#31
Andrew Sarangan wrote
I would not recommend stick & rudder. John Denker's online book is much better. Stick & rudder is very old, and a lot of things presented there as 'revolutionary ideas' have been well known for many years. It gets dry pretty fast. I completely concur. Bob Moore |
#32
in any case.... the reference is always to nautical.. in this day and age..
BT "Ron Garret" wrote in message ... In article SL5Bd.2351$232.844@fed1read05, "BTIZ" wrote: 5. When pilots use miles in conversations, does it mean the miles we normally use, or is it always nautical miles? It's supposed to be always nautical, but distance estimates are often wrong by more than 10%, which is the different between nautical and statute miles, so it often doesn't really matter. how can that be.. a distance is a distance.. who said anything about "estimates".. If I measure 10nm then it is 10nm.. if my DME says I'm x miles from station y, then that's where I am... there is no 10% error.. Read the question again: "When pilots use miles in conversations..." When a pilot says, "Five miles from the field" the actual physical distance is never exactly five miles. Even when your DME says x miles from station y that is *not* where you are. At best, it is the slant-line distance, and at worst it's a completely arbitrary number because your DME could be kerfliggered. Furthermore, a VORTAC is more or less a point, but an airport isn't. A typical airport is many tenths of miles (of either flavor) long/wide. You'd have to pick an arbitrary point on the field and measure your distance to that. What do you pick? The tower? What if there is no tower? The middle of the runway? What if there's more than one runway? The end of the runway? Which end? So you see, the actual physical distance from your airplane to an airport is not even well defined. So when a pilot says "I'm five miles from the field" what he really means is "I'm somewhere in the vicinity of five miles" at which point it doesn't much matter what kind of miles are meant. rg |
#33
In article FviBd.3074$232.1342@fed1read05,
"BTIZ" wrote: in any case.... the reference is always to nautical.. in this day and age.. Not quite. The correct answer is the one I originally gave: It's supposed to be always nautical... Whether the reference actually *is* to nautical or not (and, somewhat orthogonally, whether this number actually has any relation to physical reality) depends on whether the pilot knows what they're doing. But, again, the vast majority of the time it doesn't matter. rg |
#34
"Dudley Henriques" wrote in message
nk.net... I have a question for you, after watching these endless series of questions, and it's not meant to be hostile in any way; just curious. The questions you ask on these groups are quite complex, and require substantial effort to answer by the returning posters. I can't speak for the rest of the group, but I for one have avoided you because the questions you are asking are readily available in books and manuals that you can purchase easily if you take the time and effort to do so. Hi Dudley, I think part of the problem is that if I read it correctly, Ramapriya is in India...it's an Indian name and his sig used to say vsnl which is an Indian ISP. It may not be quite so easy as to go along to his local FBO or hang out at the local flying club, as this may be hundreds of miles away. Maybe someone could suggest some links on the net that he could look up to do some reading on the subject of airliner flights and how they compare to private flights and perhaps recommend some ground study material for the various questions one is likely to come across, either on the net or as books he can purchase from Amazon or somewhere. I could suggest that a lot of the questions would be covered by the groundschool course for the FAA PPL? Cheers, Paul (UK) |
#35
![]() "Paul Sengupta" wrote in message ... "Dudley Henriques" wrote in message nk.net... I have a question for you, after watching these endless series of questions, and it's not meant to be hostile in any way; just curious. The questions you ask on these groups are quite complex, and require substantial effort to answer by the returning posters. I can't speak for the rest of the group, but I for one have avoided you because the questions you are asking are readily available in books and manuals that you can purchase easily if you take the time and effort to do so. Hi Dudley, I think part of the problem is that if I read it correctly, Ramapriya is in India...it's an Indian name and his sig used to say vsnl which is an Indian ISP. It may not be quite so easy as to go along to his local FBO or hang out at the local flying club, as this may be hundreds of miles away. Maybe someone could suggest some links on the net that he could look up to do some reading on the subject of airliner flights and how they compare to private flights and perhaps recommend some ground study material for the various questions one is likely to come across, either on the net or as books he can purchase from Amazon or somewhere. I could suggest that a lot of the questions would be covered by the groundschool course for the FAA PPL? Cheers, Paul (UK) If this is true, that would be a perfectly reasonable explanation and a workable scenario for a newsgroup "quiz quest" I'll have to admit. It would really have helped his approach, assuming something like this is the case, had he mentioned this up front. Actually, since all of what he wants to know has already been printed, and much of it is available on the net, my option would still be to point him to the correct links rather than sit down and type out all these complicated answers; not to mention the usual Usenet confusion between the answers being offered by various posters :-) Because this poster has been so respectful to everyone, I tried my best not to seem hostile when I posted to him. I'm fairly sure his intent hasn't been to put anyone out. These kinds of posts have always posed a problem for me. On one hand, you want to try and help people. Actually, that's why most of us post here to begin with. I know over on the student group I always shy away from answering posts from students asking questions their instructors should be answering for them like, " I'm having trouble with my flare. What am I doing wrong?" Over here on "piloting", it's the "laundry list" post that I try and avoid for basically the same reason. There are available sources already in place that can deal directly with the issues being asked about. Rather than answer something like "how does a VOR work?", I've always felt it better to give a link to a competent source of that information for the poster rather than sit down at the keyboard and type out a meaningful and accurate explanation on how a VOR functions. It's just me I guess, but to me it makes sense that way. If, on the other hand, a poster asks a specific question that can be answered directly and without a lot of unnecessary typing, I'll post on it. I think in retrospect, that you might be right about this poster's location. Perhaps if he changes that "laundry list" approach a bit and addresses things one at a time, he'll have a much improved and more enthusiastic response on the groups. Dudley Henriques International Fighter Pilots Fellowship Commercial Pilot/CFI Retired for private email; make necessary changes between ( ) dhenriques(at)(delete all this)earthlink(dot)net |
#36
![]() "Dudley Henriques" wrote I think in retrospect, that you might be right about this poster's location. Perhaps if he changes that "laundry list" approach a bit and addresses things one at a time, he'll have a much improved and more enthusiastic response on the groups. Dudley Henriques He has posted this information before, about where he lives, but I forgot. He travels out of his country for work quite a bit, and basically, is all alone at night with his computer for company. Interest, and free time to post, and... g I agree, about the laundry list. One question to respond to is doable. 2, ok. 6 or 8, no way that many are going to take the time. -- Jim in NC |
#37
![]() "Morgans" wrote in message ... "Dudley Henriques" wrote I think in retrospect, that you might be right about this poster's location. Perhaps if he changes that "laundry list" approach a bit and addresses things one at a time, he'll have a much improved and more enthusiastic response on the groups. Dudley Henriques He has posted this information before, about where he lives, but I forgot. He travels out of his country for work quite a bit, and basically, is all alone at night with his computer for company. Interest, and free time to post, and... g I agree, about the laundry list. One question to respond to is doable. 2, ok. 6 or 8, no way that many are going to take the time. -- Jim in NC I think if in the future he simply tackles them one at a time, he'll have much better general response as we're saying. He was lucky he ran into a couple of the regulars this time out who felt like dealing with the "list", but for a general rule, the simple, non complicated approach is better for him I think. Have a great new year, Dudley |
#38
![]() Dudley Henriques wrote: If this is true, that would be a perfectly reasonable explanation and a workable scenario for a newsgroup "quiz quest" I'll have to admit. It would really have helped his approach, assuming something like this is the case, had he mentioned this up front. He did. Long ago. George Patterson The desire for safety stands against every great and noble enterprise. |
#39
![]() "G.R. Patterson III" wrote in message ... Dudley Henriques wrote: If this is true, that would be a perfectly reasonable explanation and a workable scenario for a newsgroup "quiz quest" I'll have to admit. It would really have helped his approach, assuming something like this is the case, had he mentioned this up front. He did. Long ago. That's fine, but with "laundry list" posts, it might be advisable that people posting them mention these things more than "long ago" so that those who might have missed that "long ago" post are aware of it. Dudley Henriques International Fighter Pilots Fellowship Commercial Pilot/CFI Retired for private email; make necessary changes between ( ) dhenriques(at)(delete all this)earthlink(dot)net |
Introduction to a newbie | Shane O | Aerobatics | 9 | December 31st 04 06:13 AM |
Questions from a newbie. | Andrew Tubbiolo | Home Built | 9 | September 14th 04 01:40 AM |
Newbie question on Rate of Climb | Wright1902Glider | Home Built | 0 | August 17th 04 03:48 PM |
Newbie questions Rail / Ejector launchers | AL | Military Aviation | 19 | November 14th 03 07:47 PM |
Basic Stupid Newbie Questions... | John Penta | Military Aviation | 5 | September 19th 03 05:23 PM |
