space ship one makes the target
Old June 22nd 04, 01:45 PM
Tom Sixkiller
"Ace Pilot" wrote in message
om...
Doesn't NASA have a bunch already? Weren't Neil Armstrong during
Gemini
and
Apollo, and Harrison Schmidt on Apollo 14, civilians?
We have the first astronaut of a civilian funded spacecraft.
I do believe civilians have funded every penny of the US space program.
I do believe that is wrong. Military personnel pay federal taxes, so
not every penny came from civilians.
And their pay comes from....???
  #32
Old June 22nd 04, 03:57 PM
Tony Cox
"Andrew Sarangan" wrote in message
. 158...
Andrew Gideon wrote in
online.com:
What type of flight plan is required? Composite (IFR through class A,
VFR above)? Does Center provide services at these altitudes, or does
one fall back on reporting points?
- Andrew
Was a TFR established around the launch site?
If I remember correctly, it was 7mi radius centered
on KMHV up to FL200.
And isn't airspace above FL600 in the US class E?
Why the need for a change at that altitude?
  #33
Old June 22nd 04, 04:18 PM
Steven P. McNicoll
"Tony Cox" wrote in message
link.net...
Yes.
Well, above some level there's just no need for it to be Class A anymore.
The level decided upon was FL 600.
  #34
Old June 22nd 04, 04:27 PM
Tony Cox
ink.net...
link.net...
Yes.
Yes, but surely an IFR flight plan would be just as valid when ascending
through FL600 as when descending below FL180.
Assuming the mode C is properly calibrated, that is.
  #35
Old June 22nd 04, 04:41 PM
Steven P. McNicoll
ink.net...
Absolutely, in each case you're leaving Class A airspace and entering Class
E airspace.
The IFR flight plan is just as valid with an improperly calibrated encoder.
I worked a flight above FL600 just once. About fifteen years ago I was a
controller at Chicago Center working traffic in the Madison, WI, area. A
NASA ER-1 departed MSN requesting an unrestricted climb to FL610. I
coordinated with the high altitude sector and issued the climb. He went up
like a rocket! The Mode C readout couldn't keep up with him. Shortly after
he reported out of FL600 and cancelled IFR, the Mode C read FL600. I asked
a Data Systems Specialist about it and he told me that FL600 and higher will
read out as FL600.
  #36
Old June 22nd 04, 05:28 PM
Paul Sengupta
ink.net...
How do you measure altitude at 328k feet? Surely a standard
barometric device isn't going to work?
Paul
  #37
Old June 22nd 04, 05:38 PM
Tom Sixkiller
ink.net...
What's an ER-1?
I
up
after
asked
will
read out as FL600.
Cool!!!
  #38
Old June 22nd 04, 05:48 PM
Tony Cox
"Paul Sengupta" wrote in message
ink.net...
Paul
Below about 50 milliBar, people use a Pirani Gauge, which is
essentially a broken light bulb -- the wire gets hotter &
changes electrical resistance as there is less air to cool the
wire. 50mBar is around 75K ft.
Lower than about 10-2 milliBar, Ion gauges are the way to
go. They are like broken vacuum tubes.
  #39
Old June 22nd 04, 05:51 PM
Steven P. McNicoll
"Tom Sixkiller" wrote in message
What's an ER-1?
At the time, it was a derivitive of the Lockheed TR-1, which has since been
redesignated U-2R.
  #40
Old June 22nd 04, 05:52 PM
G.R. Patterson III
Tom Sixkiller wrote:
Oh? So would you please differentiate/explain the direct and indirect
funding?
Simple. My taxes go to the government or to various companies who collect them for
the government. My Federal income taxes directly fund the U.S. government, 'cause
that's who I pay them to. The space program was and is directly funded by the U.S.
government. Some portion of my tax money is used for that, and you can argue that
this means I indirectly fund the space program.
George Patterson
None of us is as dumb as all of us.
Did the Germans have the Norden bombsight? Cub Driver Military Aviation 106 May 12th 04 07:18 AM
Hubble plug to be pulled John Carrier Military Aviation 33 March 19th 04 04:19 AM
Rules on what can be in a hangar Brett Justus Owning 13 February 27th 04 05:35 PM
OT (sorta): Bush Will Announce New Space Missions Dav1936531 Military Aviation 0 January 9th 04 10:34 AM
Strategic Command Missions Rely on Space Otis Willie Military Aviation 0 September 30th 03 09:59 PM
