#31
On Saturday, February 6, 2016 at 11:57:42 AM UTC-5, John Cochrane wrote:
I once took a very instructive BFR with Marty Eiler at Cal City. Needless to say, with lots of wave/rotor flying, Marty had plenty of experience in what actually works in real slack rope situations. He chuckled at the yaw the nose at the last moment stuff, encouraging me to try it and see how it made matters worse. His technique is to stay a bit off to one side, high if possible, and make sure the glider is banked toward to towplane with nose low and pointing towards the towplane as the slack comes out. The key is to avoid a kiting attitutde. This makes absolute sense. Think about rope coming taut with the glider nose up and banked away in a kite attitude, vs. nose down and banked toward the tug. The kite is going to be a lot rougher. When the rope pulls the glider, you don't want that to raise the glider's angle of attack, so the lift force fights the rope. Ideally, the rope pull should lower the glider's angle of attack, and the lift force should be somewhat in the direction of the rope. The key point is the glider's attitude when rope comes out, not relative motion. The yaw at the last minute idea, beyond being very hard to do (especially bouncing around in rotor), will typically leave the glider slightly banked away from the towplane, unless you're very very good and also banking the other way at the same time. It also points the glider away from the tug. Trying to speed up at the last minute means you get lower and lower. Any amount of last minute maneuvering is going to be very hard to do in the real situation of extreme turbulence. Holding a good attitude is easier. After a lot of subsequent experimentation I haven't found a better technique, at least one that I can perform reliably. John Cochrane BB I don't believe any of us said to, "yaw the nose at the last moment". It's more of, "Get the nose started to the side (using rudder)" so you: -avoid the loop -slow the glider -sorta maintain relative altitude to the towplane -maintain sight of the towplane It should be obvious that yawing inside the turn (if the towplane is turning) does not help at all. So, rudder away from the turn. It does not take much. When the rope comes tight, it's not a huge swing in either ship, it's just a realignment and a lessening of rope shock. If all else fails, drop the rope (especially if you lose sight of the towplane). |
#32
On Sunday, February 7, 2016 at 10:44:44 AM UTC-5, Charlie M. (UH & 002 owner/pilot) wrote:
On Saturday, February 6, 2016 at 11:57:42 AM UTC-5, John Cochrane wrote: I once took a very instructive BFR with Marty Eiler at Cal City. Needless to say, with lots of wave/rotor flying, Marty had plenty of experience in what actually works in real slack rope situations. He chuckled at the yaw the nose at the last moment stuff, encouraging me to try it and see how it made matters worse. His technique is to stay a bit off to one side, high if possible, and make sure the glider is banked toward to towplane with nose low and pointing towards the towplane as the slack comes out. The key is to avoid a kiting attitutde. This makes absolute sense. Think about rope coming taut with the glider nose up and banked away in a kite attitude, vs. nose down and banked toward the tug. The kite is going to be a lot rougher. When the rope pulls the glider, you don't want that to raise the glider's angle of attack, so the lift force fights the rope. Ideally, the rope pull should lower the glider's angle of attack, and the lift force should be somewhat in the direction of the rope. The key point is the glider's attitude when rope comes out, not relative motion. The yaw at the last minute idea, beyond being very hard to do (especially bouncing around in rotor), will typically leave the glider slightly banked away from the towplane, unless you're very very good and also banking the other way at the same time. It also points the glider away from the tug. Trying to speed up at the last minute means you get lower and lower. Any amount of last minute maneuvering is going to be very hard to do in the real situation of extreme turbulence. Holding a good attitude is easier. After a lot of subsequent experimentation I haven't found a better technique, at least one that I can perform reliably. John Cochrane BB I don't believe any of us said to, "yaw the nose at the last moment". It's more of, "Get the nose started to the side (using rudder)" so you: -avoid the loop -slow the glider -sorta maintain relative altitude to the towplane -maintain sight of the towplane It should be obvious that yawing inside the turn (if the towplane is turning) does not help at all. So, rudder away from the turn. It does not take much. When the rope comes tight, it's not a huge swing in either ship, it's just a realignment and a lessening of rope shock. If all else fails, drop the rope (especially if you lose sight of the towplane). Out of curiosity, I looked up "Slack towline" in the "Joy of Soaring" (mine is from 1974, pg28), basically what I posted is what is in the book (at least used to be a "standard" manual in the US). |
#33
The trouble I've found with attempts to slow down with slip or spoilers is that it's very hard to get timing right. You want to slow down while the slack is getting bigger. You don't want to be slowing down once the slack is big, or as the rope is coming out. A second delay, and you're making things worse.
A steady slip or spoilers in very rough air can be quite helpful for keeping slack from starting. Some times on long retrieve tows I put a few degrees of slip in and leave it there, which smooths things out nicely. John Cochrane BB |
#34
On Sunday, February 7, 2016 at 12:02:53 PM UTC-5, John Cochrane wrote:
Some times on long retrieve tows I put a few degrees of slip in and leave it there, which smooths things out nicely. I haven't done many retrieve tows of sufficient distance to obviate the tow pilot's typical advice that "I'll keep climbing until you release". But when I have, I've been reminded of how much easier it is to get slack in the rope once the tow combination has leveled off. A little slip works. But I like to move into low tow position, assuming I've briefed (or radioed) the tow pilot ahead of time. There's very little tendency to get slack in the rope. Low tow can be discomforting visually if you've never done it (a different angle) so it's worth practicing. Or fly with an operation like Valley Soaring Club (NY) that uses low tow almost exclusively. Chip Bearden |
#35
On Sunday, February 7, 2016 at 3:32:32 PM UTC-5, wrote:
On Sunday, February 7, 2016 at 12:02:53 PM UTC-5, John Cochrane wrote: Some times on long retrieve tows I put a few degrees of slip in and leave it there, which smooths things out nicely. I haven't done many retrieve tows of sufficient distance to obviate the tow pilot's typical advice that "I'll keep climbing until you release". But when I have, I've been reminded of how much easier it is to get slack in the rope once the tow combination has leveled off. A little slip works. But I like to move into low tow position, assuming I've briefed (or radioed) the tow pilot ahead of time. There's very little tendency to get slack in the rope. Low tow can be discomforting visually if you've never done it (a different angle) so it's worth practicing. Or fly with an operation like Valley Soaring Club (NY) that uses low tow almost exclusively. Chip Bearden I believe a number of training manuals suggest using low tow for long tows (like Middletown, NY to HHSC, NY...). Yes, Middletown, NY is almost exclusive low tow (except for some training and what a transient pilot likes). |
#36
On 2/3/2016 11:36 AM, son_of_flubber wrote:
The best way to demonstrate slack rope recovery is to take your BFR on a wave day with rotor in the pattern. Scenario based BFR. Chortle! Writ with tongue near cheek, I'll guess... But seriously, this may in fact be as realistic a scenario as Joe Instructor and Joe Experienced-near-mountains Soaring pilot can devise. In my case I expect it woulda helped demonstrate the validity of my post-BFR claim, "I never get slack in the rope!" FWIW, upon the presence of "significant slack" on gnarly days (gnarly being common in the foothills of the Rockies), I maintained a slight out-of-turn (if any) heading, yawed "slightly away" from the tug angle, matching as best as possible the tug's deck angle (slightly less than his, if I'm higher - the usual case), and wait. Never had a back release while so doing, & only rarely any appreciable yanks or subsequent "sympathetic loops" as noticeable in the glider. Bob W. |
#37
On Sunday, February 7, 2016 at 9:16:12 PM UTC-5, BobW wrote:
On 2/3/2016 11:36 AM, son_of_flubber wrote: The best way to demonstrate slack rope recovery is to take your BFR on a wave day with rotor in the pattern. Scenario based BFR. Chortle! Writ with tongue near cheek, I'll guess... At my last BFR, we did slack rope recovery in rotor, spin recovery, dove through a closing foehn hole, and flew V-approach of 75 K. Plan to do it again in 2016. |
#38
On Sunday, January 31, 2016 at 6:29:23 AM UTC-8, LongJourney wrote:
I would like to hear feedback from the instructors here about which method they use, and why? Any comments? Thanks, Jeff There are many ways of effecting a maneuver or result. Always strive to learn (for the 'applicant'), and always strive to be respectful and open (for the 'teacher'). There is a lot to be said for the 'cooperate and graduate' methodology in a field checkout, but these thread stories reveal more opportunities for learning. Apologies to the international readers-- the following is a mostly US and mostly high-tow(above the wake) level with the tug scenario. The yaw-away-from-the-tug method was documented in the Joy of Soaring (in the US) when tugs were lucky to have 150 hp and trainers were mostly 20:1 drag bricks. There really wasn't much option for differential in speed and lots of slack, due to that combination. And in the early 1960's in the US, there wasn't as much wave flying/rotor exposure commonly done. Training publications have lagged behind the changes of equipment, and developed techniques. In this century, with tugs believed to be minimal-performance with 180 h.p. and typically 230-235 h.p., and training occurring in (and under 50 hr. pilots buying) 30 and 40:1 or greater sailplanes, it is not uncommon to hear of towing moments gone awry. Minor glider pitch changes make abrupt speed changes. Towing speeds have changed from 55 - 65 mph to glider pilots requesting 70-75 knots. Trainers might have nose, chin or c.g. hooks. New solos in single-place might have a new tow-mount and no or minimal instruction in the new potential for different glider behavior (ie., no longitudinal stabilization). I find the most likely scenario for pilots to develop inadvertent slack line to be 1) a distraction when the tug turns (delaying their glider's heading change) or 2) turbulence. The glider pilot then typically makes a move that creates slack. In a delayed turn, the glider flies a differing arc than the tug, with a resultant increase in speed and a climb from increased lift. The increased glider attitude increases rope tension and reduces the excess thrust of the tug, which usually makes climb rate. The tug pilot changes his stick pressure aft to counteract the trim change of his lifting tail (mostly subconsciously). When the glider pilot notices the deviation they abruptly bank to "return to center" and drop the nose to level the path to the tug. At that moment, the glider releases line tension. The nose-up trim in the tug and gain in excess-thrust means he gets 'extra' rate of climb while trying to maintain normal tow speed. The glider and tug are differing in intention, closing separation, and creating increasing slack line. It is now up to the glider pilot to 'do something' to remove slack. Yet, if he achieved centerline position, the slack is under his nose and not visible. Yawing could allow sight of more of the rope, the changing of the bow. Yawing decelerates the glider relative to the tug and 'removes slack'. Yawing/slipping on tow is the only technique discussed in (US) training literature. Meanwhile, the tug continues climbing, marching away from the glider. The bigger the bow, the more differential speed at the moment of tensioning and greater likelihood of a rope break or a grumpy tow pilot. If the glider pilot notices the tugs climb, he also climbs -- increasing drag, AoA, differential speed, being more draggy to accel, adding a yaw .... and making for a big yank at the tensioning. Thank you to John Cochrane and Bill Tisdale for continuing to cross-pollinate the techniques we taught at Cal City for two decades. Perhaps this more simple recipe will clarify the teaching of position recovery and slack line management. When faced with slack line: 1) parallel the tug, 2) stay a smidge above the tug, 3) watch the rope and bow (below and alongside you) for tensioning, 4) match speed. As the rope tightens - gently lower the nose and yaw toward the tug -- to make the acceleration moment as easy as possible, and you will have minimal/no secondary slack. When tension is normal, return to position. Repeat as necessary. Recall from the boxing-the-wake exercise that a slight bow is normal for an off-centerline towing position. The same technique works in low tow position, yet the bow is above the glider ( yikes - my least favorite place). To not break a rope, the critical point is to match the speed of the tug, by accelerating the glider to slow the disappearance of the bow as it is coming tight. Yes, even students can be taught to do this smoothly, with knowledge and confidence -- even from bows of slack that have made high-time pilots 'wet their pants'. Why not just release, you ask? Usually, I see the distracted out-of-position kite occur on the first turn on departure to cross-wind leg. I don't really want the customer/renter releasing here in a PT3. Maybe this slack occurred from some punch-you-around rotor, and you'd like to get to the laminar lift. Maybe this slack happened during a long aero-retrieve and you aren't in range of the destination. Maybe if you just bail-off, you'll be at the back of the launch queue. I'd like to tow until I choose to release. Please note - none of this says to stay attached if you lost sight of the tug. All of this works when you are managing your position relative to the tug that you can see. Turbulence and Big Lift: When the tug punches up in lift - go up THEN. Don't wait. Take some of his energy/climb rate by tensioning the line with higher pitch attitude in the glider. He won't get quite so much higher than you. If he falls in a hole of sink, ease a little forward stick. By accelerating the glider, you make it easier for him to transition the hole and have less differential in climb rates. Yawing: Yes, you can/should yaw on tow to maintain enough tension to not allow a rope to back-release from a c.g. hook. Yawing/slipping is easier and a smaller scale correction than opening and closing spoilers (which the tug pilot doesn't appreciate). I write this not to "have you do it my way", but to share with more detail the technique I teach and have found to be effective in romping big conditions or for pilot whoopsies. Not every CFIG has same the range of experience or site social tolerances. Have a touch of empathy for their situations, too. If you are a CFIG -- do NOT surprise your tug driver by trying to teach this without a preflight detailed briefing. The time of slack line flight by the glider might be interpreted as a release by the tug driver. Ask your tugpilot to maintain normal speed and steady heading while practicing slack recoveries. Begin with only small deviations. The awkward phase of learning smooth recoveries includes a few yo-yo practices. A proper rope will break before hurting a sound towplane. (Be in reach of home.) A smooth slack recovery is imperceptible to the tug. Towpilots perform a huge service to soaring. Don't scare them or disrespect them. And Tisdale's comments about awareness of the rings and their potential path, if you choose to release are very pertinent. A bowed, released line will stream AFT of your glider, with potential to tangle/touch or damage the sailplane. Private questions always welcomed. Soar safely, Cindy B |
| Thread Tools | |
| Display Modes | |
| Rope Break | Walt Connelly | Soaring | 4 | April 12th 11 10:04 PM |
| tow rope | tazman | Soaring | 9 | August 25th 10 03:30 AM |
| Slack line with water | Ron Ogden | Soaring | 10 | May 5th 09 06:55 PM |
| OK you slack bastards | Glenn[_2_] | Aviation Photos | 5 | July 6th 08 03:49 PM |
| 11 on a Rope | Peter Seddon | Rotorcraft | 0 | May 27th 04 12:33 PM |
