#31
anonymous coward wrote:
Have you considered using a constant current regulator, instead of a resistor? I believe there is an example circuit given in the LM337/317 datasheet showing how to build one using only the LM337 (normally used as a voltage regulator) & one resistor. It would need to be bolted to a heatsink, like the Luxeon Star LEDs, but IIRC the LM337 and cousins also shut down if they overheat. AC Yes. I considered it. I opted for the simplicity of a single current limiting resistor and the constant voltage regulator that is already there. Number one rule of fault management. If it ain't there, there's no way to break it. Regulators not only add an additional active component with its list of failure modes, it also adds severl solder connections and more heat, making it even more difficult to rig the system into a 1/4" piece of plexiglass. -- http://www.ernest.isa-geek.org/ "Ignorance is mankinds normal state, alleviated by information and experience." Veeduber |
#32
Jim Weir wrote in message
And as somebody else has pointed out, running a series string close to the bottom limit of Vcc and hoping that a single resistor will provide constant current to these devices will cook them when Vcc rises to the charging voltage. No designer in his right mind would use a circuit in this manner. Jim The more the supply varies the less effective the technique is. I picked the simple resistor design with certain assumptions. When it comes down to it, the voltage doesn't vary all that much on a properly operating electrical system. That big 'ole battery is like an anchor on the supply bus. Over voltage condition blows the breaker. What if the alternator quits? Well how far down do you want to go on the discharge? You could get a range of zero to 14 volts if you consider a discharged battery, thats a pretty tough range to design for isn't it? I can think of a lot of systems that will malfunction when supplied from a discharged battery. Even normal lights will go out of spec on a discharged battery. |
#33
On Wed, 05 May 2004 02:46:06 +0000, Ernest Christley wrote:
anonymous coward wrote: Have you considered using a constant current regulator, instead of a resistor? I believe there is an example circuit given in the LM337/317 datasheet showing how to build one using only the LM337 (normally used as a voltage regulator) & one resistor. It would need to be bolted to a heatsink, like the Luxeon Star LEDs, but IIRC the LM337 and cousins also shut down if they overheat. AC Yes. I considered it. I opted for the simplicity of a single current limiting resistor and the constant voltage regulator that is already there. Number one rule of fault management. If it ain't there, there's no way to break it. Regulators not only add an additional active component with its list of failure modes, it also adds severl solder connections and more heat, A regulator will produce no more heat than a resistor passing the same current with the same voltage drop. The ones I'm thinking of are 'in-line' devices, so their (negligible) supply current does not have to be factored in as an extra source of heat. I buy what you're saying about complexity, but you would probably only need a single current regulator + one resistor for each parallel bank of series LEDs (eugh, but I can't think how better to put it). BTW, do you need to use zener diodes / transorbs with aircraft power systems as you do in cars, to avoid problems with voltage spikes? AC making it even more difficult to rig the system into a 1/4" piece of plexiglass. |
#34
BTW, do you need to use zener diodes / transorbs with aircraft power systems as you do in cars, to avoid problems with voltage spikes? AC In one form or another, I'd say the answer is a qualified yes. Again, I didn't add any sort of regulation to the LED array. As I remember it, and it has been quite a while since I looked at it, the larger LEDs can absorb rather large transients themselves. Their construction is not that far removed from zeners or transorbs after all. As I understand it, the limiting factor of the LED's ability to suck down transients is their ability to dump the internal heat is the reason why 'overdriving' them with higher but pulsating current works. You can drive more current through them, just not for very long. In my opinion (vs me sitting down and running actual numbers which will only happen when I'm ready to build my own prodution models), if you derate the LED to about 80%, it'll be able to take whatever a barely functioning regulator will ever throw at it. Anything more is overdesign, adds complexity, and one more solder joint is just one more chance for me to screw something up. -- http://www.ernest.isa-geek.org/ "Ignorance is mankinds normal state, alleviated by information and experience." Veeduber |
#35
I posted new photos of the LED tail strobe, now with the circuit
completed, at http://w1.lancair.net/pix/led-strobe i also posted the schematic. the particular component choices give a 1 second period and 50% duty cycle. tinker with values to get your favorite flash pattern i used monolithic ceramic capacitors because they are small, but they do have a bit of variattion of C with temp. might be better to use something more stable. as the circuit warms it flashes faster. The circuit works quite well, but after some soul-searching I have tenatively decided NOT to put the system on the LNC 360. reasons: -its heavy...235 grams. Installing the strobe will require more than 3 times its mass added to the rudder counterweight. perhaps a kilogram total. all this at the maximum rearward moment arm. yuck. -it gets quite warm. after a minute or two the temp is maybe 40C at the base of the LEDs and thats with a fan pushing air past at about 10 MPH. in still air it overheats. if i forget to turn it off on landing, I could possibly slag my rudder. -the system satisfys the FAA Regs, but with no margin...I prefer a safety factor 2. -its a complicated system. lots of machining. tight fits. odd angles. no finesse. it just doesnt seem like a bulletproof system to me, so i may just chalk this one up to experience and develop plan B. Plan B: get a bunch of 5 mm diameter superbright white leds and mill the hemispherical ends off the plastic cases. this will give them a lambertian pattern. no need to polish the ends, might even sandblast them to make the pattern even broader. glue these into holes drilled in the curved trailing edge of the lancair wingtip. i will need many more of these LEDS than with luxeons, but that will help distribute the thermal dissipation. the weight might actually be lower this way than with luxeons since the aluminum heat sink will no longer be needed. and the weight will be near the center of lift, and will not require a counterweight. or maybe i will come up with plan C... -Jeff |
#36
A linear regulator will produce the SAME amount of heat as a resistor
at the same current. W=VI If the volts and the amps are the same the power is the same. However since the car mfg's are installing LED's in the center brake light they have paid for the development of simple constant current switching power supply IC's to drive the LED's. The power dissipated in the LED is the same however the power that was dissipated in the current limit ballast resistor has been greatly reduced so that the TOTAL system power and heat generated is about 50% of what it was to get the same light out of the LED using resistors. You have to add a small inductor and since it is a switcher you may have radio interference if your layout and EMI filter is not good. John On Tue, 11 May 2004 09:01:23 +0100, anonymous coward wrote: On Wed, 05 May 2004 02:46:06 +0000, Ernest Christley wrote: anonymous coward wrote: Have you considered using a constant current regulator, instead of a resistor? I believe there is an example circuit given in the LM337/317 datasheet showing how to build one using only the LM337 (normally used as a voltage regulator) & one resistor. It would need to be bolted to a heatsink, like the Luxeon Star LEDs, but IIRC the LM337 and cousins also shut down if they overheat. AC Yes. I considered it. I opted for the simplicity of a single current limiting resistor and the constant voltage regulator that is already there. Number one rule of fault management. If it ain't there, there's no way to break it. Regulators not only add an additional active component with its list of failure modes, it also adds severl solder connections and more heat, A regulator will produce no more heat than a resistor passing the same current with the same voltage drop. The ones I'm thinking of are 'in-line' devices, so their (negligible) supply current does not have to be factored in as an extra source of heat. I buy what you're saying about complexity, but you would probably only need a single current regulator + one resistor for each parallel bank of series LEDs (eugh, but I can't think how better to put it). BTW, do you need to use zener diodes / transorbs with aircraft power systems as you do in cars, to avoid problems with voltage spikes? AC making it even more difficult to rig the system into a 1/4" piece of plexiglass. |
#37
On Tue, 11 May 2004 17:04:22 +0000, Ernest Christley wrote:
anonymous coward wrote: BTW, do you need to use zener diodes / transorbs with aircraft power systems as you do in cars, to avoid problems with voltage spikes? AC In one form or another, I'd say the answer is a qualified yes. Again, I didn't add any sort of regulation to the LED array. As I remember it, and it has been quite a while since I looked at it, the larger LEDs can absorb rather large transients themselves. Their construction is not that far removed from zeners or transorbs after all. Do you know where I might find any links to material about this? I'm building a computer controlled LED flasher device (not for a tail strobe - something unrelated) and naturally I would like to make the flashes as bright as possible. Luxeon reckon that when pulse-width modulating their LEDs, the current should never exceed 500-550 mA (for the 1W versions). Given that their normal current is only 350 mA this isn't much of an increase. Also, this is meant to be at pulse-width-modulation frequencies of 100Hz or more. The pulse duration I need is 1/10 of a second. On the other hand, your experience echoes my experience. My Luxeons aren't heat-sunk, yet due to software faults I've unintentionally passed 1.5A through some of them for several seconds. I won't be surprised if their life expectancy is greatly reduced but they have lasted the 'development' phase of my device surprisingly well. As I understand it, the limiting factor of the LED's ability to suck down transients is their ability to dump the internal heat is the reason why 'overdriving' them with higher but pulsating current works. What worries me is how quickly the die can dump heat to the aluminium casing. AC |
#38
On Tue, 11 May 2004 17:04:22 +0000, Ernest Christley wrote: In one form or another, I'd say the answer is a qualified yes. Again, I didn't add any sort of regulation to the LED array. As I remember it, and it has been quite a while since I looked at it, the larger LEDs can absorb rather large transients themselves. Their construction is not that far removed from zeners or transorbs after all. Do you know where I might find any links to material about this? I'm building a computer controlled LED flasher device (not for a tail strobe - something unrelated) and naturally I would like to make the flashes as bright as possible. Luxeon reckon that when pulse-width modulating their LEDs, the current should never exceed 500-550 mA (for the 1W versions). Given that their normal current is only 350 mA this isn't much of an increase. Also, this is meant to be at pulse-width-modulation frequencies of 100Hz or more. The pulse duration I need is 1/10 of a second. On the other hand, your experience echoes my experience. My Luxeons aren't heat-sunk, yet due to software faults I've unintentionally passed 1.5A through some of them for several seconds. I won't be surprised if their life expectancy is greatly reduced but they have lasted the 'development' phase of my device surprisingly well. Superbrightled.com (I think) has some of this info. The rest is just general knowledge of semi-conductors. If Luxeon gave you a Imax for pulsed current, they should have also given you a pulse duration and duty cycle. That is, how long and how often the current flows. Again, the limiting factor is how quickly can you get the heat from the CENTER of the device. The surface temperature is really only a side effect. It's the temperature of that little piece of doped glass in the center of that large chunk of plastic that is critical, and it can melt while the exterior is still cool. So you can briefly drive a lot of current, but then you have to stop and let the casing suck the heat out. As I understand it, the limiting factor of the LED's ability to suck down transients is their ability to dump the internal heat is the reason why 'overdriving' them with higher but pulsating current works. What worries me is how quickly the die can dump heat to the aluminium casing. AC You are well informed to be worried. All of these PC overclockers thinking they can crank up the juice if they just add a bigger heat sink are fooling themselves. The heat energy has a somewhat tortuous path to traverse through the IC packaging before it can even be transferred to the heatsink. To be most effective, a heat sink has to be as 'close' to the heat source as possible. Close being defined as the least amount of insulation between the two, ie. a 1/2" gap filled with copper plate is probably better than a 1/10" air gap. The base of the LED is NOT the heat source. (Though the leads are some nice metal heat conductors connected directly to the glass in the middle 8*) -- http://www.ernest.isa-geek.org/ "Ignorance is mankinds normal state, alleviated by information and experience." Veeduber |
#39
From what I've read, the bond wire that connects the semiconductor die
to the leadframe (the part you solder) can be the limiting factor on pulse current. It has a lower thermal time constant that the chip itself. You can smoke that little gold wire if you try to shove too many e-'s through it at once. I'm not sure what you're doing with your alternative application, but in general, you pulse them to multiplex them for moving signs or to lower the observed brightness (via PWM) for brightness controls. anonymous coward wrote in message e... On Tue, 11 May 2004 17:04:22 +0000, Ernest Christley wrote: anonymous coward wrote: BTW, do you need to use zener diodes / transorbs with aircraft power systems as you do in cars, to avoid problems with voltage spikes? AC In one form or another, I'd say the answer is a qualified yes. Again, I didn't add any sort of regulation to the LED array. As I remember it, and it has been quite a while since I looked at it, the larger LEDs can absorb rather large transients themselves. Their construction is not that far removed from zeners or transorbs after all. Do you know where I might find any links to material about this? I'm building a computer controlled LED flasher device (not for a tail strobe - something unrelated) and naturally I would like to make the flashes as bright as possible. Luxeon reckon that when pulse-width modulating their LEDs, the current should never exceed 500-550 mA (for the 1W versions). Given that their normal current is only 350 mA this isn't much of an increase. Also, this is meant to be at pulse-width-modulation frequencies of 100Hz or more. The pulse duration I need is 1/10 of a second. On the other hand, your experience echoes my experience. My Luxeons aren't heat-sunk, yet due to software faults I've unintentionally passed 1.5A through some of them for several seconds. I won't be surprised if their life expectancy is greatly reduced but they have lasted the 'development' phase of my device surprisingly well. As I understand it, the limiting factor of the LED's ability to suck down transients is their ability to dump the internal heat is the reason why 'overdriving' them with higher but pulsating current works. What worries me is how quickly the die can dump heat to the aluminium casing. AC |
#40
Luxeon has a patented mechanical design that allows them to dissipate the power better, thus getting more lumens. It is
not like the superbrights... See: http://www.lumileds.com/pdfs/protected/AB23.PDF -- Dan D. http://www.ameritech.net/users/ddevillers/start.html .. "Ernest Christley" wrote in message news ![]() anonymous coward wrote: On Tue, 11 May 2004 17:04:22 +0000, Ernest Christley wrote: In one form or another, I'd say the answer is a qualified yes. Again, I didn't add any sort of regulation to the LED array. As I remember it, and it has been quite a while since I looked at it, the larger LEDs can absorb rather large transients themselves. Their construction is not that far removed from zeners or transorbs after all. Do you know where I might find any links to material about this? I'm building a computer controlled LED flasher device (not for a tail strobe - something unrelated) and naturally I would like to make the flashes as bright as possible. Luxeon reckon that when pulse-width modulating their LEDs, the current should never exceed 500-550 mA (for the 1W versions). Given that their normal current is only 350 mA this isn't much of an increase. Also, this is meant to be at pulse-width-modulation frequencies of 100Hz or more. The pulse duration I need is 1/10 of a second. On the other hand, your experience echoes my experience. My Luxeons aren't heat-sunk, yet due to software faults I've unintentionally passed 1.5A through some of them for several seconds. I won't be surprised if their life expectancy is greatly reduced but they have lasted the 'development' phase of my device surprisingly well. Superbrightled.com (I think) has some of this info. The rest is just general knowledge of semi-conductors. If Luxeon gave you a Imax for pulsed current, they should have also given you a pulse duration and duty cycle. That is, how long and how often the current flows. Again, the limiting factor is how quickly can you get the heat from the CENTER of the device. The surface temperature is really only a side effect. It's the temperature of that little piece of doped glass in the center of that large chunk of plastic that is critical, and it can melt while the exterior is still cool. So you can briefly drive a lot of current, but then you have to stop and let the casing suck the heat out. As I understand it, the limiting factor of the LED's ability to suck down transients is their ability to dump the internal heat is the reason why 'overdriving' them with higher but pulsating current works. What worries me is how quickly the die can dump heat to the aluminium casing. AC You are well informed to be worried. All of these PC overclockers thinking they can crank up the juice if they just add a bigger heat sink are fooling themselves. The heat energy has a somewhat tortuous path to traverse through the IC packaging before it can even be transferred to the heatsink. To be most effective, a heat sink has to be as 'close' to the heat source as possible. Close being defined as the least amount of insulation between the two, ie. a 1/2" gap filled with copper plate is probably better than a 1/10" air gap. The base of the LED is NOT the heat source. (Though the leads are some nice metal heat conductors connected directly to the glass in the middle 8*) -- http://www.ernest.isa-geek.org/ "Ignorance is mankinds normal state, alleviated by information and experience." Veeduber |
| Thread Tools | |
| Display Modes | |
| FS: RV-8 Tail Kit | Mike Woodall | Home Built | 0 | January 4th 04 03:38 AM |
| twin tail questions | Kevin Horton | Home Built | 12 | January 2nd 04 04:21 PM |
| tail buffeting and leading edge fillets, strakes | Wallace Berry | Home Built | 1 | September 26th 03 11:48 PM |
| LEDs with Strobe lights | pekka1510 | Home Built | 11 | September 1st 03 12:36 AM |
| Oshkosh Get together Roster - Sign in, please! | Bruce E. Butts | Home Built | 4 | July 26th 03 12:34 PM |
