![]() "Morgans" wrote in message ... "mindenpilot" wrote It seems that we have identified about five areas to focus on: 1. propulsion (caged prop, pusher prop, ducted fan) 2. ground handling 3. tires 4. brakes 5. acceleration I'll have to think about each of these a bit before trying to attempt possible solutions, but now I have some things to think about. Adam Eliminate the moving prop, as thrust for ground propulsion. Doing so will solve the acceleration problem. The dust it would throw up will make it very unpopular, if not outlawed. The guard would have to have bars close enough together to keep even a finger from getting into it, and most likely even hair. I don't have my OSHA book with me, but I'm certain the regs on the guard are very restrictive, and will keep the prop from being used on the ground. *If* you got around the problems of using the prop on the ground, the airflow restriction would be high enough to make it unusable for air propulsion. -- Jim in NC Again, you're right. Some of the more feasible designs I've seen use a secondary method of propulsion while on the ground. This seems to be the way to go. You're starting to sound like a believer ;-) Adam N7966L Beech Super III |
![]() "mindenpilot" wrote Again, you're right. Some of the more feasible designs I've seen use a secondary method of propulsion while on the ground. This seems to be the way to go. You're starting to sound like a believer ;-) Adam Nope. Once you are headed down the only road to do it, you will start to understand the huge obsticales in your way. The weight to make it road worthy will kill its chances of flying well. (or at all) -- Jim in NC |
Morgans wrote:
Eliminate the moving prop, as thrust for ground propulsion. Doing so will solve the acceleration problem. The dust it would throw up will make it very unpopular, if not outlawed. The guard would have to have bars close enough together to keep even a finger from getting into it, and most likely even hair. I don't know, if you were to go the ducted fan route you could have the inlet and outlet of the duct far enough from the prop that the guard wouldn't have to be all that restrictive and it could be easily removed for flight. Also the ducted fan would provide more thrust for the same horsepower if I'm not mistaken. If it is a constant speed fan, I bet you could get acceptable acceleration out of it. However the dust it would throw up and noise would probably be big down side. You may be able to minimize the dust problem by mounting the fan high on the vehicle. But the noise would be pretty bad still. I really don't like the idea of having 2 power plants but if you are going to drive the wheels I don't see that there is a practical alternative.... or wait.... maybe hydrostatic drive off the same drive shaft as the prop. A lot of research is going into hydrostatic transmissions these days. The can be pretty compact but are generally heavy. Since you only want around town slow driving capability, maybe a compact light weight engine with low gearing would fit the bill. If you could make some use of that power plant during flight, so it wasn't completely dead weight that would be nice..... maybe have it drive all the engine accessories for flight and ground use. -- Chris W Gift Giving Made Easy Get the gifts you want & give the gifts they want http://thewishzone.com "They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." -- Benjamin Franklin, 1759 Historical Review of Pennsylvania |
On Mon, 7 Feb 2005 18:51:59 -0800, "mindenpilot"
wrote: It seems that we have identified about five areas to focus on: 1. propulsion (caged prop, pusher prop, ducted fan) 2. ground handling 3. tires 4. brakes 5. acceleration Like others, I don't think using the prop for ground propulsion makes sense. Too much danger in FOD, not to mention the noise factor and the prop blast. Some kind of declutchable drive should be used and a transmission. But this requires a driveshaft and differential as well, unless some kind of engine driven generator is used to drive perhaps on wheel with the rest of them non driven. This brings up the possibility of a three wheeled vehical with the driven wheel being the single wheel. It eliminates the need for the differential, thus saving weight. But you'll still need some sort of transmission. Corky Scott |
On Sun, 6 Feb 2005 19:25:59 -0800, "mindenpilot"
wrote: OK, you have to humor me on this. I'm not talking about anything unrealistic (like Moller's skycar, etc). But what would prevent a design (even low performance/ultra light to start) that would allow a pilot to fly into an airport, then fold up his wings and cruise down surface streets at 45mph? Here is a website describing Moult Taylors Aerocar as well as other types. http://www.fiddlersgreen.net/aircraf.../info/info.htm Corky Scott |
Here's something like what you are looking for--a roadable vehicle that
can fly. It is a parachute conversion for a Honda Reflex motorcycle. http://www.ultralightnews.com/airven.../flitebike.htm |
![]() "Hank Rausch" wrote in message oups.com... Here's something like what you are looking for--a roadable vehicle that can fly. It is a parachute conversion for a Honda Reflex motorcycle. http://www.ultralightnews.com/airven.../flitebike.htm Except he could easily do the trip twice as fast in a car, as with a parachute and motorcycle. The wind limitations of a powered chute could eliminate 50% or more of the days that would otherwise be flyable. -- Jim in NC |
![]() "Morgans" wrote in message ... "Hank Rausch" wrote in message oups.com... Here's something like what you are looking for--a roadable vehicle that can fly. It is a parachute conversion for a Honda Reflex motorcycle. http://www.ultralightnews.com/airven.../flitebike.htm Except he could easily do the trip twice as fast in a car, as with a parachute and motorcycle. The wind limitations of a powered chute could eliminate 50% or more of the days that would otherwise be flyable. -- Jim in NC That is absolutely true. However, it won't stop one person who actually *wants* to do it. How else could you explain people who pay money to glide, or do hang-glide, etc. Even though this technology is not what I was envisioning, it's a start, and it may or may not evolve. If someone came up with some extremely inefficient vehicle that does what I've proposed, *I* would probably try it. And, it would probably be improved upon as time went on. This is a LOOONG way from not being possible. Adam N7966L Beech Super III |
I bet more than one reader of this group (maybe the homebuilt group)
could hack something together in no time. It would then be reasonably easy to get it certified as experimental. What about certified to drive on the road? Keep in mind the golf carts that are road legal... I've been in the homebuilding world since 1973 and can think of a half-dozen attempts to build a roadable car. NONE of them were worth pursuing. They were heavy, flew rather poorly and most were rotten as cars. Some of them killed their designers. The added mechanism to gear an engine to wheels adds a lot of weight any way you look at it, and the engine, if it's aircooled, has to have a fan. More weight. The cumbersome wings and tail take time to remove and install, and a simple mistake in assembly can kill. There was one, a delta sort of layout, that had folding wings that bent twice and shielded the pusher prop. More heavy mechanisms. IIRC the designer couldn't get any road licensing with that prop driving the "car." Too dangerous. Imagine the reaction of an insurance company! Another one, a Ford Pinto married to the aft section of a Cessna 337, actually flew. The airplane section was unbolted and left at the airport while the car ran around town. The whole thing was too heavy, and one day the car fell off in flight. End of experiment. People with big ideas about building flying cars should do their research and learn a lot before trying to persuade someone that it's easy. There have been many mistakes make and the ignorant will only make them again. The simple fact is that airplanes are meant to fly and cars are meant to drive, and because of the technological requirements the two don't fit together well in one machine at all. Dan |
This one has been solved. Dedicated equipment is the best and most
convenient. I have enough trouble getting an airplane, however a rental car is pretty easy. If you are just commuting, leave a beater at the airport. I would start with a backpack powered parachute and a bicycle and work your way up. Stuart mindenpilot wrote: OK, you have to humor me on this. I'm not talking about anything unrealistic (like Moller's skycar, etc). But what would prevent a design (even low performance/ultra light to start) that would allow a pilot to fly into an airport, then fold up his wings and cruise down surface streets at 45mph? It doesn't sound that complex. I bet a homebuilder could do it with parts laying around his garage. The only serious issue I can think of is having a spinning prop on a city street. Even so, couldn't you "disengage" the prop and then couple the engine to the mains somehow? I realize that is a bit more complex and would mean some kind of transmission. I'm just throwing out ideas here. It sure would be nice not to rent a car or get a taxi! It also seems that there would be a MUCH larger interest in GA if people could potentially commute this way. For example, I would consider working in Reno and living in Minden if I could fly into Reno, then commute to my work. I'm serious about this, but I'm ready for the flames ;-) Adam N7966L Beech Super III |
VP-II wings available in Oregon, USA (Or, "How I was coconuted...") | Roberto Waltman | Home Built | 2 | October 29th 04 04:21 PM |
Charging for Wings safety seminar? | Marty Shapiro | Piloting | 19 | June 23rd 04 05:28 PM |
Stolen "Champ" wings located...from 23,000 feet!! | Tom Pappano | Piloting | 17 | December 15th 03 01:24 PM |
Wings from "Champ" stolen in Oklahoma after emergency landing | Tom Pappano | Piloting | 1 | December 7th 03 05:02 AM |
Folding Wings on a Sonerai II | JR | Home Built | 2 | September 18th 03 12:33 AM |
