Run up for plug clearing
Old October 10th 04, 04:21 AM
Dudley Henriques
"Daniel L. Lieberman" wrote in message
Dudley,
You have made my point. There is a POH for every plane. A pilot should
read it when he has a question.
Of course.
He is supposed to always be learning.
Basic flying 101.
If he has
found an answer then he should verify what he has found with a CFI if
he feels it necessary.
One way to handle it that's for sure. He could also check any and all
available sources of information as he should be doing; and this would
include any good CFI; the result should be a path leading directly to
the manufacturer's POH.
My point was simply that your statement as worded assumed that the
"average flight instructor" might not know enough to point the
questioner in the direction of the POH; an assumption I totally disagree
with.
I have no problem at all with your basic premise that checks the POH. In
fact that would be MY answer as well. Since I'm a flight instructor, and
would have done that, your added "assumption" to your comment about
CFI's not necessarily knowing enough to point a pilot to the POH I
thought might need a bit of "adjustment" so to speak. :-)
The question did NOT contain the necessary information to find a
specific answer.
Correct.
What I quoted was quoted as an example of what can be found by
reading the POH.
Also correct. Just don't assume that the "average flight instructor"
wouldn't know enough to point someone in the right direction.
The instructor obviously, if he is competent, which we must assume
until proven otherwise could answer the question - what does that
teach the pilot?
Don't assume anything in flying. It will kill you in short order! As for
"teaching the pilot". It isn't a CFI "game". If a pilot has a question,
you give him what you have and point him in the right direction to the
answer. In this case it's the POH. Any informative source can do that.
It's up to the pilot to make maximum use of all available sources and
sort out the good from the bad.
Again, my comment on your remark is directed only to your instructor
reference being not as reliable as the manufacturer's POH. BOTH should
be equally reliable in the context of this question; the POH for
supplying the needed data and the instructor for supplying the path to
the POH for obtaining that data.
It's no big deal, but I like to keep the air nice and clean when it
comes to statements about instructors.
Your basic point about the POH was correct. In my opinion, your added
reference about the "average instructor" I thought needed some
additional clarification which we have done I believe.
Dudley Henriques
International Fighter Pilots Fellowship
Flight Instructor/Aerobatics/Retired
The pilot has the ultimate responsibility for what he does. At some
time he must cut the apron strings and act like a PIC. That obviously
requires asking a more knowledgeable person if he cannot answer a
question himself with a little work.
Daniel
P.S. I believe that almost all CFIs are competent. The ultimate goal
is to generate a safe pilot who can fly himself.
Old October 10th 04, 11:21 AM
Cub Driver
If only this were true! I would love to have a POH for the 1946 J-3
Cub that I fly.
all the best -- Dan Ford
email: (put Cubdriver in subject line)
Warbird's Forum
www.warbirdforum.com
Piper Cub Forum www.pipercubforum.com
Viva Bush! www.vivabush.org
Old October 10th 04, 02:05 PM
Larry Dighera
On Sun, 10 Oct 2004 06:21:11 -0400, Cub Driver
wrote in
Cub that I fly.
Owner's Manual for Cub Special J-3C-65……………..………$10.00
http://www.cub-club.com/Printed72303.doc
Here's a CD with 8 different Cub manuals:
http://www.flight-manuals-on-cd.com/Cub.html
There's one he
http://www.aeroplanebooks.com/seriesPilot.htm
Piper Cub J-3 Service Manual
http://www.historicaviation.com/historicaviation/product_info.po;jsessionid=vE63PPu_0M-U90wTx3XdDKst(0CpplRPt)?ID=1544
http://www.xs4all.nl/~aviation/books3.html
http://www.texair.com/rfq/catalog-P.asp
Larry Dighera
wrote in
Cub that I fly.
There's one he
Cub Driver
Cub that I fly.
Warbird's Forum
Old October 10th 04, 02:20 AM
Daniel L. Lieberman
Dudley,
You have made my point. There is a POH for every plane. A pilot should read
it when he has a question. He is supposed to always be learning. If he has
found an answer then he should verify what he has found with a CFI if he
feels it necessary.
The question did NOT contain the necessary information to find a specific
answer. What I quoted was quoted as an example of what can be found by
reading the POH.
The instructor obviously, if he is competent, which we must assume until
proven otherwise could answer the question - what does that teach the pilot?
The pilot has the ultimate responsibility for what he does. At some time he
must cut the apron strings and act like a PIC. That obviously requires
asking a more knowledgeable person if he cannot answer a question himself
with a little work.
Daniel
P.S. I believe that almost all CFIs are competent. The ultimate goal is to
Old October 9th 04, 04:55 PM
Dudley Henriques
The answer to questions such as this can be found in the POH from the
manufacturer who supposedly knows more than the average flight
instructor.
I just love posts like this one!!
A good flight instructor would know that the answer to this question is
not a general answer that works for all aircraft and would therefore not
deal with it on a newgroup forum or in person before checking it out for
engine manufacturer recommendations and POH remarks as the answer
relates to the SPECIFIC aircraft/engine combination involved with the
question.
Although your answer is correct, unless you are one of these "pilots" on
"piloting" who think CFI's are morons, I see no reason to assume that
the "average" flight instructor wouldn't be intelligent enough to do
this.
Dudley Henriques
Old October 9th 04, 06:59 PM
G.R. Patterson III
"Daniel L. Lieberman" wrote:
For the Cessna Model 152 .......
Roger has a Skyhawk.
George Patterson
If a man gets into a fight 3,000 miles away from home, he *had* to have
been looking for it.
G.R. Patterson III
George Patterson
Old October 9th 04, 03:59 PM
Larry Dighera
On Sat, 09 Oct 2004 10:54:44 GMT, "Roger Long"
wrote in ::
Any thoughts?
http://www.sacskyranch.com/faq_spark_plug/index.html
http://www.sacskyranch.com/faq_spark_plug/FAQ00007.htm
Clearing a fouled plug Roger Long Piloting 3 July 6th 04 05:53 AM
