Ventus 3F - Fatal
Old July 21st 18, 02:15 AM posted to rec.aviation.soaring
WB
Default Ventus 3F - Fatal
On Friday, July 20, 2018 at 6:30:07 PM UTC-5, Jock Proudfoot wrote:
National Transportation Safety Board
Aviation Accident Preliminary Report
The glider was equipped with a FLARM electronic flight collision
alerting device, which records flight track, altitude, and airspeed.
About 11 seconds prior to impact with the ground, the glider entered a
left hand descending spiral at an airspeed of 48 knots, which continued
to ground impact.
https://app.ntsb.gov/pdfgenerator/Re...atorFile.ashx?
EventID=20180710X25659&AKey=1&RType=HTML&IType=FA
Doesn't really sound like a stall/spin from low altitude. Sounds more like the behavior of a glider trimmed for an off-field landing with no one at the controls.
  #32
Old July 21st 18, 04:18 AM posted to rec.aviation.soaring
Steve Koerner
to ground impact.
WB: In what way does it not sound like stall/spin? Secondly, what do you mean about trimmed for an off-field landing? I've never heard about trimming differently for an on-field landing vs an off-field landing?
Separate remark: Flarm does not record airspeed as stated in the report. It could be that airspeed was inferred from the spiral descent dynamics; but that seems more complicated than suggested by the brevity of this preliminary report.
  #33
Old July 21st 18, 05:19 AM posted to rec.aviation.soaring
George Haeh
Flarm obtains aircraft data from GPS and an internal static pressure sensor. Speed would be calculated from GPS position change and possibly altitude change yielding either 2D or 3D groundspeed, not airspeed.
Possibly wind aloft could be estimated from changes in groundspeed on different tracks and used to produce an airspeed, but any gusts would make a hash of such an estimate.
  #34
Old July 21st 18, 07:57 AM posted to rec.aviation.soaring
Mike the Strike
If you download the igc file from the Flarm into a program such as SeeYou, you will get a decent estimate of both ground speed and airspeed, presumably the latter calculated from the GPS ground speed, allowing for density altitude. I am assuming that the investigator was able to do this.
I examined Renny's previous two logged flights in the V3 at Moriarty and he maintained air speeds in excess of 60 knots on the descent to landing.
Given the good handling characteristics of the V3, I find it hard to believe that an experienced pilot like Renny misjudged his approach and entered a stall/spin and that some degree of pilot incapacitation seems more likely.
However, rather than speculate with incomplete information, perhaps we should wait for the final report.
  #35
Old July 21st 18, 10:15 AM posted to rec.aviation.soaring
I would have interpreted the mention of 48 knots as being a descent rate shown on the data recorder file (= around 880ft/11seconds).
  #36
Old July 21st 18, 03:34 PM posted to rec.aviation.soaring
jfitch
The report clearly says airspeed not descent rate. Default Flarm setting is 4 second fixes so 11 seconds represents at most 3 fixes. 11 seconds from normal flight to impact indicates a very low altitude no matter how you interpret it.
  #37
Old July 21st 18, 03:56 PM posted to rec.aviation.soaring
Mike the Strike
The previous two igc files of Renny's I looked at have the default 4 second recording interval. In these, it appears that he arrived back at Moriarty high and perhaps spoilered down, entering the pattern at around 1,000 to 1,500 feet AGL. In both of these landings, he maintained plenty of height and speed through his base and final turns, slowing down only on final just before touchdown. Of course, we have no idea what happened on his last flight, but his previous flights in the V3 show no signs of sloppiness that might result in loss of control.
  #38
Old July 21st 18, 04:02 PM posted to rec.aviation.soaring
FLARM does -not- report or calculate airspeed. The device only calculates positions from GPS fixes and has a pressure sensor to enhance that information, but any airspeed or groundspeed calculations are only speculative approximations from the GPS data in the logs. From the GPS fixes of itself and those transmitted from nearby aircraft it then calculates threat levels and warns you appropriately if necessary.
  #39
Old July 21st 18, 05:41 PM posted to rec.aviation.soaring
Another good reason to go to a 1 sec recording interval. Memory is cheap, why do people not use the best resolution our flight recorders offer?
  #40
Old July 21st 18, 06:12 PM posted to rec.aviation.soaring
George Haeh
In my glider the Oudie receives and records TAS and Groundspeed supplied by the Air Glide S in one second intervals.
The instrumentation may offer more complete data.
If you happen to have advanced varios, you might want to leave some notes on what data can be extracted if your family and fellow pilots are looking for answers.
Fatal this afternoon Gene Seibel Piloting 6 March 7th 07 09:22 PM
1 Fatal ...r.a.h or r.a.p? Montblack Piloting 81 February 12th 06 08:54 AM
1 Fatal ...r.a.h or r.a.p? Montblack Home Built 99 February 12th 06 08:54 AM
1 Fatal ...r.a.h or r.a.p? Montblack Piloting 38 February 9th 06 02:00 PM
Fatal at Omarama Philip Plane Soaring 0 January 12th 05 07:52 PM
