Needed: Inexpensive AHRS module to work with Oudie, XCsoar, LK8000, etc...
Old April 30th 15, 01:59 AM posted to rec.aviation.soaring
Dan Marotta
Default Needed: Inexpensive AHRS module to work with Oudie, XCsoar, LK8000,etc...
Keep your airspeed indicator and altimeter and replace your mechanical
variometer with the Dynon D2. Problem solved!
On 4/29/2015 11:06 AM, kirk.stant wrote:
On Wednesday, April 29, 2015 at 9:48:12 AM UTC-5, son_of_flubber wrote:
On Wednesday, April 29, 2015 at 6:32:08 AM UTC-4, wrote:
Dynon has a very good answer: http://www.dynonavionics.com/docs/PocketPanel.html.
To meet Kirk's request for integration with moving map...
The D2 integrates wirelessly with several 3rd party apps so a programming API exists. Whether Dynon would make the API available to glider App developers (like the XCSoar team) is unknown.
On Wednesday, April 29, 2015 at 10:15:51 AM UTC-4, Tango Whisky wrote:
Until the main fuse blows.
The Dynon allows you to tie into the main DC supply, but it also contains an internal battery with 4-6 hours of juice. I suspect that there is a fail over mechanism.
The Stratus2 AHRS https://www.foreflight.com/products/stratus/ requires an 'Ipad' but it also offers Synthetic Vision and ADS weather (not offered on the D2.
The Dynon is nice (I've flown one in a friends Mooney), but remember that the speed is GPS based; in a wave situation that could get interesting! If I flew wave and wanted a full time AI it would be high on my list. The Stratus is real close, if it was supported in my Oudie2 I would take a real hard look at it!
Kirk
Dan Marotta
Old April 30th 15, 02:05 AM posted to rec.aviation.soaring
kirk.stant
Default Needed: Inexpensive AHRS module to work with Oudie, XCsoar,LK8000, etc...
mechanical variometer with the Dynon D2.* Problem solved!
Dan, I haven't had a mechanical vario in my cockpit for 14 years!
And getting stuck in a lennie is not a big problem out here in the midwest! So I'll just continue to comply with the FARs and wait for something I can afford.
Kirk
66
Oudie 2 Lite - how to Autorun XCSoar (or something other than SeeYou Mobile) Dave Springford Soaring 11 October 23rd 18 10:40 PM
XCSoar or LK8000? Dan Marotta Soaring 18 August 11th 16 02:54 PM
Best way to put XCsoar on Oudie 2 lite? Andrew Henderson Soaring 5 August 14th 14 08:37 PM
XCSoar / LK8000 MNLou Soaring 58 July 3rd 13 06:28 PM
Brief review of Android XCSoar on the Streak 5 and LK8000 on the MIO 400 Mike[_8_] Soaring 7 April 1st 11 10:22 PM
