#31
tony roberts wrote:
There's only one "R" in AROW nowadays, you know. The missing one if for the redidio license. -- Jim Fisher So If I read this correctly I don't actually need a redidio licence? Do I even need a redidio? I gotta redidio...love listing to them old time redidio shows on it... the Shadow, Life with Luigi, Dragnet... |
#32
![]() "Cub Driver" wrote in message ... On Sat, 06 Nov 2004 15:24:04 GMT, john smith wrote: Correct. You only need one if you are going outside the USA. I have yet to have the folks in Canada ask for the Radio License. Dave Stadt wrote: You are just fine. In your situation a station or operators license is not required. The requirement went away about a decade ago. Thanks, guys. Guess what I found at Larry's website?: ******************************* b) An aircraft station is licensed by rule and does not need an individual license issued by the FCC if the aircraft station is not required by statute, treaty, or agreement to which the United States is signatory to carry a radio, and the aircraft station does not make international flights or communications. Even though an individual license is not required, an aircraft station licensed by rule must be operated in accordance with all applicable operating requirements, procedures, and technical specifications found in this part. **************************** Which seems to say that the airplane has a "license" even if it doesn't have a license! What all that says is: 1. Radio regulations are governed by an International Agreement... not by the USA, Canada, or any other one country. 2. That agreement requires a license for the radio (station license) and a license for the operator (in the case of aviation, an Aeronautical Restricted Operator's License) 3. The USA and Canada have elected to stop enforcing the station license requirement (for VHF radio in planes and boats), where they have jurisdiction.... that is: each within its own borders. 4. The USA has elected to stop enforcing the operator's license requirement (but Canada continues to enforce it). 5. The rules in Canada and the USA will respect the installation or operator of another country, (even if there is no license required in that country), as long as there is a reciprocal agreement that allows the same for both parties. Unfortunately, such an agreement has not yet been signed between Canada and the USA. 6. THEREFORE, the *official* position of each country has to revert to points 1 and 2 above. If "my" citizen operates a radio transmitter outside of "my own" borders, I must enforce the license requirements, or I am in breach of the International Agreement that I agreed to and signed. |
#33
Your'e not since the radio is not permanantly installed. The J-3 was
built before ARROW. Have a great one! Bush On Sat, 06 Nov 2004 05:19:25 -0500, Cub Driver wrote: Okay, the Cub I rent has no radio, hence no radio license. I am vaguely aware, each time I use the handheld, that I am operating without a station license. Is this a problem? Should I apply to the FCC for a license, and if so, what sort of license do I want? all the best -- Dan Ford email: (put Cubdriver in subject line) Warbird's Forum www.warbirdforum.com Piper Cub Forum www.pipercubforum.com the blog www.danford.net |
#34
![]() "Bush" wrote in message ... Your'e not since the radio is not permanantly installed. The J-3 was built before ARROW. What does permanent installation have to do with it? A radio transmitter in the aeronautical VHF bands requires a station license.... except that the FCC has waived that requirement, provided the transmitter is used in accordance with the rest of the rules. It does not matter whether the transmitter is permanently installed or not. A handheld is still subject to the same regulations. |
#35
![]() "Icebound" wrote in message ... "Bush" wrote in message ... Your'e not since the radio is not permanantly installed. The J-3 was built before ARROW. What does permanent installation have to do with it? A radio transmitter in the aeronautical VHF bands requires a station license.... except that the FCC has waived that requirement, provided the transmitter is used in accordance with the rest of the rules. It does not matter whether the transmitter is permanently installed or not. A handheld is still subject to the same regulations. Nor does it matter if the plane was built before ARROW (whatever that means). He was wrong on all counts. |
#36
![]() "Dave Stadt" wrote in message . com... Nor does it matter if the plane was built before ARROW (whatever that means). He was wrong on all counts. ARROW are the current on-board-document rules: A-irworthiness Certificate R-egistration Certificate R-adio Station License O-perating Limits (POH) W-eight and balance documentation He was suggesting that just because an aircraft was built before these rules came into effect, they don't apply (or at least the radio one does not apply). That is false, as you said. If you use a radio on an aircraft with no electric, it (and the operator) still have to comply with the FCC rules. |
#37
So, I got my pilot license in 1963 and had to get a radio license too.
I have lost it. Does anyone know if there is an FCC sub-agency who will replace it for me? Thanks in advance. (Of course this begs the question, why do I want it if I don't need it.) |
#38
![]() Icebound wrote: ARROW are the current on-board-document rules: A-irworthiness Certificate R-egistration Certificate R-adio Station License O-perating Limits (POH) W-eight and balance documentation He was suggesting that just because an aircraft was built before these rules came into effect, they don't apply (or at least the radio one does not apply). That is false, as you said. If you use a radio on an aircraft with no electric, it (and the operator) still have to comply with the FCC rules. But, as of 1996, the radio station license is not required in the United States. George Patterson If a man gets into a fight 3,000 miles away from home, he *had* to have been looking for it. |
#39
![]() "G.R. Patterson III" wrote in message ... Icebound wrote: ARROW are the current on-board-document rules: A-irworthiness Certificate R-egistration Certificate R-adio Station License O-perating Limits (POH) W-eight and balance documentation He was suggesting that just because an aircraft was built before these rules came into effect, they don't apply (or at least the radio one does not apply). That is false, as you said. If you use a radio on an aircraft with no electric, it (and the operator) still have to comply with the FCC rules. But, as of 1996, the radio station license is not required in the United States. That is correct. The origional poster implied that AROW or ARROW would not apply to a Cub because it was built before AROW or ARROW came into common use. The poster was wrong. George Patterson If a man gets into a fight 3,000 miles away from home, he *had* to have been looking for it. |
#40
![]() "Icebound" wrote in message ... "Dave Stadt" wrote in message . com... Nor does it matter if the plane was built before ARROW (whatever that means). He was wrong on all counts. ARROW are the current on-board-document rules: No, it is now AROW and has been since 1996. |
~ IS IT ILLEGAL TO REQUEST THAT SOMEONE > KILL BUSH< ? | B2431 | Military Aviation | 1 | September 20th 04 03:01 PM |
on US/UK illegal spying in UN SC | Matt Wiser | Military Aviation | 1 | February 17th 04 07:28 PM |
bushies file illegal flight plan | Gordon | Naval Aviation | 33 | January 13th 04 08:05 PM |
bushies file illegal flight plan | JamesF1110 | Naval Aviation | 1 | December 8th 03 12:06 AM |
40,000 U$ Soldiers are Illegal Aliens, Drafted for Illegal War | Gordon | Military Aviation | 6 | September 7th 03 03:28 AM |
