I thought I'd share a story with you. I have posted a few things here, and
really enjoyed the information that people share on these groups. Some background: I'm currently working on my ME rating, and was out with my instructor polishing up some maneuvers. I have about 12 to 14 hours in a Seminole, and have been working on a VFR ME rating (the IFR ME rating will be later). So yesterday, my instructor and I headed out on a really nice Pacific NW day (decent ceilings, great visibility and temps in the 40s at the surface). We were planning on doing a few maneuvers, a Vmc demo or two, single engine failure procedures, etc. We also planned on practicing simulated engine failures in the pattern. All of this was to get ready for my upcoming ME check ride. I completed the pre-flight, and we didn't have any issues on run up. All systems appeared normal, and working great. On our take-off roll, we got an alternator warning. We aborted the take off, ran through the check lists, reset the alternator, and the problem seemed to go away. (The alternator problem was not our problem later on, and is probably not even related to the problem we encountered). So we finally got going, headed out to a practice area and began our maneuvers. Everything was going fairly well, Vmcs looked decent, engine failure procedures were looking better, etc. We were close to the airport we were planning on doing pattern work, but we were above 5000AGL, so my instructor asked me to do an emergency decent. For those unfamiliar with it, the procedure is to bring the gear down, throttles to idle, props full forward, and start a 45 deg descending turn while maintaining around 140kts. I extended the gear (below the required 140), started to see the lights turning green, and started the procedure. The lights normally all light within a second of each other. Both the instructor and I notice the right main light was not lit. We stopped the emergency decent, and reconfigured to retract the gear. After a couple of attempts to cycle the gear, and swap gear light bulbs, we determined that indeed, we were not getting a positive lock indication on the right main gear. We even tried the emergency gear extension, with the same results. So at this point, we decided to head back to our home field and get some help.While heading back we are both trying to figure out what might be causing the problem. We are both thinking it might be as simple as the gear lock switch, or as complicated as a gear stuck in transit. The tower at Boeing Field allowed us to do a fly by, and was able to tell us that the gear was down. They of course couldn't determine if it was locked or not, but at least we know that it seems to be extending. We then left the airport and headed out west to do more troubleshooting, and to call our FBO mechanics. While I am flying a small circuit over the Olympic Peninsula, my instructor talked on his cell phone to the FBO's maintenance gang. We tried a bunch of variables. Extending the gear while in a turn, pulling circuit breakers to reset the system then extending it, you name it, we tried it. We spent over an hour trying to sort it out. Finally we arrived at the point were we've burned off some of our extra fuel (now we only have around 20 gals/ side) and our daylight is beginning to go. We decide that the problem can't be fixed from inside the cockpit, and we'll just have to hope that the issue is just the lock switch. Remarkably both my instructor an I stayed pretty calm about the whole thing. We get set up for our upcoming emergency landing by discussing who will do what if the gear collapses (since he is flying, he would cut the mixtures, I'd get the fuel shut-offs, mags, alts, and master). We remove our knee boards, remove the decorative "emergency exit" handle cover, and locate the fire extinguisher. We did one more fly by of the tower, and they once again confirmed that the gear was down. We went around again, declared our emergency, waited for a 767 to land, and went in. The Boeing Field fire department was ready and waiting, which re-assured us if the worst happened, they would be there in seconds. The landing went extremely well. My instructor managed to hold the plane at stall, and set it down as gently as was possible on the left gear first. Lucky for us the right gear was locked, or at least held long enough for us to land, taxi off the runway, and park. (Last time I checked the airplane is in for determination of the problem). It was an excellent learning experience, with the best outcome imaginable. I know more about the Seminole's landing gear than I ever did before. I also learned that keeping a cool head during a potential emergency will let you clearly think about problems and most importantly-- keep flying the plane. It can be distracting troubleshooting, flying and talking on the radio at once. Keeping things in perspective and working as a team helped keep everything manageable. The FBO's maintenance guys, the Boeing Fire department and the Boeing tower also were key in keeping things manageable and as safe as possible. I definitely have to say, it was one of my most useful flights. Len PPSEL, working on that ME. |
reading stuff like yours is why i do the net groups. thanks for posting
that. would there have been any sense to "bumping" it on the runway?? planning not to put all the weight on it and just kinda bumping it then pulling up to do another circuit with whatever new info you just gained?? dan....oh, by the way...sounds like y'all did just right. |
houstondan wrote:
reading stuff like yours is why i do the net groups. thanks for posting that. would there have been any sense to "bumping" it on the runway?? planning not to put all the weight on it and just kinda bumping it then pulling up to do another circuit with whatever new info you just gained?? And what would that tell you. Frankly, unless there's something dangerous (like something in the way on the runway), it's probably safer to continue the landing and take the possible collapse. A gingerly executed landing is going to be better than bumping things and taking off... I've seen a plane land without the nosegear and I've seen one land without one of the mains. While the first yielded a bunch of sparks and the second caused the plane to go off into the dirt, both pilots walked away uninjured and without too much damange to the plane either. |
![]() "Ron Natalie" wrote in message m... houstondan wrote: reading stuff like yours is why i do the net groups. thanks for posting that. would there have been any sense to "bumping" it on the runway?? planning not to put all the weight on it and just kinda bumping it then pulling up to do another circuit with whatever new info you just gained?? And what would that tell you. Frankly, unless there's something dangerous (like something in the way on the runway), it's probably safer to continue the landing and take the possible collapse. A gingerly executed landing is going to be better than bumping things and taking off... I've seen a plane land without the nosegear and I've seen one land without one of the mains. While the first yielded a bunch of sparks and the second caused the plane to go off into the dirt, both pilots walked away uninjured and without too much damange to the plane either. Half-way through the post, I thought Len was involved in this (with video): http://www.firstcoastnews.com/news/u...?storyid=32215 from a day or so ago. Pretty standard 1-main-up landing. |
![]() "Icebound" wrote in message ... "Ron Natalie" wrote in message m... houstondan wrote: reading stuff like yours is why i do the net groups. thanks for posting that. would there have been any sense to "bumping" it on the runway?? planning not to put all the weight on it and just kinda bumping it then pulling up to do another circuit with whatever new info you just gained?? And what would that tell you. Frankly, unless there's something dangerous (like something in the way on the runway), it's probably safer to continue the landing and take the possible collapse. A gingerly executed landing is going to be better than bumping things and taking off... I've seen a plane land without the nosegear and I've seen one land without one of the mains. While the first yielded a bunch of sparks and the second caused the plane to go off into the dirt, both pilots walked away uninjured and without too much damange to the plane either. Half-way through the post, I thought Len was involved in this (with video): http://www.firstcoastnews.com/news/u...?storyid=32215 from a day or so ago. Pretty standard 1-main-up landing. Reminds me of the C-310 with the nose wheel unlocked. The guy did a number of flybys that confirmed that it was down but not locked; it was just dangling there. They went off and tried 60° bank turns and other things to try and flick it down, but no luck. They finally came in to land, a little hot, shut down the engines in the flair, sorta bounced it, and the nose wheel flicked out, looked like it might stay, but then folded back. The nose settled down on the runway and wore off a patch of aluminum maybe one foot long. Very minimal damage to the plane... |
![]() "Ron Natalie" wrote And what would that tell you. Frankly, unless there's something dangerous (like something in the way on the runway), it's probably safer to continue the landing and take the possible collapse. I would have to agree with you on that one. Bumping it may cause an unlocked gear to become even "less locked", then collapse, the next time you put the weight on it. On the other hand, a real greaser may not put enough strain on the gear to cause the same unlocked gear to fold on you. -- Jim in NC |
This is what I like about pilots. After an experience like this, 97% of the population would be screaming "Never again!" -- and would probably never set foot on an airport again. Pilots, on the other hand, just say "Hmmm...that was a valuable learning experience..." Great story -- thanks for sharing it! -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Jay Honeck wrote:
I definitely have to say, it was one of my most useful flights. This is what I like about pilots. After an experience like this, 97% of the population would be screaming "Never again!" -- and would probably never set foot on an airport again. Pilots, on the other hand, just say "Hmmm...that was a valuable learning experience..." Great story -- thanks for sharing it! Interesting observation, Jay. I think you are correct about that. Pilots have a different perspective on taking risks, and are more analytical than emotional about accident reports. Perhaps that's a trait that led us to become pilots, or perhaps the additional knowledge we share gives us more information to analyze. So, are pilots also correspondingly analytical and unemotional when faced with accident reports from outside aviation? Say, a boating accident, or a farm-tractor accident, or a fill in the activity accident? Just musing, when I'm supposed to be working. :-) |
![]() Dave Butler wrote: Interesting observation, Jay. I think you are correct about that. Pilots have a different perspective on taking risks, and are more analytical than emotional about accident reports. Perhaps that's a trait that led us to become pilots, or perhaps the additional knowledge we share gives us more information to analyze. I think that's applicable to anyone that bothers to analyze the risks associated with a particular endeavor (for example motorcycling, skydiving and skiing). That said, Jay has a point. Of the people I've encountered in those particular activities, there is a large percentage that do not bother to consider all of the risks and take an "it won't happen to me" approach. Those are the ones that say, "Never again!" after a mishap. The rest (a minority, in my opinion) just chalk it up as a valuable learning experience. I know several former pilots that hung up their wings after a particularly frightening experience. They gained a sudden realization of the risks involved with their activity and weren't prepared to deal with it. John Galban=====N4BQ (PA28-180) |
particularly frightening experience. They gained a sudden realization of the risks involved with their activity and weren't prepared to deal with it. It's even more common with family of pilots. I know a particularly egregious example. A good friend of mine used to own a C-177RG. He geared it up. Of course it wasn't his fault. My friend bought the plane used. The plane had hydraulic hoses that were original (25 years old) and he instructed his A&P/IA to replace them at annual. The guy didn't, and he also didn't tell my friend that he didn't. A few months later, one of them burst. In the Cessna system, once a hose bursts you're done. The manual extension only provides a backup for the pump. My friend did all the right things. He tried to get the gear down by the emergency extension procedure, shking the plane, etc. He diverted to a major airport with emergency services. He made a flyby to confirm gear state. He flew off most (but not all) of his fuel. He killed the engine in the flare, over the runway. He made a perfect minimum-energy landing and kept the wings level far into the roll. The emergency crews actually applauded, it was so letter-perfect. My friend's wife wouldn't fly with him after that. She gained a sudden realization of the risks involved. My friend sold the Cardinal and bought a Bonanza. He won't let the same A&P/IA work on it anymore, and has begun to do much of his own work, having learned that you can't trust a shop. He has had years of incident-free flying. It's a MAJOR challenge to get his wife into the airplane. Michael |
Flashing green | Robert M. Gary | Piloting | 30 | June 23rd 11 01:57 AM |
new cleaning product: Simple Green for aircraft | [email protected] | Owning | 19 | February 17th 05 06:15 AM |
Advice Wanted: Flying to Green Bay for a Packer Game | Jay Honeck | Piloting | 12 | August 14th 04 03:54 AM |
Green Hills Software Powers Next Generation of Military Unmanned . | Otis Willie | Military Aviation | 0 | July 20th 04 12:34 AM |
Photos of a GREEN F-117 in Palmdale, taken Jan 04 | Wings Of Fury | Military Aviation | 3 | January 20th 04 09:41 PM |
