GP Gliders GP 14 Velo has finally FLOWN!!!
Old November 29th 16, 05:57 PM posted to rec.aviation.soaring
Default GP Gliders GP 14 Velo has finally FLOWN!!!
On Thursday, November 24, 2016 at 6:09:14 PM UTC-8, Tim wrote:
Good Evening All:
After a very long wait, the GP 14 Velo took to the air yesterday (November 24th) from Krosno, Poland by both aero-tow and electric self-launch. More details to come but check GP Gliders on FaceBook for pictures and video. First pilot reports are very good. We are finally flying!!!
Tim McAllister
GP Gliders USA
Looks like a fantastic glider Tim, congrats to GP. Anyone have any comments about the Velo, or any of the GP gliders for that matter? Thread drift into completely unrelated topics/nonsense is becoming the norm on this group.... So, is there a timeline for US delivery for the Velo? A rough timeline for the Jeta that you could inform us of Tim? The Jeta seems like a glider that could fill a very large niche. It sure would be one that would do all of what I want from a glider if it performs even close to advertised. I wonder what the planned empty weight and max gross are, and how much ballast it might take. All questions that I'm sure will be answered when GP wants to answer them, but I thought I might get the thread back on track...
  #32
Old November 29th 16, 09:20 PM posted to rec.aviation.soaring
son_of_flubber
On Tuesday, November 29, 2016 at 11:57:24 AM UTC-5, wrote:...
I wonder what the planned empty weight and max gross are, and how much ballast it might take...
For the GP 14 e Velo
Empty weight: 170 kg
Max. take off weight: 420 kg (255 kg UL)
http://www.gpgliders.com/gp-14-e-velo
  #33
Old November 29th 16, 09:29 PM posted to rec.aviation.soaring
here is the GP 15 info http://www.gpgliders.com/gp-15-jeta-0
  #34
Old November 30th 16, 01:32 AM posted to rec.aviation.soaring
Casey[_2_]
The more I look into the GP gliders and trailer the more I'm liking it. The propulsion is same company partnered with FES. http://www.mgm-compro.com And the battery in the wing is not an original concept. The German company Lange Aviation has been using it: https://www.youtube.com/watch?v=aSZxLewd8BA&t=61s look at 3:11. The trailers look very durable.
I wonder about charging the batteries in the wing. They must be pretty safe to be charged in the wing.
Casey
  #35
Old November 30th 16, 09:15 AM posted to rec.aviation.soaring
krasw
I think the GP15 is the smartest concept I've seen in ages. 13.5m gliders are stuck with club class performance (plus some, maybe) because of the massive span penalty. If GP is able to build 15m glider with kind of ultra-light structure with high aspect ratio, small wing AND stuff in electric propulsion plus rescue system, that would be awesome. Questions in my mind a 1) how are they going to achieve the stated empty weight, 2) are they able to mass produce (anything) and 3) are they able to certify it? Last two are essential questions.
  #36
Old November 30th 16, 05:27 PM posted to rec.aviation.soaring
Dan Marotta
How much weight do the batteries add to the wing? Will weigh something
like a LAK-12 to rig?
Casey
Dan, 5J
  #37
Old November 30th 16, 05:55 PM posted to rec.aviation.soaring
I've been told that the batteries will be removable, so you don't have to charge them in the wings. However, you presumably have to rig with them in the wings. The Antares 20E is one-man riggable with batteries in the wings, so it can be done with the right equipment.
  #38
Old November 30th 16, 07:11 PM posted to rec.aviation.soaring
son_of_flubber
So in your mind, the range extension of the sustainer does not compensate for the lower glide ratio?? Could the 13.5m could do the same task in the same time on the same day as a 15m pure glider?
The 13.5m might even go farther/faster than the 15m pure glider because the pilot could be smart and use the engine selectively.
Assuming aerotow, do you think that many pilots will land at the end of the day with fully charged batteries? If I had one I think I would land with a 50% charge or less. What do the people that already have FES do on a typical day?
  #39
Old November 30th 16, 08:26 PM posted to rec.aviation.soaring
Sean[_2_]
You guys are worrying too much.
This is a tiny, extremely modern glider. The batteries will add AT MOST 50 lbs per wing. Probably more like 30 lb. per wing or 60 lb. total. And without batteries I'll bet these wings are AT LEAST 50 lb. lighter (EACH) than any current 15m wing. So it's a wash in weight, with the batteries in the wing, with a current 15m (standard, not motor) glider such as an ASW-27. I would suspect that it might be lighter than a 27 wing, even with batteries.
The prototype had a picure (99%) sure, without batteries, and the guy was carrying the wing around under his arm like a large RC glider. Maybe I am wrong on this. Anyone?
Also, aero-towing with the boom deployed (and motor ready to go) would be very easy and practical to do. I cannot think of anything that would prevent certification of that procedure. The only thing I could imagine might be she shocks on the propeller in the aero retract (sprung bach clean) position. Maybe heavy gear hits on take off roll could somehow damage it.
Sean
  #40
Old November 30th 16, 08:43 PM posted to rec.aviation.soaring
Dan Marotta
I don't think towing with the boom erect would effect certification.
There may be a /_prohibition_/ in the flight manual but, if it's
experimental, IIRC you can do anything that you demonstrate during your
flight test phase (unless prohibited).
Sean
Dan, 5J
Anybody flown - Apis or TST 10M gliders? Dave Boulter Soaring 2 July 17th 06 09:27 PM
Any pilots flown Alisport Silent2 Motor Gliders? Dave Boulter Simulators 0 July 7th 06 12:12 PM
Has anyone flown in here? john smith Piloting 2 October 2nd 05 12:36 PM
has anyone flown with these ? Damian John Paul Brown General Aviation 0 April 15th 04 05:26 AM
has anyone flown with these ? Damian John Paul Brown Aviation Marketplace 0 April 15th 04 05:25 AM
