#31
![]() "Roger Long" wrote in message . .. I would imagine you probably view me in the usual Usenet way and wouldn't lose a moment's sleep if I crashed and burned tomorrow. Typical Usenet posters, you and me......not friends......not enemies. Not at all! I've greatly enjoyed the wisdom and experience you bring to this group and your presence in it is one of my biggest reasons for check it every day. I'm sure I am not the only one that would feel the poorer if you decided to drop out. As for crashing and burning, I don't even want to thing about it. Thank you for the kind thought, which I'm fairly certain will probably be negated by someone else before the thread dies out, but thank you anyway. :-) Dudley Henriques International Fighter Pilots Fellowship Flight Instructor/Aerobatics/Retired |
#32
"Gary G" wrote in message ...
How about the force one one side ****ers the force (gravity) on the other. Turning an airfoil upside down doesn't violate Bernoulli. You just change teh angle of attack to componesate. Gee, if a golfer is someone who golfs, what would a ****er be? |
#33
![]() "Mark Oliver" wrote in message . .. THIS HAS A MAJOR PROBLEM - specifically inverted flight. The current theory of flight utilizing the Bernoulli's Principal is only applicable to normal level flight. That's what Bernoulli's Superintendent is for. He takes care of all the really tough situations. Pedantically, -cwk. |
#34
Andrew Gideon wrote in message gonline.com...
Roger Long wrote: The web site for this theory does just as much of a dis-service to the aliens (they aren't really aliens because they are actually right next to us and have been her all along) as the popular lift explanations do to Bernoulli and Newton. Wait...are you suggesting that it's the aliens lifting our aircraft? That would explain so much! Why do *I* end up with the lazy alien, I'd like to know. You are going to have to get friendly with the Big Pink Sky Pixies. They are replacing the old lift fairies who were all very good back in the last century... :-)) |
#35
![]() "G.R. Patterson III" wrote in message ... Andrew Gideon wrote: Why do *I* end up with the lazy alien, I'd like to know. Be content -- mine likes to play the maracas. Hmmmph! Mine tries to play the control cables like a violin. |
#36
Mark,
Nice job, your troll post has snagged a lot of responses... very effective post. |
#37
While the general aviation community is for the most part unaware of the
vital role played by Lift Demons, the FAA has for a long time taken them into consideration when formulating Federal Aviation Regulations. In fact, understanding the needs and wants of Lift Demons greatly helps in understanding many of the rules that the FAA has introduced over the years (which otherwise make little sense to the average pilot). For example as it turns out there are two types of Lift Demons. Bird Demons and Bat Demons. Bat Demons are blind because they evolved along side bats in caves, they also have sticky feet which help them to grip onto the more slippery wings of bats. Now, when man first took to the skies, it was on the wings of bird demons (Seagull demons to be exact in Kittyhawk). However, before long some bright sparks decided that unlike birds man would fly his airplanes inside clouds (not something that birds usually do - I mean have you ever seen a bird inside a cloud ?). Straight away there was a problem. Bird Demons need to be able to see where they are going and when they can't see they get scared and quickly jump off the plane - causing unfortunate accidents. Should you every fly into a cloud by mistake - quickly start a 180 degree turn to get out of it before the Lift Demons panic. However, before long a solution was found, Bat Demons, being blind didn't panic inside a cloud, they didn't need to see in order to keep the lift working. As a bonus, their sticky feet helped them grip wet slippery wings which is common when inside a cloud. However, there are not very many Bat Demons (at least compared to Bird Demons) so you need to make sure some Bat Demons are waiting for your plane at the runway before you take off if you are planning on flying into a cloud. The FAA realized this and created the Air Traffic Control system to facilitate the timely coordination of Bat Demons and planes. And that is why FAR 91.173 exists Sec. 91.173 ATC clearance and flight plan required. No person may operate an aircraft in controlled airspace under IFR unless that person has-- (a) Filed an IFR flight plan; and (b) Received an appropriate ATC clearance. You see, when you file an IFR flight plan the flight service station computer sends a message to the nearest colony of Bat Demons telling them where and when they will be needed. Actually, the demons we all know that live inside computers can communicate directly with their demon brothers - so the Bat demons don't need their own computers. The Bat Demons don't always turn up on time, which is why you can't actually take-off until ATC sees the Bat Demons arrive and issue your IFR release. Sometimes, when the weather is really bad and lots of planes want to fly in the clouds, there are not enough Bat Demons to go around and you have to wait a long time on the ground for some to arrive. It all starts to make sense when you think about it. Bird Demons don't even like getting close to clouds. That is why you always have to ask ATC for Special VFR, this gives them a chance to call up at least a few Bat Demons, to keep all the other Demons calm as you fly close too the (but not in) the clouds. Class bravo airspace has so many big jets flying with lots of Bat Demons that there is always a few extra around which lets you get closer to the clouds as well. |
#38
On Tue, 05 Oct 2004 16:22:30 GMT, "OtisWinslow"
wrote: Bernoulli sucks. The wing lifts because air pushes on one side and not the other. That's what I told my flight instructor, but he did not seem impressed. all the best -- Dan Ford email: (put Cubdriver in subject line) Warbird's Forum www.warbirdforum.com Piper Cub Forum www.pipercubforum.com Viva Bush! www.vivabush.org |
#39
"Dudley Henriques" wrote in message link.net...
"Roger Long" wrote in message . .. I would imagine you probably view me in the usual Usenet way and wouldn't lose a moment's sleep if I crashed and burned tomorrow. Typical Usenet posters, you and me......not friends......not enemies. Not at all! I've greatly enjoyed the wisdom and experience you bring to this group and your presence in it is one of my biggest reasons for check it every day. I'm sure I am not the only one that would feel the poorer if you decided to drop out. As for crashing and burning, I don't even want to thing about it. Thank you for the kind thought, which I'm fairly certain will probably be negated by someone else before the thread dies out, but thank you anyway. :-) Dudley Henriques International Fighter Pilots Fellowship Flight Instructor/Aerobatics/Retired Dudley, I too would be most upset to find that you had crashed and burned... Unlsess of course, Iwan Bogels got it on video and I could entertain myself with the fiery spectacle of your demise! |
#40
![]() "Pat" wrote in message om... "Dudley Henriques" wrote in message link.net... "Roger Long" wrote in message . .. I would imagine you probably view me in the usual Usenet way and wouldn't lose a moment's sleep if I crashed and burned tomorrow. Typical Usenet posters, you and me......not friends......not enemies. Not at all! I've greatly enjoyed the wisdom and experience you bring to this group and your presence in it is one of my biggest reasons for check it every day. I'm sure I am not the only one that would feel the poorer if you decided to drop out. As for crashing and burning, I don't even want to thing about it. Thank you for the kind thought, which I'm fairly certain will probably be negated by someone else before the thread dies out, but thank you anyway. :-) Dudley Henriques International Fighter Pilots Fellowship Flight Instructor/Aerobatics/Retired Dudley, I too would be most upset to find that you had crashed and burned... Unlsess of course, Iwan Bogels got it on video and I could entertain myself with the fiery spectacle of your demise! If your post was meant tongue in cheek, be advised I don't know you and you don't know me well enough to say something like this to me. If you meant it the other way, go f**k yourself! Dudley Henriques International Fighter Pilots Fellowship Flight Instructor/Aerobatics/Retired |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 02:26 PM |
new theory of flight released Sept 2004 | Mark Oliver | Aerobatics | 1 | October 5th 04 10:20 PM |
ramifications of new TSA rules on all non-US and US citizen pilots | paul k. sanchez | Piloting | 19 | September 27th 04 11:49 PM |
Flight Simulator 2004 pro 4CDs, Eurowings 2004, Sea Plane Adventures, Concorde, HONG KONG 2004, World Airlines, other Addons, Sky Ranch, Jumbo 747, Greece 2000 [include El.Venizelos], Polynesia 2000, Real Airports, Private Wings, FLITESTAR V8.5 - JEP | vvcd | Home Built | 0 | September 22nd 04 07:16 PM |
Looking for Cessna Caravan pilots | [email protected] | Owning | 9 | April 1st 04 02:54 AM |
