![]() I just helped set up the Ramy Yanetz ASG29's TRIG TT21 transponder with a TN72 GPS Source to use as a TABS ADS-B out system. That along with PowerFLARM in his glider makes for a pretty capable overall traffic awareness/collision avoidance system. Here is a screenshot of my portable Stratux ADS-B receiver (as would be used in many GA aircraft) receiving the ADS-B signal from the TT21 over 20 nautical miles away. Yes, it's a wave day out at Williams. https://drive.google.com/file/d/1Kik...SlslyEyMPo62Mu And again just an reminder, the TN72 is a ~$350 (+ GPS antenna + install costs) GPS Source that can easily be added to any Trig transponder to deliver ADS-B Out in your glider. (If you need full 2020 Compliant ADS-B Out it's a little more involved). This is low-enough cost that it will likely be a "just do it" choice for owners who already have a Trig transponder, and who especially want to provide more visibility to GA traffic (and it makes your glider visible to PowerFLARM buddies at much longer distances). |
On Sunday, February 11, 2018 at 6:04:37 PM UTC-5, Darryl Ramm wrote:
I just helped set up the Ramy Yanetz ASG29's TRIG TT21 transponder with a TN72 GPS Source to use as a TABS ADS-B out system. That along with PowerFLARM in his glider makes for a pretty capable overall traffic awareness/collision avoidance system. Here is a screenshot of my portable Stratux ADS-B receiver (as would be used in many GA aircraft) receiving the ADS-B signal from the TT21 over 20 nautical miles away. Yes, it's a wave day out at Williams. https://drive.google.com/file/d/1Kik...SlslyEyMPo62Mu And again just an reminder, the TN72 is a ~$350 (+ GPS antenna + install costs) GPS Source that can easily be added to any Trig transponder to deliver ADS-B Out in your glider. (If you need full 2020 Compliant ADS-B Out it's a little more involved). This is low-enough cost that it will likely be a "just do it" choice for owners who already have a Trig transponder, and who especially want to provide more visibility to GA traffic (and it makes your glider visible to PowerFLARM buddies at much longer distances). Please expand on make/model antennae used and where it is located on G29. |
![]() Most Trig glider dealers should be able to provide an antenna and either it will have a QMA antenna on it or they will install one for you and cut the GPS antenna cable to your length spec. I know Richard at Craggy Aero can do that for you.... he had one in his hand waving it at me when I last saw him :-) Give him a call. There is nothing special about the GPS antenna mounting location, or really the GPS antenna itself... but the dealers have been checking out specific antennas. You install it in the same location as you would a GPS antenna for your flight computer. Please don't use the silly TA70 wall wart antenna. That is TSO-ed-silliness on a stick, just not something suitable for a glider, and seems pretty contrary to the original easy adoption intent of TABS/TSO-C199. TRIG is aware of this, the TA70 came from earlier STCs for 2020 Compliant ADS-B Out installs. On Sunday, February 11, 2018 at 3:13:48 PM UTC-8, wrote: On Sunday, February 11, 2018 at 6:04:37 PM UTC-5, Darryl Ramm wrote: I just helped set up the Ramy Yanetz ASG29's TRIG TT21 transponder with a TN72 GPS Source to use as a TABS ADS-B out system. That along with PowerFLARM in his glider makes for a pretty capable overall traffic awareness/collision avoidance system. Here is a screenshot of my portable Stratux ADS-B receiver (as would be used in many GA aircraft) receiving the ADS-B signal from the TT21 over 20 nautical miles away. Yes, it's a wave day out at Williams. https://drive.google.com/file/d/1Kik...SlslyEyMPo62Mu And again just an reminder, the TN72 is a ~$350 (+ GPS antenna + install costs) GPS Source that can easily be added to any Trig transponder to deliver ADS-B Out in your glider. (If you need full 2020 Compliant ADS-B Out it's a little more involved). This is low-enough cost that it will likely be a "just do it" choice for owners who already have a Trig transponder, and who especially want to provide more visibility to GA traffic (and it makes your glider visible to PowerFLARM buddies at much longer distances). Please expand on make/model antennae used and where it is located on G29. |
On Sunday, February 11, 2018 at 6:52:03 PM UTC-5, Darryl Ramm wrote:
Most Trig glider dealers should be able to provide an antenna and either it will have a QMA antenna on it or they will install one for you and cut the GPS antenna cable to your length spec. I know Richard at Craggy Aero can do that for you.... he had one in his hand waving it at me when I last saw him :-) Give him a call. There is nothing special about the GPS antenna mounting location, or really the GPS antenna itself... but the dealers have been checking out specific antennas. You install it in the same location as you would a GPS antenna for your flight computer. Please don't use the silly TA70 wall wart antenna. That is TSO-ed-silliness on a stick, just not something suitable for a glider, and seems pretty contrary to the original easy adoption intent of TABS/TSO-C199. TRIG is aware of this, the TA70 came from earlier STCs for 2020 Compliant ADS-B Out installs. On Sunday, February 11, 2018 at 3:13:48 PM UTC-8, wrote: On Sunday, February 11, 2018 at 6:04:37 PM UTC-5, Darryl Ramm wrote: I just helped set up the Ramy Yanetz ASG29's TRIG TT21 transponder with a TN72 GPS Source to use as a TABS ADS-B out system. That along with PowerFLARM in his glider makes for a pretty capable overall traffic awareness/collision avoidance system. Here is a screenshot of my portable Stratux ADS-B receiver (as would be used in many GA aircraft) receiving the ADS-B signal from the TT21 over 20 nautical miles away. Yes, it's a wave day out at Williams. https://drive.google.com/file/d/1Kik...SlslyEyMPo62Mu And again just an reminder, the TN72 is a ~$350 (+ GPS antenna + install costs) GPS Source that can easily be added to any Trig transponder to deliver ADS-B Out in your glider. (If you need full 2020 Compliant ADS-B Out it's a little more involved). This is low-enough cost that it will likely be a "just do it" choice for owners who already have a Trig transponder, and who especially want to provide more visibility to GA traffic (and it makes your glider visible to PowerFLARM buddies at much longer distances). Please expand on make/model antennae used and where it is located on G29. Too many antenna. 4 GPS and 2 FLARM within 30". We need a reliable way to split/share GPS signal off a single antennae. |
On Sunday, February 11, 2018 at 5:57:21 PM UTC-8, wrote:
On Sunday, February 11, 2018 at 6:52:03 PM UTC-5, Darryl Ramm wrote: Most Trig glider dealers should be able to provide an antenna and either it will have a QMA antenna on it or they will install one for you and cut the GPS antenna cable to your length spec. I know Richard at Craggy Aero can do that for you.... he had one in his hand waving it at me when I last saw him :-) Give him a call. There is nothing special about the GPS antenna mounting location, or really the GPS antenna itself... but the dealers have been checking out specific antennas. You install it in the same location as you would a GPS antenna for your flight computer. Please don't use the silly TA70 wall wart antenna. That is TSO-ed-silliness on a stick, just not something suitable for a glider, and seems pretty contrary to the original easy adoption intent of TABS/TSO-C199. TRIG is aware of this, the TA70 came from earlier STCs for 2020 Compliant ADS-B Out installs. On Sunday, February 11, 2018 at 3:13:48 PM UTC-8, wrote: On Sunday, February 11, 2018 at 6:04:37 PM UTC-5, Darryl Ramm wrote: I just helped set up the Ramy Yanetz ASG29's TRIG TT21 transponder with a TN72 GPS Source to use as a TABS ADS-B out system. That along with PowerFLARM in his glider makes for a pretty capable overall traffic awareness/collision avoidance system. Here is a screenshot of my portable Stratux ADS-B receiver (as would be used in many GA aircraft) receiving the ADS-B signal from the TT21 over 20 nautical miles away. Yes, it's a wave day out at Williams. https://drive.google.com/file/d/1Kik...SlslyEyMPo62Mu And again just an reminder, the TN72 is a ~$350 (+ GPS antenna + install costs) GPS Source that can easily be added to any Trig transponder to deliver ADS-B Out in your glider. (If you need full 2020 Compliant ADS-B Out it's a little more involved). This is low-enough cost that it will likely be a "just do it" choice for owners who already have a Trig transponder, and who especially want to provide more visibility to GA traffic (and it makes your glider visible to PowerFLARM buddies at much longer distances). Please expand on make/model antennae used and where it is located on G29. Too many antenna. 4 GPS and 2 FLARM within 30". We need a reliable way to split/share GPS signal off a single antennae. http://www.craggyaero.com/antennas.htm Bottom Page Richard www.craggyaero.com |
Great, now if we could get something like that for GPS. I have 3 GPS's now without ADS-B in out or sideways. Flarm, LX and Butterfly.
On Sunday, February 11, 2018 at 6:20:41 PM UTC-8, Richard Pfiffner wrote: Too many antenna. 4 GPS and 2 FLARM within 30". We need a reliable way to split/share GPS signal off a single antennae. http://www.craggyaero.com/antennas.htm Bottom Page Richard www.craggyaero.com |
So we're looking at:
$350 TN72 $321 GPS Antenna Combiner & cables for Flarm + GPS vario $671 Total before shipping. There's just barely enough room under my glareshield for 2 GPS antennae 30" apart. Without the combiner I'd have to wire the third antenna to my hat. I'm still entertaining the fantasy of mounting an L2 transponder antenna in the tail battery box of my 27 - and routing a fat enough coax there. I dread the thought of dirtying my 27 with an external transponder antenna. |
You can do a lot to merge GPS antennas you already have. Personally I would not be doibg that for a GPS source used to drive any type of ADS-B Out.
I just helped set up the Ramy Yanetz ASG29's TRIG TT21 transponder with a TN72 GPS Source to use as a TABS ADS-B out system. That along with PowerFLARM in his glider makes for a pretty capable overall traffic awareness/collision avoidance system. So Ramy is using the PowerFlarm for ADS-B In? What display? Is it linked to a moving map? Any significant limitations to that configuration? |
My ClearNav II displays ADS-B In targets generated by my PowerFlarm
portable unit. A question for Darryl (or a general whine):Â* My Stemme is exempt from the ADS-B requirement as a glider but, since it's a certificated aircraft, I probably can't use the TN-72 GPS with my TT22 transponder.Â* Is there any chance of such a system being installed in a certificated glider? Dan On 2/11/2018 5:01 PM, son_of_flubber wrote: On Sunday, February 11, 2018 at 6:04:37 PM UTC-5, Darryl Ramm wrote: I just helped set up the Ramy Yanetz ASG29's TRIG TT21 transponder with a TN72 GPS Source to use as a TABS ADS-B out system. That along with PowerFLARM in his glider makes for a pretty capable overall traffic awareness/collision avoidance system. So Ramy is using the PowerFlarm for ADS-B In? What display? Is it linked to a moving map? Any significant limitations to that configuration? -- Dan, 5J |
Trig TN72 Antenna | Andrew Ainslie | Soaring | 17 | April 6th 17 04:21 AM |
Trig TT21 for sale | [email protected] | Soaring | 2 | April 15th 16 06:35 PM |
Trig TT21 transponder for sale | Dave Springford | Soaring | 15 | September 7th 12 11:05 PM |
Trig TT21 transponder draws only 125 mA! | Steve Koerner | Soaring | 5 | March 15th 10 09:59 PM |
TRIG TT21 Transponders | Tim Mara[_2_] | Soaring | 12 | September 26th 09 02:01 AM |
