On Tue, 26 Oct 2004 at 18:12:20 in message
TBCfd.18911$SW3.16862@fed1read01, Jay Beckman wrote: Is that due to the crash at the Paris Airshow several years back? Many people say Paris - it wasn't Paris it was Mulhouse, in the upper Rhine Valley near the junction of the Swiss and German borders. It was only a local air show and the aircraft was an almost new A320 (it had been in service for 2 days). The Airport (if you could call it that) has one main paved runway only 1000m long plus some grass strips for gliders. Air France were invited to display an A320. It could not land there. Not only that but it was a charter flight with 130 passengers aboard - how often does that happen at the Paris Air Show I wonder? The crew were probably given an inadequate briefing on the airport. The idea was to do a low slow pass in landing configuration at about 100ft. (Often done in France although the air show regulations said 170 ft.) They intended to reach the maximum allowable angle of attack in the low pass. They meant they would inhibit the 'alpha floor' limit which would automatically increase power at that point. The co-pilot was supposed to control the power. When they identified the airport they were close but they saw that the crowd seemed to be along a grass strip and not along the chosen paved runway 02. They realigned and at 100 ft deactivated the alpha floor function. They sank to only 30 ft above the strip. They then suddenly realised there were trees ahead at the same height or higher than the aircraft. They then called for TO power but it was too late. Speed had reduced to 122k and the engines now at flight idle responded as they should. There was then nothing anyone or the aircraft could do. 4.5 seconds after power started increasing it began hitting the trees. That is a very much abbreviated version but I believe substantially correct. IIRC, the pilot commanded a flight attitude in the landing config that the software wouldn't allow and that led to the aircraft settling into the trees. Sorry that is wrong. And it did not settle into the trees; it flew horizontally into them at an altitude of 24 ft and then sank! This accident is very often badly reported. Although the system would not permit main flight restrictions to be exceeded the performance at those low limits was as limited as any conventional aircraft would have been. It could not climb at flight idle at 122 knots and 15 degrees nose up. That is not a surprise. This case is a bad example but often used. Ref: Air Disaster Volume 3 by Macarthur Job. Roughly 13 pages -- David CL Francis |
David CL Francis wrote:
That is a very much abbreviated version but I believe substantially correct. My memory has blurred during all those years, but yes, now I rememberm, this is exactly how it was found in the report. Thanks for refreshing my memory. Summary: You can fly any airplane into the trees if you deliberately wish to do so. Stefan |
![]() David CL Francis wrote: On Tue, 26 Oct 2004 at 18:12:20 in message TBCfd.18911$SW3.16862@fed1read01, Jay Beckman wrote: Is that due to the crash at the Paris Airshow several years back? Many people say Paris - it wasn't Paris it was Mulhouse, in the upper Rhine Valley near the junction of the Swiss and German borders. It was only a local air show and the aircraft was an almost new A320 (it had been in service for 2 days). The Airport (if you could call it that) has one main paved runway only 1000m long plus some grass strips for gliders. Air France were invited to display an A320. It could not land there. Not only that but it was a charter flight with 130 passengers aboard - how often does that happen at the Paris Air Show I wonder? The crew were probably given an inadequate briefing on the airport. Indeed they were. The idea was to do a low slow pass in landing configuration at about 100ft. (Often done in France although the air show regulations said 170 ft.) They intended to reach the maximum allowable angle of attack in the low pass. They meant they would inhibit the 'alpha floor' limit which would automatically increase power at that point. The co-pilot was supposed to control the power. When they identified the airport they were close but they saw that the crowd seemed to be along a grass strip and not along the chosen paved runway 02. They realigned and at 100 ft deactivated the alpha floor function. They sank to only 30 ft above the strip. Nope - they were using the analogue readout barometric altimeter not the more accurate digital readout radalt ( for reasons of being easier to read whilst rapidly changing in this instance ). During the take off phase the radalt and baro altimeter somehow got 'misaligned' by 70 odd feet. Hence they thought they were flying at 100ft when it was actually 30 ft. They then suddenly realised there were trees ahead at the same height or higher than the aircraft. They then called for TO power but it was too late. Speed had reduced to 122k and the engines now at flight idle responded as they should. There was then nothing anyone or the aircraft could do. 4.5 seconds after power started increasing it began hitting the trees. Actually, increased power was called for as planned. They were indeed unaware of the trees due to the poor briefing material. Exactly how and why the engines responded as they did has been a matter of considerable debate. That version of the CFM 56 ? was subsequently altered and units in service 'upgraded' following a compressor stall incident on another early A320 at Geneva ? IIRC. That is a very much abbreviated version but I believe substantially correct. IIRC, the pilot commanded a flight attitude in the landing config that the software wouldn't allow and that led to the aircraft settling into the trees. Sorry that is wrong. And it did not settle into the trees; it flew horizontally into them at an altitude of 24 ft and then sank! This accident is very often badly reported. Although the system would not permit main flight restrictions to be exceeded the performance at those low limits was as limited as any conventional aircraft would have been. It could not climb at flight idle at 122 knots and 15 degrees nose up. That is not a surprise. The response of the engines was a surprise to the pilots. Graham |
![]() nobody wrote: Pete wrote: I thought that was one of the main advantages of fly-by-wire systems, to eliminate truly stupid actions of pilots. Sounds like Airbus shares a lot of blame for the crash. The A300-600 is not fly by wire. It is a 1970s plane updated to some extent in the 1980s. And I have been told that because rudders are so rarely used in flight............. You're not a friend of John Tarver are you ? He insisted that rudders on big jets were *purely* yaw dampers. that Airbus didn't actually make it "smart" with software to restrict movement depending on airplane's speed etc on its FBW planes. Note that similar rudder use on Boeing planes would also cause the tail to break off. After the accident, I hear that Boeing issued a similary advisory to Airbus regarding use of rudder. Graham |
Pooh Bear wrote:
You're not a friend of John Tarver are you ? He insisted that rudders on big jets were *purely* yaw dampers. Isn't he the one who was certain planes have slaps, a combination of slats and flaps ? :-) :-) |
Howdy!
In article , nobody wrote: Pooh Bear wrote: You're not a friend of John Tarver are you ? He insisted that rudders on big jets were *purely* yaw dampers. Isn't he the one who was certain planes have slaps, a combination of slats and flaps ? "splaps"... and the P1T0Tube that has nothing to do with measuring dynamic air pressure... Just an ID ten T problem... :-) :-) yours, Michael -- Michael and MJ Houghton | Herveus d'Ormonde and Megan O'Donnelly | White Wolf and the Phoenix Bowie, MD, USA | Tablet and Inkle bands, and other stuff | http://www.radix.net/~herveus/wwap/ |
![]() "Peter" wrote But if there's a clear rule for what 'shouldn't be done' then it would seem prudent to build it into the firmware for the fly-by-wire system so that it can't be done. BINGO Seems to me that Airbus is, if not criminally responsible, morally and legally responsible. -- Jim in NC --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.782 / Virus Database: 528 - Release Date: 10/23/2004 |
On Tue, 26 Oct 2004 18:05:42 -0400, Morgans wrote:
"Peter" wrote But if there's a clear rule for what 'shouldn't be done' then it would seem prudent to build it into the firmware for the fly-by-wire system so that it can't be done. BINGO Seems to me that Airbus is, if not criminally responsible, morally and legally responsible. ???? From what I hear (1) the US certification standards *do not* require the rudder to be able to withstand the sort of forces the exercise in question resulted in, and no plane, whether Boeing or Airbus, builds rudders that would. This is presumably public knowledge, and presumably open information available to American Airline; incidentally, the same scenario would have led to a similar accident with a Boeing plane. (2) apparently, Airbus had repeatedly warned AA about the flaws in AA's training procedures, which recommended excessive rudder use, even in situations that were patently unsafe. So, it does seem to me that the biggest share of the blame should be with AA. AA doe claim that the warnings from Airbus were not clear enough or not strong enough. My problem with that is that AA was recommending the same procedure with Boeing planes too. So presumably Boeing's warnings were not strong enough either? |
![]() "devil" wrote in message news ![]() On Tue, 26 Oct 2004 18:05:42 -0400, Morgans wrote: "Peter" wrote But if there's a clear rule for what 'shouldn't be done' then it would seem prudent to build it into the firmware for the fly-by-wire system so that it can't be done. BINGO Seems to me that Airbus is, if not criminally responsible, morally and legally responsible. ???? From what I hear (1) the US certification standards *do not* require the rudder to be able to withstand the sort of forces the exercise in question resulted in, and no plane, whether Boeing or Airbus, builds rudders that would. This is presumably public knowledge, and presumably open information available to American Airline; incidentally, the same scenario would have led to a similar accident with a Boeing plane. ***************************** My point was that a FBW aircraft that did not have limiting software, is wrong. I now see that the plane in question was not FBW. "Nevermind! "g --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.782 / Virus Database: 528 - Release Date: 10/23/2004 |
is wrong. I now see that the plane in question was not FBW. "Nevermind! "g Yeah, me too. I assumed all Airbus aircraft employed FBW. Mea culpa. But to start another flame war, maybe AA has a culture problem of ignoring manufacturers' advice. Remember that it was an AA DC-10 that lost an engine at ORD, and AA's maintenance practice of removing engines with a forklift was the culprit, contrary to McDonnell Douglas' advice. Pete |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 02:26 PM |
Military: Pilot confusion led to F-16 crash that killed one pilot | Otis Willie | Military Aviation | 0 | September 1st 04 12:30 AM |
P-51C crash kills pilot | Paul Hirose | Military Aviation | 0 | June 30th 04 05:37 AM |
Fatal plane crash kills pilot in Ukiah CA | Randy Wentzel | Piloting | 1 | April 5th 04 05:23 PM |
AmeriFlight Crash | C J Campbell | Piloting | 5 | December 1st 03 02:13 PM |
