iPhone 6 Plus and iGlide
Old May 4th 15, 08:02 PM posted to rec.aviation.soaring
glidergeek
Default iPhone 6 Plus and iGlide
I've only seen about 4 hours without charging only leaving 10-20% charge left, not quite enough if you land out and need to make a call(s).
  #32
Old May 4th 15, 09:41 PM posted to rec.aviation.soaring
jfitch
I wired in a usb charing port, so it stays charged. Best to start the day with the phone charged though, otherwise it will drain the instrument battery to charge the phone battery.
  #33
Old May 4th 15, 10:11 PM posted to rec.aviation.soaring
Mike Rinaldi
I have a portable charger I fly with. Very small and light. Will keep my iPhone charged all day. Bought it on Amazon.
  #34
Old May 5th 15, 03:26 AM posted to rec.aviation.soaring
Sean Fidler
Buy a Mophie perhaps? This is what I use for my iPhone when flying with iGlide. The Mophie is a $100 "battery case" that provides roughly 3500 mAh of additional battery capacity (120% additional). With a Mophie, there is no need for wires or a separate portable battery in the cockpit. The mophie case is only slightly larger than a normal case. The Mophie case setup will run an iPhone running iGlide all day (8 hours plus). Far longer if one does not leave the screen on constantly. Also, the Mophie charges from the same single USB wire at night. No need to charge two batteries separately (two wires and charging adapters). No more forgetting to charge the spare battery. Just a thought. www.mophie.com
  #35
Old May 17th 15, 07:02 PM posted to rec.aviation.soaring
I picked up an 8600mah PowerBurst from Costco for $30. It will fully charge my iPhone5 3 times and after flying for 5 hours the phone is still at 100%. It has to be connected by cord to the phone but that has been workable so far.
  #36
Old May 19th 15, 12:27 PM posted to rec.aviation.soaring
On Sunday, March 29, 2015 at 1:23:59 PM UTC-7, jfitch wrote:
Since the board seems kind of dead today (everyone getting their gliders ready for the season?) I will weigh in with a brief review of this combo. I like iGlide, which seems quite modern compared to the other commercial offerings and it pairs well with the Butterfly/Air variometer. Last year I was running it on an iPhone 5s alongside an Avier(Oudie/V2) running SYM, XCSoar, and Winpilot on various days. The problem with the 5s is the screen is considerably smaller and not apparently as bright as the Avier. Though the display is much higher resolution, you have to hold it closer to you (not ideal for mature eyes) and sometimes hope you are under a cloud.
I bought an iPhone 6 Plus just to run iGlide. It's pretty big to carry around as a phone, however you can swap the SIM card back and forth if you have a 5/ 5s and want to use it that way. In any case, I did so with some trepidation that though the display is bigger and reputedly a bit more sunlight readable, it is an expensive experiment to perform. I now have it running, though I have not flown with it yet.
It is a great deal better than the iPhone 5s, it seems a little brighter held side by side in the sunlight but the shear size means a lot more light is falling on your eyeballs. It is quite readable even in direct sun behind while the 5s was not. Only when you get a direct refection of the sun orb on the screen is it illegible. iGlide just scales up everything to fit the display, so the text, icons, everything is bigger and easier for someone over 50 to read. The touchscreen is also better than the 5s, which seemed to take just a bit more firm touch than the previous iPhones. The 6+ is very sensitive and nice.
The surprise was holding it next to the Avier. There is a mismatch of specs, the Avier/Oudie/V2 claims are in the 800 - 1000 nit brightness and the iPhone 6+ has been independently tested at around 560. However they seem about the same apparent brightness held side by side with both at highest brightness. And the iPhone 6+ is more readable at any angle, in any light. The worst for both is the sun orb directly reflected from the glass, neither is readable there although you can see the edges of the iPhone. At slightly off that angle you can read the iPhone first, and it is simply better in all conditions. Of course the resolutions and touchscreens are not even in the same century. The iPhone display is both physically larger and higher resolution (1920 x 1080 vs. 480 x 272). The less said about the Avier touch screen the better.
I also have Winpilot iOS installed on it, this is also pretty modern and has some nice ideas incorporated, however for me it has been too buggy to use, yet.
I'm looking forward to flying with it.
Hello,
I would like to try iGlide Lite on an iPad Mini. Does this entry version of iGlide provide final glide information to a destination and provide U.S. terrain, airport and airspace data? Will iGlide work on an older iPhone 4?
Thanks. Peter Breen
  #37
Old May 19th 15, 12:29 PM posted to rec.aviation.soaring
Hello,
Thanks.
Peter Breen
  #38
Old May 19th 15, 05:11 PM posted to rec.aviation.soaring
jfitch
Hello,
Thanks. Peter Breen
I believe the answer to all those questions is yes. The lite version will not do a multi turn point route, but will do a "Go To" and the other functions. I ran it on an iPhone 4s initially. You will find the iPhone 4 a pretty small display for practical use, also somewhat dim in the sunlight. You will find the iPad mini very large, but also very dim in direct sunlight. I think you need iOS 8 to run the current version.
  #39
Old May 19th 15, 07:36 PM posted to rec.aviation.soaring
Hello,
Thanks. Peter Breen
Thanks for your quick response. I forget to ask: Does the lite version have a "nearest airports" function? What do you recommend as the best device for iGlide lite? The iPhone 6?
  #40
Old May 20th 15, 01:07 AM posted to rec.aviation.soaring
jfitch
I believe it does. I think that is the only routing function it has. If you do much cross country you will eventually want to upgrade to the Adv, if you do much racing you will want the Pro. But for local and casual CC I think the lite gives you nearest, and also arrival altitude at all reachable airports.
I have only run it on the iPhone 4s, 5s, and 6+. Of those the 6+ is far superior - brighter than the 4s, maybe a little brighter than the 5s but the screen area of the 6+ just puts out way more light. I considered an iPad mini but looking at other similar apps in the sun it was quite washed out, this is what all of the independent tests concluded as well. In my cockpit, the mini would be quite large too. The 6+ is big enough! Too big to carry around as a phone, for me. John Carlyle is using a 6 and thinks it is perfectly big enough. The 6+ has a physically larger screen than an Oudie/Avier/V2, with about 5x the resolution.
iGlide Ben S Soaring 31 February 16th 20 04:14 AM
iGlide update for iPhone 6 (4.7 inch) and iPhone 6 plus (5.5 inch) Sean Fidler Soaring 29 March 9th 15 03:24 AM
Butterfly iGlide App now available in the US Marc - Butterfly Avionics Soaring 25 June 2nd 14 08:10 AM
iglide [email protected] Soaring 1 June 2nd 13 05:07 PM
Butterfly iGlide Reed von Gal Soaring 4 May 2nd 12 06:00 PM
