A Tale of Two Takeoffs
Old June 18th 17, 07:00 PM posted to rec.aviation.soaring
Default A Tale of Two Takeoffs
The tailwind in Cordele was minimal; a few knots. At Nephi last year, IIRC it was more substantial: perhaps 10 kts. We gridded that way because the wind was forecast to (and did) become more of a headwind early in the launch.
The few launches before mine were uneventful. As is true with most things at contests, no one forces you to do anything: launch, start, fly the task, final glide low over unlandable terrain, whatever. It's always pilot's choice. Sometimes we put pressure on ourselves to exhibit the "right stuff" and carry on like everyone else.
Nephi has a single hard-surface runway so the alternative was gridding at the other end, then elephant walking the entire length after the early gliders had launched and the wind shifted. With three classes on the grid--including the Open Class birds at the back--that would have complicated matters even more. The launch operation had been slower than desired during the practice period so the last thing anyone wanted was a delay. I believe this was the day that someone on the radio reported a dust devil in the vicinity of the departure corridor just off the end of the runway. After a minute's reflection, the order came down, "Continue the launch!" Already airborne, I heard the next couple of pilots radio their alarm and unhappiness after they hit the turbulence. There was probably a bit too much "full speed ahead" on all our parts.
I've carried on way too long already but I'll add two more points that help explain where I went wrong. Back in 1982 at the Elmira 15M Nationals, I was #1 to take off. The wx forecast was good but there was a significant quartering tailwind. No way to launch in the opposite direction. The decision whether to cancel the day would be based on how my launch went. Pressure! I consulted more experienced pilots, including Elmira's Roy McMaster. I briefed my sister, Diane, how to run the wing. With partial ballast and a tailskid on my LS-3, I knew keeping the wings level and the fuselage aligned were both critical.
The initial roll went fine: wings level and straight. But as we rolled off the end of the hard surface onto the grass, neither I nor the tow plane was airborne. The grass eventually slopes down slightly at Harris Hill before falling off more sharply. Once we broke ground, all I had to do if things weren't progressing was coast out into the valley where I could glide to the big county airport. I was told we went out of sight still on the ground and disappeared. Many seconds later, when we reappeared far out in the valley, level with the top of the Hill and climbing, a big cheer went up! Most flew that day but one pilot's crew didn't seem to understand the concept of running with the wingtip as long as possible and he gave up after three aborted attempts.
I suspect I've been overconfident about non-standard take offs ever since....until last summer at Nephi.
The second point involved an aero retrieve at Region 4 the year before Nephi. The owner of the grass strip, a pilot himself, towed my ASW 24 back to the end of the runway and I briefed him on how to run the wing. My biggest caution: "Don't hold the wingtip back; let the trailing edge just fly out of your hand." Of course, he did the exact opposite and steered me right toward the fence. But with M-ASA's powerful Pawnee ahead, the glider responded almost instantly to full opposite rudder and I straightened out just before reaching for the release.
So at Nephi, with the confidence that I had dealt with similar situations in the past and seeing other guys take off just fine, I accepted the launch. And when the nose was pulled off track almost immediately, my first reaction was "I can do this (just like I did last year)." The difference was a much higher density altitude, full ballast, and a significant tailwind.
I did just about everything wrong, from the pre-flight planning all the way through the takeoff itself. I'm very fortunate I didn't ground loop when I rolled off the runway and do some real damage.
Now for real question no one has asked: would I accept the Nephi launch again? Yes, with my own wing runner and a commitment to pull the release as soon as anything went wrong. I was the only pilot in the "downwind" group who had a serious problem that day and I could have avoided it by executing my long-standing contingency plan.
As to why no one radioed about the landing light, I believe everyone thought I must have known and elected to continue anyway.
Chip Bearden
"JB"
  #32
Old June 18th 17, 08:13 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
On Sun, 18 Jun 2017 06:50:31 -0700, Echo wrote:
Wow that's interesting stuff. I once went to a WW2 glider museum in
Iron Mountain Michigan, but it was more about the manufacturing and
stories and less about the design and flight characteristics. The only
time I've ever noticed any kind of wash from a towplane is on pavement
behind a CAP 182. 100' into the takeoff roll, the right wing always
drops. It's a briefing item when we fly there. Spiraling slipstream of a
tri gear vs taildragger.
It's a shame we can't put a glider and towplane in a wind tunnel
together...or at least some smoke/fluid testing released from the
towplane wingtips.
There seems to have very little research into glider towing, not even in
the Akafliegs, which did surprise me.
Take a look at this:
Wake Turbulence Hazard Analysis For A General Aviation Accident, DLR
2014, DocumentID 340177
You'll need to run a search as I don't have the URL to hand. Its a report
on a crash when a Robin GR400 took off too close behind an Antonov AN-2,
so not directly about glider towing, but there is some good info and
numbers about tip vortexes.
A glider on a 200 ft rope is close enough to the tug to be flying in its
downwash field if it is in the normal tow position, with the glider just
above the turbulent prop wake, which is angled down behind the tug's
flight path at about 1/3 of its AOA. and you can get some idea of the
downwash depth at the glider's distance if you extrapolate from
assumption that the downwash thickness is about half the wing chord at
4-5 chords behind the wing. NOTE this the tug's wing-generated downwash
and has nothing to do with the turbulent prop wake: I don't know how that
is positioned in relation to the wing downwash, how far back it extends
or what its 3D shape might be.
So much of aerodynamic "fact" isn't really known,
but more speculated and generally accepted. Would be a pretty neat
study to actually watch said downwash.
It seems to me that this topic could be the basis of a really nice PhD
thesis for an aerodynamicist.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
  #33
Old June 19th 17, 12:55 AM posted to rec.aviation.soaring
IIRC Gliding International magazine had something on towplane/glider interference sometime in the last year.
  #34
Old June 19th 17, 04:58 AM posted to rec.aviation.soaring
George Haeh
My limited exposure to aerodynamics textbooks leaves me with the
impression that airflow behind the vehicle is neglected.
When heavy jets came out, there was a spate of light aircraft crashes in
wake
encounters, followed by NASA research and guidance on avoiding.
I have not come across any formulae for air behavior behind aircraft. There
are simply general statements that the air will be descending and vortices
will trail the wing tips.
Perhaps a good analogy for being behind a towplane is that it has
similarities
for approaching a ridge from downwind - a bad place for being slow.
  #35
Old June 19th 17, 08:40 AM posted to rec.aviation.soaring
bumper[_4_]
At a flyi that included various flying and landing contests, I was helping with the release of helium balloons for the pilots to try and pop. Harder than some would imagine, as there were a lot more misses than hits (except for ace pilots such as myself). Several of the missed balloons got sucked into the wing tip vortices where they almost stayed in place while rotating at least several hundred rpm. This experience, and other explanations of tip vortices, led me to believe they were of small diameter directly behind the aircraft and expanded in diameter the further back they got while sinking at several hundred feet per minute.
This picture is from "wiki".
https://upload.wikimedia.org/wikiped...ortex_edit.jpg
I was on a photoshoot for a backcountry flying video with my Husky at Nevada's Black Rock Desert. Near the north end of the desert there are a couple of small playas that are protected from the wind, surrounded by small mountains. The playa surface had fine alkali dust that readily showed the air disturbance behind the Husky, which normally takes off full flaps. As soon as the plane started its take off roll, each tip vortice looked to be about 20 feet in diameter, sucking the fine dust up from the ground and rolling it up and over onto the wing reaching almost to the fuselage - it looked impressive.
The Husky has a perhaps undeserved* reputation for "Moose Stalls". So named as the aircraft is typically circling low over game counting animal populations or doing photograph. It is thought the aircraft, while circling tightly, dirty or "slowed up" with flaps extended, flies into its own wake causing a low altitude stall and loss of control. I have flown into my own wake doing this, though at higher altitude with room to recover - it's an eye opener.
*Undeserved, not because it doesn't happen with the Husky, but rather that the Husky has been used by many state Fish and Games for animal surveys, predator control etc. - lots of exposure. There have been Super Cub crashes under similar circumstances.
  #36
Old June 19th 17, 01:01 PM posted to rec.aviation.soaring
wake encounters, followed by NASA research and guidance on avoiding.
There
FWIW the angles and wake thicknesses I quoted work well for free flight
model design, where we know from experience that a model with its
tailplane in the wing wake is not stable in pitch. I've used these values
when designing an F1A with its wing on a low pylon to check that the
tailplane would outside the wing wake. Drawing the diagram said the
tailplane should be in clean air above the wing wake. The model's in-
flight behaviour shows that was a good prediction.
org |
  #37
Old June 19th 17, 02:45 PM posted to rec.aviation.soaring
Tim Newport-Peace[_4_]
http://cdn.shopify.com/s/files/1/011...f_jets.pdf?151
Page 2 "Wake turbulence"
helping
t=
f=
in=
a=
tip=
th=
sinking=
https://upload.wikimedia.org/wikiped...lane_vortex_e=
dit.jpg/220px-Airplane_vortex_edit.jpg
Nevad=
couple
mount=
di=
as=
2=
it=
impr=
essive.
named=
popula=
tight=
causi=
wake
op=
ener.
that
pr=
u=
  #38
Old June 19th 17, 05:16 PM posted to rec.aviation.soaring
I feel like retitling this from TTTO (Tale of Two Takeoffs) to SSST (Survival Strategies for Slow Tows).
Does this mean that if we're trapped on a slow tow, we should drop down into low tow position...or move up even higher than normal (if that's possible by then)...or move out to the side--all to escape the downwash?
Chip Bearden
"JB"
  #39
Old June 19th 17, 07:13 PM posted to rec.aviation.soaring
Tango Eight
Chip Bearden
"JB"
Speaking as a guy who's been the you ain't gonna have the choice. You are going to be heading for deep low tow whether you like it or not. Whether you fall off depends on what your tow pilot does next.
Evan Ludeman / T8
  #40
Old June 19th 17, 07:19 PM posted to rec.aviation.soaring
Steve Koerner
Responding to the slow tow matter...
I've written on this subject here on RAS before as it's one of my pet pive safety concerns. I've had a few seriously slow tows with water. My experience is that you will drop into low tow whether you want to or not - there's no choice to be had. In the extreme case, expect to be hanging lower than "low tow" at a high pitch angle slamming alierons to the stops. When this ocurrs at low altitude, there's no possibility of recovering should you disconnect from the rope.
I now keep printed instructions for towing with water ballast in the side compartment of my glider. If I don't have the chance to talk to the tow pilot immediately before the tow, then I will have the ground crew deliver written instructions to the tuggie as I'm being hooked up. Written instructions are less likely than a radio call to be confused, forgotten or misunderstood.
Here's a pdf of my written instruction sheet:
https://drive.google.com/file/d/0B_X...w?usp=drivesdk
14 takeoffs = 14 approaches - Video [email protected] Piloting 0 February 4th 10 01:16 AM
Any early turn takeoffs still around? Michael Instrument Flight Rules 12 June 6th 04 06:24 PM
Ground steering and Takeoffs webmaster Simulators 3 February 15th 04 08:34 PM
F-15 takeoffs Mary Shafer Military Aviation 2 July 1st 03 07:41 AM
