Don't forget that, as with any airplane, stall speed and thus approach speed vary with weight. If 70 knots works well on short final at max gross weight, then to get the same flare and float characteristics, you must be slower at lighter weights. If the plane is 20% below max gross, then approach speed should be 10% less. A couple of other things that might be a bit more 'advanced', or at least are not in the POH but are worth considering. When you're deep in the flare, flip your flaps to up. Stall speed goes up, the airplane will stay down when it touches down. If there's a serious cross wind and the runway is wide -- say 100 feet or so -- you can take 4 or so degrees off the crosswind component by planing your touch down near the downwind side of the runway, aiming towards the upwide side. If you cross say 50 feet of runway -- 25 feet from the downwind edge to within 25 feet of the upwind edge in say 750 feet you'll have changed the effective runway heading about 4 degrees. It's often enough to give you a little more rudder authority (in my M20J at least I run out of rudder in strong cross winds -- I like to touch down pretty slowly). |
I generally take 5 knots off everything in my Mooney when I'm light.
"Barry" wrote in message ... Don't forget that, as with any airplane, stall speed and thus approach speed vary with weight. If 70 knots works well on short final at max gross weight, then to get the same flare and float characteristics, you must be slower at lighter weights. If the plane is 20% below max gross, then approach speed should be 10% less. |
Don't flare a Mooney.
What you know as a flare will cause nothing but trouble. Instead of the "flare" do a "round out". If you have good electric trim, use it instead of back pressure. Also, don't chop the power, remove it SLOOOOWWWWLLLY. The plane can land before idle.You want a slow transition from nose down to nose wheel just a bit higher. Let the plane fly down the runway while the speed bleeds. Worry about spot landings after you have practiced smooth ones. Once you have the site pictures and techniques, you can move it to the numbers. What others have said about airspeed and stabilized approach are more important than what I just said, but if you got them right this is the next step. "Jon Kraus" wrote in message ... We just purchased a'79 M20J 4443H. I am in the middle of getting my 10 hours with a CFI for Insurance purposes and I have to tell you that this thing is a lot different to land than a Skyhawk. So far I am glad that my CFI has been with me because 75 percent of the landings have not been pretty. They are safe (mostly) but nothing you'd want the wife to film with the video camera. I've got the speeds down good (100 on downwind, 90 on base and 80 on final) but getting it to the runway smoothly has been a challange. I've never flown a low wing plane before the Mooney and I am having a problem with the sight picture working out for me. Is this a pretty common issue in transitioning to these planes or should I just resign to the fact that I'm not going to get as nice a landings in my Mooney as I did in the Skyhawk . Right now any stories would help out tremendously!! Thanks. Jon Kraus PP-ASEL-IA Student Mooney Owner '79 M20J 4443H @ TYQ |
Until you get your visual sight picture down you might try reducing power to
idle at about 50' and just flying it onto the runway with a controlled smooth descent, making sure you don't land nosegear first. Then when you have that down you could use the "normal" procedure of holding it just off the runway until it plays out and lands. With a low wing you have a little more ground effect near touchdown. -- Darrell R. Schmidt B-58 Hustler History: http://members.cox.net/dschmidt1/ - "Jon Kraus" wrote in message ... We just purchased a'79 M20J 4443H. I am in the middle of getting my 10 hours with a CFI for Insurance purposes and I have to tell you that this thing is a lot different to land than a Skyhawk. So far I am glad that my CFI has been with me because 75 percent of the landings have not been pretty. They are safe (mostly) but nothing you'd want the wife to film with the video camera. I've got the speeds down good (100 on downwind, 90 on base and 80 on final) but getting it to the runway smoothly has been a challange. I've never flown a low wing plane before the Mooney and I am having a problem with the sight picture working out for me. Is this a pretty common issue in transitioning to these planes or should I just resign to the fact that I'm not going to get as nice a landings in my Mooney as I did in the Skyhawk . Right now any stories would help out tremendously!! Thanks. Jon Kraus PP-ASEL-IA Student Mooney Owner '79 M20J 4443H @ TYQ |
Hard to resist this thread. I was on the Mooney listserver for a couple of
years and there is an 'unlimited' number of landing notes for you. Every model, vintage, condition. If you aren't on it, you should be. Don't have the details though. The various models apparently have different speeds, challenges, and techniques. I flew a '61 model 21 with the Johnson bar. I fell in love with landing it, and I'm a high wing guy too. Airspeed as always was the key. The thing I liked the most though, was doing short field landings at 65mph as I remember. At a very specific airspeed (68 I think at our weight), you apparently fell out of laminar flow mode and the descent angle would significantly steepen. If you held 65 and pulled the power 2 wingspans up, it was automatic spot landing. Neat. I think someone else mentioned that effect (pitch up and slow 5 knots and the descent rate goes up). Apparently that is a lot trickier on the later heavier models. Have fun! "Jon Kraus" wrote in message ... We just purchased a'79 M20J 4443H. I am in the middle of getting my 10 hours with a CFI for Insurance purposes and I have to tell you that this thing is a lot different to land than a Skyhawk. So far I am glad that my CFI has been with me because 75 percent of the landings have not been pretty. They are safe (mostly) but nothing you'd want the wife to film with the video camera. I've got the speeds down good (100 on downwind, 90 on base and 80 on final) but getting it to the runway smoothly has been a challange. I've never flown a low wing plane before the Mooney and I am having a problem with the sight picture working out for me. Is this a pretty common issue in transitioning to these planes or should I just resign to the fact that I'm not going to get as nice a landings in my Mooney as I did in the Skyhawk . Right now any stories would help out tremendously!! Thanks. Jon Kraus PP-ASEL-IA Student Mooney Owner '79 M20J 4443H @ TYQ |
I also do my short field landings like that when I'm in Mexico with my
Mooney. As you slow the Mooney down below around 70 knots the rate of decent goes up a lot. You can drag it in on the prop and drop it one a spot easily. If you run the trim all the way back you can also raise the nose up on take off and accelerate on the mains. Tricky though, check out a CFI first. BTW: If you are flying an older Mooney just substitute knots for mph. So the older Mooneys approach at 75-80mpg, the newer one use 75-80 knots. Same thing with over the fence speed (should be 5 mph less than your approach speed). Kinda neat that it works out that way. -Robert "Maule Driver" wrote in message om... Hard to resist this thread. I was on the Mooney listserver for a couple of years and there is an 'unlimited' number of landing notes for you. Every model, vintage, condition. If you aren't on it, you should be. Don't have the details though. The various models apparently have different speeds, challenges, and techniques. I flew a '61 model 21 with the Johnson bar. I fell in love with landing it, and I'm a high wing guy too. Airspeed as always was the key. The thing I liked the most though, was doing short field landings at 65mph as I remember. At a very specific airspeed (68 I think at our weight), you apparently fell out of laminar flow mode and the descent angle would significantly steepen. If you held 65 and pulled the power 2 wingspans up, it was automatic spot landing. Neat. I think someone else mentioned that effect (pitch up and slow 5 knots and the descent rate goes up). Apparently that is a lot trickier on the later heavier models. Have fun! "Jon Kraus" wrote in message ... We just purchased a'79 M20J 4443H. I am in the middle of getting my 10 hours with a CFI for Insurance purposes and I have to tell you that this thing is a lot different to land than a Skyhawk. So far I am glad that my CFI has been with me because 75 percent of the landings have not been pretty. They are safe (mostly) but nothing you'd want the wife to film with the video camera. I've got the speeds down good (100 on downwind, 90 on base and 80 on final) but getting it to the runway smoothly has been a challange. I've never flown a low wing plane before the Mooney and I am having a problem with the sight picture working out for me. Is this a pretty common issue in transitioning to these planes or should I just resign to the fact that I'm not going to get as nice a landings in my Mooney as I did in the Skyhawk . Right now any stories would help out tremendously!! Thanks. Jon Kraus PP-ASEL-IA Student Mooney Owner '79 M20J 4443H @ TYQ |
Years ago I did allot of flying in a M20C, they are fast and tend to float.
If I remember the key is to be right on the speed at flare or expect it to balloon and float. It will get better with practice. Ron Gardner Jon Kraus wrote: We just purchased a'79 M20J 4443H. I am in the middle of getting my 10 hours with a CFI for Insurance purposes and I have to tell you that this thing is a lot different to land than a Skyhawk. So far I am glad that my CFI has been with me because 75 percent of the landings have not been pretty. They are safe (mostly) but nothing you'd want the wife to film with the video camera. I've got the speeds down good (100 on downwind, 90 on base and 80 on final) but getting it to the runway smoothly has been a challange. I've never flown a low wing plane before the Mooney and I am having a problem with the sight picture working out for me. Is this a pretty common issue in transitioning to these planes or should I just resign to the fact that I'm not going to get as nice a landings in my Mooney as I did in the Skyhawk . Right now any stories would help out tremendously!! Thanks. Jon Kraus PP-ASEL-IA Student Mooney Owner '79 M20J 4443H @ TYQ |
Key to a smooth landing ishave the flightpath to be parallel to the landing
surface as the plane touches. Consistent roundouts to land need good consistent airspeed control. It s amater of timing. Btw, is you engine a IO-360-A3B6 or still an IO-360-A1B6 ? Kent Felkins Tulsa a |
Jon Kraus wrote
We just purchased a'79 M20J 4443H. I am in the middle of getting my 10 hours with a CFI for Insurance purposes and I have to tell you that this thing is a lot different to land than a Skyhawk. Yes it is. It's also a lot different than other airplanes in its class. It's not really that it's harder to land - it's that it advertises even your most minor mistakes to everyone watching. Some airplanes make you look good even when you are sloppy - true of the C-172, and also true of the Bonanza (and pretty much every Beech product I've ever flown, though I admit I haven't flown and Beech taildraggers). Some airplanes make you look bad if you do anything short of a perfect job. I've got the speeds down good (100 on downwind, 90 on base and 80 on final) but getting it to the runway smoothly has been a challange. Those speeds sound right. However, all the correct speed buys you is a landing that is WHERE you want it. The Mooney gear has very little shock absorption. In something like a Bonanza, you have long oleo struts - so a few inches either way is no big deal. Three inches high and you will never know it. In a Mooney, three inches high is very noticeable. Those rubber donuts simply are not very good for shock absorption. Bottom line - you're not just transitioning into an airplane that lands differently, you're transitioning into one that requires more skill to land well - not just airspeed control, but judging your altitude and rate of descent in the flare precisely (and I mean down to the inch). I've never flown a low wing plane before the Mooney and I am having a problem with the sight picture working out for me. Is this a pretty common issue in transitioning to these planes or should I just resign to the fact that I'm not going to get as nice a landings in my Mooney as I did in the Skyhawk . It's not a low wing vs. high wing issue - it's just that you are being called upon to judge and control your altitude and rate of descent in the flare more precisely than was ever necessary before. You are extending your skills. So get a CFI experienced in Mooneys (not some guy who has 10 hours in one, but someone who actually owns and flies a Mooney) and practice man, practice. With time, it will come. Michael |
Michael wrote:
It's not really that it's harder to land - it's that it advertises even your most minor mistakes to everyone watching. Also advertises those mistakes to the pilot's rear. There's not much give in those rubber biscuits. |
| Thread Tools | |
| Display Modes | |
| Skycraft Landing Light Question | Jay Honeck | Owning | 15 | February 3rd 05 07:49 PM |
| Landing a Mooney | Jon Kraus | Owning | 42 | November 16th 04 08:00 PM |
| VW-1 C-121J landing with unlocked nose wheel | Mel Davidow LT USNR Ret | Military Aviation | 1 | January 19th 04 06:22 AM |
| "I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 10th 04 12:35 AM |
| Off topic - Landing of a B-17 | Ghost | Home Built | 2 | October 28th 03 05:35 PM |
