#31
On Thu, 08 Jul 2004 19:01:59 +0000, Mackfly wrote:
Luke you must not of seen many combat acft return home with holes big enough to park a V W in. Mac USAF retired How fast did they fly home? Also, how thick is the skin on a combat aircraft compared to a civilian airliner? I'll buy that the aircraft could stay together. The Mythbusters simulation wasn't very comprehensive... But, then again, I know just enough about high-speed aerodynamics to be afraid! :-) -Luke |
#32
On Fri, 09 Jul 2004 00:55:34 -0500, Jack wrote:
It is my understanding that the "Air Marshals" do not use the 9mm. Do you have other information? You are correct, the Marshals are not using 9mm. -Jack Davis B737 -----= Posted via Newsfeeds.Com, Uncensored Usenet News =----- http://www.newsfeeds.com - The #1 Newsgroup Service in the World! -----== Over 100,000 Newsgroups - 19 Different Servers! =----- |
#33
On Thu, 08 Jul 2004 19:03:35 +0000, Mackfly wrote:
Gads are we thinking here??? 8.5 PSID(or whatever) is the same at any altitude----Mac Thanks for the laugh, I needed that! -Jack Davis B737 -----= Posted via Newsfeeds.Com, Uncensored Usenet News =----- http://www.newsfeeds.com - The #1 Newsgroup Service in the World! -----== Over 100,000 Newsgroups - 19 Different Servers! =----- |
#34
![]() saying that the reason the perpetrators there were able to shrug off multiple hits on their armor was because the cops were using 9mm. For those who don't like conversions, 9 mm = 0.3543307 inches. That is pretty small. I never realized how small! all the best -- Dan Ford email: (put Cubdriver in subject line) The Warbird's Forum www.warbirdforum.com The Piper Cub Forum www.pipercubforum.com Viva Bush! weblog www.vivabush.org |
#35
The thing those guys missed was the effect of cold temps on the windows.
They did it in the desert, where it was likely above 80F. At altitude, the windows would be over 100 degrees colder. Plastic windows become much more fragile at those temperatures. |
#36
![]() "MichaelR" wrote in message ... The thing those guys missed was the effect of cold temps on the windows. They did it in the desert, where it was likely above 80F. At altitude, the windows would be over 100 degrees colder. On one side. Plastic windows become much more fragile at those temperatures. On one side. |
#37
Why do airliner cockpit windows have heaters?
The answer is to keep the windows warm enough and flexible enough so they don't shatter if they hit a bird. If Mythbusters had cooled that side window to -50C, it would have disintegrated when the bullet hit it. |
#38
![]() "MichaelR" wrote in message ... Why do airliner cockpit windows have heaters? The answer is to keep the windows warm enough and flexible enough so they don't shatter if they hit a bird. Why do they run them at altitudes that birds don't fly? If Mythbusters had cooled that side window to -50C, it would have disintegrated when the bullet hit it. |
#39
Tom Sixkiller wrote:
[ heated airliner windscreens] Why do they run them at altitudes that birds don't fly? I assume your question is rhetorical, but the range of altitudes at which birds may be found is far greater than most people suspect. I have seen them 14,000 msl over the lower 48, and that is no record. Other reasons: ice & snow, FOD (balloons and their payloads, kites, model aircraft, wind- and vertical current-borne objects and material), and of course the ever-present possibility of mid air collision -- all of which must be considered at all altitudes within the operating envelope. But these considerations have little to do with the advisability of preventing skyjacking by any means necessary, including the use of firearms by Federal Sky Marshals. As a cockpit crew member, a blown out window is something I can deal with -- a medium sized problem: a team of terrorists controlling the cabin is going to be a much bigger problem, and it will have ramifications well beyond anything we are likely to include in our discussions here. -- Jack "Cave ab homine unius libri" |
#40
In article , Jack
wrote: I assume your question is rhetorical, but the range of altitudes at which birds may be found is far greater than most people suspect. I have seen them 14,000 msl over the lower 48, and that is no record. As a side note on this, I'm pretty sure I once heard in a lecture or presentation -- no!, it was in a wonderful quasi-documentary movie about birds; was the title perhaps something like "Flight"? -- which described one species of fairly small birds that migrate annually by taking off from near or at sea level and flying over the Himalayas to a destination far to the north, reaching altitudes higher than the top of Everest en route -- and doing it nonstop. Hope I don't have the details too far wrong here -- but if it stimulates someone to dig out the movie itself, you may find it worth my possibly erroneous memories. |
Mythbusters Explosive Decompression Experiment | C J Campbell | Piloting | 49 | January 16th 04 07:12 AM |
More Explosive Decompression | John Galban | Piloting | 5 | January 7th 04 09:34 PM |
