Jay has a mpg on his site of a SuperCub landing extremely short. It's worth
a look. http://www.alexisparkinn.com/photoga...perCubLand.mpg Jim wrote in message oups.com... Z Think about it....the airplane cares not about the wind...only how fast its going thru the air! If you have the aircraft slowed to say 40 IAS regardless of how you arrived at that steady speed, and you have a 40kt wind blowing, you can literally hover over one spot. If you continue to descend using power for your altitude control, you should be able to maneuver the aircraft to the desired touchdown spot, reduce the power and touchdown with no forward roll or drama. How else can you make a really REALLY short field landing unless a wind is blowing? I enjoy flying a 180 slip to a touchdown on a spot from abeam in the pattern. Lots of fun and good practice. I get a lot of satisfaction doing it in a Stearman in particular. I've won a lot of wagers doing the no hands landings usually in the C-172 with judicious use of power and trim for pitch, and of course rudder for directional. That too is rather simple once you have been in the airplane to see how it's done. Thanks and Cheers Ol Shy & Bashful |
![]() "zatatime" wrote in message ... On 14 Jan 2005 21:31:49 -0800, wrote: What is fun is using that same set of conditions, and landing with virtually zero ground roll. I've won more than a few beers that I could land and stop short within the wingspan of the airplane (C150-172). Selway Kid Care to elaborate? I've not pushed that far into the envelop, especially close to the ground, and would think a 150 wouldn't have enough power to hang on the prop without a high descent rate. You are not hanging on the prop, you are opposing the headwind. It all depends on where you are in the drag bucket. If the wind was strong enough, you could 'cruise' backwards... I did get to be in the plane (J-3) once with one of the people I most respect in aviation (and know personally) where from 2000 feet, he entered a slip, asked me where I wanted the plane, and flew - in the slip, and I swear below stall speed - all the way to the ground and put the plane right on the mark I asked for. It was one of the most amazing demonstrations of flying I'd ever seen....Even better than his no hands landings. I only offer the story thinking perhaps you're technique is somewhat similar. TIA for any response. z Nose into the Santa Anna winds out in California, blowing at 45 at least. Full flaps and a C-150. It is fun to try and do a turn around a point, staying at 2500 agl or so. |
On Sat, 15 Jan 2005 18:31:42 GMT, zatatime wrote:
asked me where I wanted the plane, and flew - in the slip, and I swear below stall speed Nice story. Yesterday I flew the Cub after a four-week layoff (weather) so worked on t.o. & landings. For some reason I was always high / close-in on final, so I did a lot of slipping. Indeed, I had the feeling that I controlled the plane in all three dimensions, and could have planted it anywhere within a 200-foot square at the south end of the runway. And I was starting from say 600 feet. -- all the best, Dan Ford email (put Cubdriver in subject line) Warbird's Forum: www.warbirdforum.com Piper Cub Forum: www.pipercubforum.com the blog: www.danford.net |
In a similar vein, I've got a mate who, when the wind is high enough and
from the right direction, will land our Taylorcaft ACROSS the runway. He often has enough room to take back off again from the same point without reversing. Mind you, the Tcraft stalls at about 35 mph. Shawn wrote in message oups.com... What is fun is using that same set of conditions, and landing with virtually zero ground roll. I've won more than a few beers that I could land and stop short within the wingspan of the airplane (C150-172). Selway Kid |
![]() "ShawnD2112" wrote in message . uk... In a similar vein, I've got a mate who, when the wind is high enough and from the right direction, will land our Taylorcaft ACROSS the runway. He often has enough room to take back off again from the same point without reversing. Mind you, the Tcraft stalls at about 35 mph. That runway is really short....yea, but it is also really, really wide! |
![]() "ShawnD2112" wrote in message . uk... In a similar vein, I've got a mate who, when the wind is high enough and from the right direction, will land our Taylorcaft ACROSS the runway. He often has enough room to take back off again from the same point without reversing. Mind you, the Tcraft stalls at about 35 mph. So what does his pattern look like? Missing one leg, or adding a buttonhook turn? -- Jim in NC |
I think when you're doing those kinds of things you're not really working a
standard pattern. Mind you, he's very careful about what other traffic is in the area. We used to do a competition on really quiet summer evenings when the wind dropped to near-zero and there wasn't a soul around but us. Our airport has 10 runways (3 hard, 2 grass, both ways) and we used to see how fast we could touch and go on all 10. I think we got it down to about 2 mins. Now that was great fun!! Shawn "Morgans" wrote in message ... "ShawnD2112" wrote in message . uk... In a similar vein, I've got a mate who, when the wind is high enough and from the right direction, will land our Taylorcaft ACROSS the runway. He often has enough room to take back off again from the same point without reversing. Mind you, the Tcraft stalls at about 35 mph. So what does his pattern look like? Missing one leg, or adding a buttonhook turn? -- Jim in NC |
![]() wrote in message oups.com... Have you ever really taken your aircraft to the bottom edges of its flight ability and airspeed, and flown it with any degree of precision and of more than just a few moments/minutes? I had my CFI run through slow flight with me about 2 weeks ago at night. Made turns with the rudder only at the slowest point, since the ailerons were way too mushy. Also worked at lifting falling wings with opposite rudder at stall break. I agree with you about this being important and that's why I asked my CFI to work with me on slow flight and stalls. One thing though, it has been my personal rule to only practice stalls with an instructor on board. I feel that is reasonable since I am not trained in spin recovery. I'd be interested in other's opinions on this. On the subject of "seat of the pants", the first time I flew with my present instructor, he had me fly patterns without an airspeed indicator. I was extremely nervous because my primary instructors never did this while I trained for my private ticket. I found that it was a truly liberating experience and as a result, I generally fly patterns by feel now. -Trent PP-ASEL |
![]() "Trent Moorehead" wrote in message ... wrote in message oups.com... One thing though, it has been my personal rule to only practice stalls with an instructor on board. I feel that is reasonable since I am not trained in spin recovery. I'd be interested in other's opinions on this. Trent, If you don't think you could recover from a spin, I would highly recommend that you get some spin training, and read up on the spin recovery techniques for your particular aircraft. A spin can happen any time the airplane gets away from you (not just doing stalls), and knowing how to react is rather important. Besides, they're an absoloute blast. :-) Happy flying. -Rob |
Interesting. Life history of John Lear (Bill's son) | Big John | Piloting | 7 | September 20th 04 05:24 PM |
Interesting Resume (V Long) | Bob Chilcoat | Piloting | 24 | September 13th 04 06:44 AM |
Ultralight Club Bylaws - Warning Long Post | MrHabilis | Home Built | 0 | June 11th 04 05:07 PM |
Mountain flying instruction: McCall, Idaho, Colorado too! | [email protected] | General Aviation | 0 | March 26th 04 11:24 PM |
FA: WEATHER FLYING: A PRACTICAL BOOK ON FLYING | The Ink Company | Aviation Marketplace | 0 | November 5th 03 12:07 AM |
