High tow vs. low tow for rough tows (long)
Old December 7th 03, 02:50 AM
F.L. Whiteley
"Stefan" wrote in message
Andreas Maurer wrote:
Why?
I haven't flown the Janus that often, but to me its airbrakes didn't
feel extraordinary to me?
The last time I flew a Janus, I needed both hands to close the airbrake.
THE girl who flew it the next day even couldn't close them at all, she
needed the help of the copilot.
Stefan
He's taking the Mickey.
Andreas claims " 6'7", 201 cm" ;^)
He once had an image posted, but it appears to be missing now.
He's a big lad, if anything he might have trouble with full aft travel of a
control.
Our elder member, about 135cm, had a little trouble with the airbrake handle
in our Grob when they popped open once.
YMMV,
Frank Whiteley
Colorado
  #32
Old December 7th 03, 04:35 AM
Bruce Hoult
Stefan wrote:
Let me add the standard procedure that I was told and that all pilots
I know of are using:
Extend the airbrakes (carefully - only about one inch) to get the
Try this in a Janus. Extending isn't a problem, but I wish you luck
closing them again during the tow. Chances are that after successfully
closing them, slack is much bigger than before.
I'm not sure I understand what you're talking about. We've got:
1) a Janus
2) 1000 ft high ridges
3) frequent strong winds onto the ridges
4) airspace limitations restricting us to, say, 2500 ft in some
of the places the ridges take us.
So I've spent a fair amount of time flying the Janus at 90 - 100 knots
and needing some brake to stop from busting the altitude limit. It's
not a problem.
See, for example:
http://www.hoult.org/bruce/gliding/sasha/p17.html
Someone previously asked if I always fly around with the brakes half
open. Yes, on days like that, in that area.
-- Bruce
  #33
Old December 7th 03, 04:38 AM
Bruce Hoult
That's why if I'm going faster than the towplane I prefer to store the
energy by climing a little, rather than by simply throwing it away using
the brakes, or a slip, or a yaw.
The slack isn't going to come out until you're going slower than the
towplane, and you need a way to get back to about the same speed again.
Basically a good idea - but higher than the tow plane, especially in
gusty conditions, is a place where I try not to be.
I don't know how much height is required, but I suspect it's on the
order of 5m. On a 50m+ rope that's Not A Problem.
-- Bruce
  #34
Old December 7th 03, 05:18 PM
Andreas Maurer
On Sat, 6 Dec 2003 19:50:25 -0700, "F.L. Whiteley"
... did I mention the 95 kilo's...?
control.
This is not my problem... the problem is the aft CG...
Bye
Andreas
  #36
Old December 8th 03, 07:57 PM
Mark James Boyd
Brian Case wrote:
small correction, I wasn't suggesting yawing the airplane to slow it
down and take out the slack. What I was saying is if you move off to
the side when the slack comes out it will automatically yaw the
towplane and a nose hook equipped glider. No timing required just stay
out to the side.
Brian
Thank you, Brian. A subtle but important distinction...being out
to the side clearly means the slack is taken out with quite a bit
less "snappiness." And this is a different dampening than the
yaw of the glider and tug when the line comes taut. Excellent!
  #37
Old December 9th 03, 07:13 PM
Caracole
out to the side.
Brian
If we can base the idea on two premises, first that we have a lot of
slack and second that breaking the rope is undesirable.
The reality is that large amounts of slack tend to result in big speed
differentials between the tow plane and the glider, particularly with
glass gliders and powerful tugs.
While the rope is slack, no thrust is transmitted to the glider.
Even with no pitch change, the glider begins decelerating. Due to
the loss of the glider's drag, the tug either accelerates or increases
rate of climb (depending on the tow pilot's actions). Presuming a
beginning generous gust or slap, and big slack, this allows a long
enough time period for a noticeable speed differential to be created.
Now, with differential speed, the slack is coming out rapidly.
One pilot sits level with or slightly below the tow plane and offset
to one side believing that the imminent yawing between the tow plane
and glider will dampen the loads sufficiently to prevent the rope
from breaking.
A second pilot has positioned himself slightly above the tow plane
and offset enough that he can easily watch the towline and it's
rate of tightening. As the line starts to come tight, this pilot
points his nose toward the tow plane and lowers the nose,
believing that he is in a good position and attitude for at least
some of the tow line loads to be absorbed in accelerating the glider.
The speed differential is diminished, as is the AOA of the glider.
Which of these two pilots is least likely to break the rope? And do
you have sound physics (rather than emotion) to support your position?
M Eiler
Fwd: [BD4] Source of HIGH CHTs on O-320 and O-360 FOUND! Bruce A. Frank Home Built 1 July 4th 04 07:28 PM
(PIREP, long) Cherokee 180 from Bay Area to Bishop, CA Dave Jacobowitz Piloting 15 June 24th 04 12:11 AM
Flight test update - long nauga Home Built 1 June 5th 04 03:09 AM
SWRFI Pirep.. (long) Dave S Home Built 20 May 21st 04 03:02 PM
MT. DIABLO HIGH SCHOOL CONCORD, CA PHOTOS MT. DIABLO HIGH SCHOOL PHOTOS Home Built 1 October 13th 03 03:35 AM
