Gordon Boettger Glider Record Attempt - Mon 03/21/2016
Old March 22nd 16, 12:34 AM posted to rec.aviation.soaring
Default Gordon Boettger Glider Record Attempt - Mon 03/21/2016
Got it...thanks Ron Gleason.
On Monday, March 21, 2016 at 4:56:00 PM UTC-4, Ron Gleason wrote:
On Monday, 21 March 2016 14:35:11 UTC-6, wrote:
Is there a way to filter the DeLorme inReach track so it only shows points of a single flight? Displaying the complete tracking history just confuses the mission.
On Sunday, March 20, 2016 at 6:46:00 PM UTC-4, WaltWX wrote:
Posted by Walt Rogers - WX
As flight dispatcher/weather support I once again will be commenting on the flight through my twitter feed: @wrogerswx
My blog is NOT active this year. However, I'll post graphics and occasional longer discussions on my Dropbox account "Weather Board":
http://bit.ly/1pv30VS
__________________________________________________ ____________________________
On Monday 31 Mar, I'll be making another record attempt in the Duo Discus glider with Hugh. If you're interested in following along, you can click on the link below which will provide you with my position, altitude, and speed throughout the flight. Select the arrow next to MAP FILTERS on the left and then by DATE AND TIME RANGE select CURRENTLY TRACKING to follow the flight. On the map you can click on the blue dots which will show more detailed position at that point. There is also a CENTER button on the left side that shows current position on the map. Altitudes and speeds will vary throughout the flight, but we will have a clearance up to 28,000 feet.
My main goal is to complete a straight line distance record with a goal of Rapid City, SD, however excessive upper level moisture along the route in NV might not make it possible to fly that route safely. We will make that call at launch time (sunrise). Our other option would be to fly north and south along the Sierra Nevada range and attempting a 3 turn point distance record, so I'll likely aim for flying from Minden (launch point) down to Inyokern, then up to Susanville, back down towards Mojave, and then back north to Minden or the northeast in NV. As you know, there are so many variables with this stuff, so who really knows where we'll end up, where we go, or when we land. Bottom line for me is to have fun and keep learning.
Click below to track our flight:
https://share.delorme.com/GordonBoettger
I'm not sure how this twitter stuff works, but Walt Rogers' (expert weather guy tracking our flight and in communication with us during the flight) has a twitter feed going.
Walt's Twitter feed:
@wrogerswx
Cheers,
Gordo
yes, on the upper left you will see 'Map Filter (OFF)' click on that and you will get a list of options for filtering. You can choose 'Currently Tracking' or 'Last Track'
It looks like they have landed back in Minden
  #32
Old March 22nd 16, 01:05 AM posted to rec.aviation.soaring
Frank Whiteley
On Monday, March 21, 2016 at 2:22:51 PM UTC-6, wrote:
Hi Charles yep Rons got his 1-26 diamond. I believe there are about 35 guys now that have done all three diamond legs in the 1-26. There had'nt been any for about 10 years untill daniel sachen, a 18 yr old from blairstown completed his this last year. Those blairstown boys make some remarkably good flights mostly using the ridge but they also clean house at the mtn and flat land contests.
I was looking at the Gordo plots, it looks like they made one flight out into east central wyoming from minden some time in the past. Thats one heck of a run.
I believe Daniel was #39.
Frank Whiteley
  #33
Old March 22nd 16, 01:07 AM posted to rec.aviation.soaring
Frank Whiteley
One attempt to Garden City, KS, landed in Gunnison, CO. Another ended in Logan, UT, due to weather. Two ended in Wyoming, first Casper, then Hulett (Devil's Tower).
Frank Whiteley
  #34
Old March 22nd 16, 01:23 AM posted to rec.aviation.soaring
Yes Frank it was the devils tower plot that I was examining
  #35
Old March 22nd 16, 04:55 AM posted to rec.aviation.soaring
WaltWX[_2_]
On Monday, March 21, 2016 at 12:49:36 PM UTC-7, ND wrote:
Hi Walt,
where do you find the hi res satellite loops that go all day? the ADDS satellite loop only lasts 9 frames. :/
Ah... the "Trick". Yes, it's hard to come back from a day of flying and still get all the day's visible animated imagery.
The trick is to use... Integrated Data Viewer (IDV) which can access some NCAR and Unidata servers that hold the GOES imagery for around 30 hours. The other trick is to find the time and have the patience to learn how to use IDV. That took a lot... but has now paid off.
http://www.unidata.ucar.edu/software/idv/
Lots of documentation and tutorials. But, still... a lot of time to learn the nuances...
Walter Rogers WX
Gordon Boettger Downwind Wave Record Attempt - Mon 02/17/2014 WaltWX[_2_] Soaring 57 December 12th 16 02:18 PM
Boettger Glider Distance Record Attempt Sunday 5/4/14 WaltWX[_2_] Soaring 26 May 8th 14 11:43 AM
Boettger Distance Record Attempt Saturday Mar 29 WaltWX[_2_] Soaring 10 March 29th 14 10:03 PM
Gordon Boettger 1000 mile attempt going on right now Bob Soaring 11 April 16th 13 03:16 AM
Best Glider for Altitude Record Attempt? Jerome Conners Soaring 24 December 17th 03 10:54 AM
