I have monitored sections of gel-coated gliders with and without WX =
block. There is a VERY noticeable difference of yellowing on areas not = protected. This has been over a 5 year period. As a UV blocker, WX = block seems to work as advertised. Paul |
This thread is what makes ras work. Reuben I have
a 17 year old ship with some cracking on the wings. From your experience with composites, should I go poly or gel? And should I have all the old gel taken off, even if this will be more money? |
The wings I am preparing to refinish will be done in urethane and I
will be removing all the gelcoat that can be removed safely. I am addicted to gelcoat though. Must be the smell. Reuben Stewart Kissel wrote in message ... This thread is what makes ras work. Reuben I have a 17 year old ship with some cracking on the wings. From your experience with composites, should I go poly or gel? And should I have all the old gel taken off, even if this will be more money? |
Moisture will also settle around fittings and migrate into areas where it
really should not be. I think it is always better practice not to leave a ship outside. Wider temp swings, etc... Paul ----- Original Message ----- From: "Glider Pilot Network" To: "Paul Gaines" Sent: Tuesday, December 23, 2003 9:40 AM Subject: [r.a.s] Refinishing: Who has tried a shortcut?-U out there JJ? ------------------------------------------------------------ Newsgroup: rec.aviation.soaring Subject: Refinishing: Who has tried a shortcut?-U out there JJ? Author: Andy Durbin Date/Time: 14:30 23 December 2003 ------------------------------------------------------------ Paul Gaines wrote in message news:... Dry out your ship, slick it up, use WX block system once, preferably = twice a year, NEVER tie it out, and store it in your trailer inside a = basement or hanger, etc.. P. Gaines Why *NEVER tie it out*. Is your concern UV, moisture, or something else? My ship is based in Phoenix, AZ where the humidity is usually very low. Most of my fellow club pilots tie down for the duration of a contest. When I go to New Mexico or Texas I see dew on the wings in the morning. Why should I be concerned about a little moisture on the wings if I put 30 gallons inside them for 6 or more hours each contest day? Andy (GY) ------------------------------------------------------------ |
Reuben-
Fascinating post, would not waxing increase UV damage? |
Time for a round up.
I started this thread 4 days ago and I asked: There has been quite a bit on refinishing on RAS recently. Most people advocate that when gel-coat starts cracking up, it is essential to remove it ALL. There has been lots of advice and theory as to why the above is true. No doubt it is the recommended approach - recommended by many who are not in a position where they might have to pay for the work! However there was little response to my question: Does anybody out their own a ship which was refinished without removing all the gel-coat? What is the service history of these gliders? So far there have been two postings of problems with re-finishes. Neither of these involved a polyurathane finish. Gliders re-finished with extensive or complete removal of the old gel-coat have held up - at least as well as the original gel coat. So I will extend the question. Does anybody anybody know of gliders that have been refinished with polyurathane and subsequently experienced problems? I can answer that by saying I know of one glider that was re-finished with polyurathane about 10 years ago. There is some localised paint cracking on the tailplane and rudder which suggests that there were some areas of poor preparation during the refinish. I suspect that the glass skin on these areas is thiner more flexible which results in a finish that is more susceptible to cracking. This was not an "expensive" refinish job, for example the ailerons and flaps were not removed during the respray. But overall the glider still looks very neat and I think I can say this finish has lasted as least as well as many factory gel coat finishes. Ian |
I know of wings on a Phoebus that was sanded and then sprayed with
Polyurethane. After a couple of years, the wings looked like surface of El Mirage Dry Lake in Southern California. The old gelcoat pieces were not coming off but the cracks and fissures in the paint were obvious to the most casual observer. However, this Phoebus is still flying and it has been probably 15 years since sprayed. GA |
Ian,
I have had excellent results with a 'partial' gelcoat removal/refinish ... repainted with Simtek Prestec ... fuse 5 years old, still perfiect ... as are wings 3 and 2 years since refinish. This is a lot of work, BTW. Documented on SRA site ... http://sailplane-racing.org/Articles...asw20_wing.htm BTW ... did I say this is a lot of work. JJ ... apologize for stealing your punch line. :-) KK Ken Kochanski "Ian Forbes" wrote in message news ![]() Time for a round up. I started this thread 4 days ago and I asked: There has been quite a bit on refinishing on RAS recently. Most people advocate that when gel-coat starts cracking up, it is essential to remove it ALL. There has been lots of advice and theory as to why the above is true. No doubt it is the recommended approach - recommended by many who are not in a position where they might have to pay for the work! However there was little response to my question: Does anybody out their own a ship which was refinished without removing all the gel-coat? What is the service history of these gliders? So far there have been two postings of problems with re-finishes. Neither of these involved a polyurathane finish. Gliders re-finished with extensive or complete removal of the old gel-coat have held up - at least as well as the original gel coat. So I will extend the question. Does anybody anybody know of gliders that have been refinished with polyurathane and subsequently experienced problems? I can answer that by saying I know of one glider that was re-finished with polyurathane about 10 years ago. There is some localised paint cracking on the tailplane and rudder which suggests that there were some areas of poor preparation during the refinish. I suspect that the glass skin on these areas is thiner more flexible which results in a finish that is more susceptible to cracking. This was not an "expensive" refinish job, for example the ailerons and flaps were not removed during the respray. But overall the glider still looks very neat and I think I can say this finish has lasted as least as well as many factory gel coat finishes. Ian |
Ian - painting a control surface without removing it means it has not
been checked for proper mass-balance, and for many gliders is likely way out of spec - flutter hazard and not airworthy. If you refinish over cracked gelcoat, the cracks will continue to propagate upwards through the finish and downwards into the laminate - not airworthy and hidden. A reputable and knowledgable mechanic will sign off neither of these "shortcuts". Be careful out there, Happy Holidays, Dave PS: Yes, I have seen gliders where these shortcuts were taken, and yes, it caused serious problems later. Ian Forbes wrote in message ... Time for a round up. I started this thread 4 days ago and I asked: There has been quite a bit on refinishing on RAS recently. Most people advocate that when gel-coat starts cracking up, it is essential to remove it ALL. There has been lots of advice and theory as to why the above is true. No doubt it is the recommended approach - recommended by many who are not in a position where they might have to pay for the work! However there was little response to my question: Does anybody out their own a ship which was refinished without removing all the gel-coat? What is the service history of these gliders? So far there have been two postings of problems with re-finishes. Neither of these involved a polyurathane finish. Gliders re-finished with extensive or complete removal of the old gel-coat have held up - at least as well as the original gel coat. So I will extend the question. Does anybody anybody know of gliders that have been refinished with polyurathane and subsequently experienced problems? I can answer that by saying I know of one glider that was re-finished with polyurathane about 10 years ago. There is some localised paint cracking on the tailplane and rudder which suggests that there were some areas of poor preparation during the refinish. I suspect that the glass skin on these areas is thiner more flexible which results in a finish that is more susceptible to cracking. This was not an "expensive" refinish job, for example the ailerons and flaps were not removed during the respray. But overall the glider still looks very neat and I think I can say this finish has lasted as least as well as many factory gel coat finishes. Ian |
Ian,
With respect, you cannot establish good practice by totting up numbers of for and against contributions to RAS. Bob Lacovara's contribution says it all. If you come to resell the shortcut refinished glider will you make clear to potential purchasers that the condition of the glider laminate is unknown and can only be checked by removing the new and underlying old finishes? John Galloway At 09:36 20 December 2003, Ian Forbes wrote: Time for a round up. I started this thread 4 days ago and I asked: There has been quite a bit on refinishing on RAS recently. Most people advocate that when gel-coat starts cracking up, it is essential to remove it ALL. There has been lots of advice and theory as to why the above is true. No doubt it is the recommended approach - recommended by many who are not in a position where they might have to pay for the work! However there was little response to my question: Does anybody out their own a ship which was refinished without removing all the gel-coat? What is the service history of these gliders? So far there have been two postings of problems with re-finishes. Neither of these involved a polyurathane finish. Gliders re-finished with extensive or complete removal of the old gel-coat have held up - at least as well as the original gel coat. So I will extend the question. Does anybody anybody know of gliders that have been refinished with polyurathane and subsequently experienced problems? I can answer that by saying I know of one glider that was re-finished with polyurathane about 10 years ago. There is some localised paint cracking on the tailplane and rudder which suggests that there were some areas of poor preparation during the refinish. I suspect that the glass skin on these areas is thiner more flexible which results in a finish that is more susceptible to cracking. This was not an 'expensive' refinish job, for example the ailerons and flaps were not removed during the respray. But overall the glider still looks very neat and I think I can say this finish has lasted as least as well as many factory gel coat finishes. Ian |
Commercial Glider refinishing book | Martin Carolan | Soaring | 0 | December 15th 03 09:41 AM |
REFINISHING | Ventus B | Soaring | 32 | December 3rd 03 10:14 PM |
Older glass glider refinishing question | Gus Rasch | Soaring | 6 | November 10th 03 12:18 AM |
Refinishing Your Aircraft (now in Oregon) | aerocomposites | Home Built | 0 | September 24th 03 05:29 AM |
Tracon II Shortcut key for "THEN" | Jack Frost | Simulators | 0 | August 17th 03 02:54 PM |
