A Level 1 AOA clarification
Old December 28th 04, 03:56 AM
G.R. Patterson III
Hilton wrote:
I don't understand the first part (higher speed and climbing?) and the
second part is wrong.
If I leave the flaps at 0 degrees in my aircraft, bring the power back to
decelerate, and maintain level flight, she will stall at about 53 mph indicated.
The relative wind will be essentially horizontal, since that is the direction in
which the aircraft is actually traveling.
If I leave the flaps at 0 degrees, slow down to 60 mph indicated and raise the
nose enough to stall, the aircraft will be climbing just prior to the stall. The
relative wind will be "coming from above", since that is the direction in which
the aircraft is traveling.
George Patterson
The desire for safety stands against every great and noble enterprise.
  #32
Old December 28th 04, 05:21 AM
Greg Esres
Are you contradicting your previous comment: "Some studies I've seen
have shown that pilots are often oblivious to warning horns and
lights, though stick shakers are effective."?
No, the discussion has vacillated between AOA indicators and warnings;
there is more justification for improved warnings than for indicators
which won't be used.
BTW, I do agree that AOA indicator would be *useful* in the right
hands (precise short field landings, e.g.), but I don't think it will
make much of a dent int he stall/spin accidents.
I'd like to think it's a solvable problem, or at least reducable.
Planes that fly themselves? ;-)
  #33
Old December 28th 04, 05:37 AM
Greg Esres
The relative wind will be "coming from above", since that is the
direction in which the aircraft is traveling.
The relative wind doesn't ever "come from above" while the aircraft
has a positive angle of attack..by definition. ;-) Nor will the
aircraft stall with the relative wind "essentially horizontal."
Sounds like you think there is a zero angle of attack in that
situation? Cannot be true.
When not pulling a g-load, an aircraft climbs because the *flight
path* is inclined relative to the horizon; the AOA depends on the
chord line angle with the *flight path*.
If your level flight stall speed is 53 and you're stalling at 60,
you're probably achieving an accelerated stall.
The flight testing guys try to decelerate 1 knot per second; oddly,
decelerating at a greater rate produces a *lower* stall speed, which
must be normalized during the data processing. (I'm sure this only
occurs up to a point.)
  #34
Old December 28th 04, 06:31 AM
Hilton
decelerating at a greater rate produces a *lower* stall speed,...
Why?
Hilton
  #35
Old December 28th 04, 08:18 AM
Peter Duniho
"Greg Esres" wrote in message
I am sure that George means "coming from above relative to the horizon".
Which is a fine statement to make, IMHO. I do find it odd that you were
apparently unable to make this inference, given your next paragraph:
Yes, the flight path IS inclined relative to the horizon, and this causes
the relative wind to also become inclined relative to the horizon.
Yes, he certainly is, and he said as much.
Pete
  #36
Old December 28th 04, 12:02 PM
CV
George Patterson
I think I see a lot of confusion happening in this thread due to
the use of fuzzy and unnecessary concepts like "relative wind",
"pitch angle", "from above" and a couple of others.
Angle of Attack is simply the angle at which the airflow meets
the wing. There is no need to complicate matters by calling the
airflow "relative", especially as some posters seem to be confused
about what is _relative_ to what.
If we must use "relative" then it would be better to say exactly
what we mean "relative to the wing/aircraft" or "in relation to
the wing/aircraft", but as this is the only relation that makes
sense when discussing AOA it shouldn't be necessary to mention
it at all.
And "wind" is positively misleading as it makes you think of
movement of an airmass in relation to the ground. "From above"
is similarly meaningless, unless we specify whether we mean it
in relation to the wing/aircraft or the horizon.
Cheers CV
  #37
Old December 28th 04, 04:42 PM
Greg Esres
horizon". Which is a fine statement to make, IMHO. I do find it odd
that you were apparently unable to make this inference, given your
next paragraph:
That is possibly what he meant, but I think you're trying to interpret
what he said in light of your own understanding. That's a common
mistake that instructors make and it hides the fact that the student
really *doesn't* understand.
Odd words or phrases used to explain something can often give a clue
that the mental model is wrong. This "relative wind coming from
above" sets my detectors going off. Where the relative wind is coming
from relative to the horizon is irrelevant.
[an accelerated stall.] Yes, he certainly is, and he said as
much.
Where?
  #38
Old December 28th 04, 04:46 PM
Greg Esres
Why?
I don't know. None of the books explain it. They just descibe
methods of correcting for it. (Test pilots seem the practical sort,
rather than theoretical.)
My suspicion is that it's due to the "dynamic stall" concept. When an
aircraft is rotated rapidly to a high AOA, it can generate a much
higher lift coefficient than steady state. Apparently it takes some
finite amount of time for the adverse pressure gradients to do their
magic and cause the airflow to separate.
  #39
Old December 28th 04, 05:02 PM
Greg Esres
it at all.
That's why it's almost impossible to discuss a subject meaningfully
with someone unless he has the basic vocabulary down. For the CFIs I
have taught, my first step is have them read an entry-level
aerodynamics book. Much of our discussions after that is making sure
they use the correct words and have a clear idea of what they mean.
Words like "pitch", "angle of attack", and "climb angle" all have
different meanings, but the distinction is so fuzzy in most pilots'
minds that it's no wonder that people get confused.
Now, "relative wind" is a standard aerodynamics term and is as
ordinary to me as the word "chair". Surely all pilots understand what
relative wind is?
Yes, "wind" probably isn't the ideal word to use; vast numbers of
pilots out there still think that the motion of the airmass relative
to the ground affects the aerodynamics of the aircraft, and it's very
difficult to rid them of that notion.
  #40
Old December 28th 04, 09:42 PM
David CL Francis
On Tue, 28 Dec 2004 at 03:56:41 in message
, G.R. Patterson III
I think the question here is "Above What?" If the aircraft is flying
then the relative wind will be coming from a direction in which the
velocity vector of the aircraft is pointing (assuming we are talking
still air).
But it will not be coming from "above the aircraft". A normal angle of
attack sufficient to satisfy the required lift vector must still exist.
The lift required when climbing is normally somewhat less than that
required in steady horizontal flight.
David CL Francis
PIREP--CO Experts low level carbon monoxide detector Jay Honeck Piloting 10 December 3rd 04 11:21 AM
What's minimum safe O2 level? PaulH Piloting 29 November 9th 04 07:35 PM
Altimeter setting != Sea Level Pressure - Why? JT Wright Piloting 5 April 5th 04 01:04 AM
The Internet public meeting on National Air Tour Standards begins Feb. 23 at 9 a.m. Larry Dighera Piloting 0 February 22nd 04 03:58 PM
flight level in Flight simulator Robert Piloting 3 August 20th 03 07:37 PM
