TAT scoring question
Old September 5th 04, 09:40 AM
Guy Byars
Winscore MUST see a gps trace to each and every turnpoint or turn area and
a
finish. IF Winscore does NOT see this trace, then it gives you a landout.
On A MAT, Winscore must see this trace between turnpoints claimed or you
will get a
landout. Winscore checks flight traces and turnpoints/ turn areas. Like
it.....
I have watched this thead with interest, and really wanted to keep out of
it, but this post forced me to jump in.
In your post you repeatedly say what Winscore can and can't do and what
Winscore requires of a flight trace. Winscore is one tool used by a scorer
to see if a US contest flight conforms to the published US rules. "Winscore
will land you out" if the rules specify a landout in such a situation.
"Winscore checks" was is required to be checked by the US rules. Any
deviation in Winscore's behavior from the US rules should be immediately
reported to me as a program problem.
And when, inevitably, Winscore does make an error scoring a flight, it gives
the scorer the tools to override and correct the analysis based on the
scorer and CD's judment.
Guy Byars
Winscore Author
  #32
Old September 5th 04, 05:58 PM
TomnKeyLargo
Yes, Guy, I assumed we are talking about WinScore being used at US contests.
This topic started from the bagging of turnpoints before the start. Current US
contest rules do not permit bagging of turnpoints before the start. to then be
used whenever a contestant wishes to slip them in. I was speaking of how
generally Winscore works, and of course it must be used by a qualified scorer
and CD, under US rules, when used in the U.S.A. I believe that when used in
this way, Winscore does what it is designed to do. My responce to this thead
came from the idea that contestants were thinking of a way to get around the
rules for a unfair advantage. I believe that we, the contestants, all want a
""level playing field"" and this is what is given us by the US contest rules.
Our US contest board, along with you, have worked very hard to give us what we
have today. A good progam which has "checks" and "balances" for our racing
needs. I do not know everything Winscore can and cann't do, and as you know,
earlier this year I spoke with you about a start problem seen by a contest
scorer and contest manager. I have been told that this problem now has been
corrected. That's great and I thank you for your help. At the contests I have
been at over the last few years, most scorers, when their time permits, are
glad to show you how they perform their work. Most CD's are willing to speak
with you over the rules when their workload does permit. As new contestants are
needed for our sport to grow, I suggest to them that when they do go to
contests, they speak with their mentors, or contest officals to "clear their
thoughts" on the US rules, so all of us can have a "level playing field". #
711.
  #33
Old September 6th 04, 12:33 AM
Andy Blackburn
I think there's some confusion about the term 'before
the start'.
The point that was being made was that under certain
circumstances it might be advantageous to make a start
(after the task is opened), fly some sequence of legal
turnpoints, return and fly through the finish cylinder
and the go out and fly some more to accumulate more
speed/distance.
Under a MAT this looks just like any other flight that
happens to include the finish point as a legal turnpoint,
at least from a scoring perspective. It is debatable
as to whether this would ever be something you would
plan to do ahead of time given all the operational
constraints, landout risks, etc. There was also a debate
as to whether calling '4 miles' and 'finish' necessarily
makes null and void any subsequent flying (I say no
- you can keep flying legally).
Under a TAT, this would only appear to make sense if
the whether is very unpredictable, you are well under
time AND it you are able to stay aloft near the finish.
I would think the final turn area would need to be
pretty close to home as well. In this case you are
going back out either to finish off a turn area you
missed or go deeper into the last one under improved
WX conditions. Seems legal to me - but may not be profitable
very often.
I can't think of an AST task circumstance where this
makes any sense, since the distance and turnpoints
are pre-determined.
9B
can't do and what
US rules. 'Winscore
will land you out' if the rules specify a landout in
such a situation.
'Winscore checks' was is required to be checked by
the US rules. Any
''level playing field'' and this is what is given us
have today. A good progam which has 'checks' and 'balances'
for our racing
seen by a contest
when they do go to
officals to 'clear their
thoughts' on the US rules, so all of us can have a
'level playing field'. #
711.
  #34
Old September 6th 04, 01:42 AM
Jonathan Gere
Gary Ittner wrote in message ...
So, did you deliberately prevaricate when you stated that, according to
the rules, a start or finish is invalidated by the lack of a radio
announcement?
No, I sincerely misunderstood how the rules committee intends the
rules to be read. There is an outline level heading for each type of
start and finish. In the same hierarchical position for each type are
a paragraph *requiring* certain communications and a paragraph
*requiring* certain flight paths. It is natural to me to assume they
are both essential parts of the procedure to get a start or finish.
Especially, if the consequence of assuming the opposite is a goofy
loophole, blocked only by a top pilot's assurance that it is
unprofitable!
If I understand the rules of construction correctly, based on your
clarifications, not making required communications is against the
rules, but has no bearing on being scored for speed points, and only
might/may be penalized at CD discretion. Apologies to anyone I
ignorantly misled into following the rules unnecessarily.
I think all this falls into the category of an "oral tradition" rather
than a "tight" racing rule. Leaving out the deliberate prevarication
you suspect of me, see that eager racer 711 quite misunderstands the
rules as you see them regarding my useless loophole. Luckily, not
understanding (or reading) the rules is traditional in soaring. My
impression is that to arrive at the "accepted" interpretation of our
rules requires in turn both mind boggling chains of logic and literal
reading in some places and the ignoring of loopholes and literal
contradictions in other places in favor of common sense. I cited some
examples in earlier posts. And no I don't think I could write them
better, if you are tempted to reply with the standard "why don't you
volunteer to write the rules if you think they aren't perfect".
When the rules introduced this multi-task in progress possibility, it
would have been nice had it been noticed, and the theoretical
possibility discussed, along with how useless the best pilots find it.
But it seems to me that it was overlooked. I think that if you rule
writing, contest winning experts had considered and ruled out this
stuff as harmless in advance, such a seemingly important, but
inconsequential, major change would have been explicitly covered in
the explanatory material.
I find the ability to be on multiple provisional starts / finishes /
tasks simultaneously an absurd consequence of the rules.
And I do not.
It is little
comfort to me to have your assurance that it is strategically useless.
It is of great comfort to me. I believe there may an infinite number of
useless strategies for flying any of the tasks. One of the main purposes
of the rules is to ensure fair competition, but I see no benefit in
making our rulebook infinitely longer by specifically prohibiting every
strategy in which a pilot cannot gain an unfair advantage, or indeed any
advantage at all.
I'm shocked. This is weird. I don't believe that all variations of
this loophole are strategically useless. The 4 times around example
is just a good example of the absurdity of the loophole. Operational
exploitations can be much more profitable.
In practice, one could just prepend optionally claimable S-one or more
TPs- Home TP-S combinations without going low to finish. Cheap
insurance against gross or possibly even minor undertime.
The insurance excursions would occur before the final start intended
to bracket the *expected* day. The insurance excursions would absorb
any inefficiency in getting ready for the "perfect" optimized start.
If not claimed, the excursions imperfect efficiency wouldn't matter.
On the other hand, 1hr at even 80% efficiency is a lot better than
nothing, when everyone else finished an hour undertime due to an
*unexpected* thunderstorm. 30 minutes at 90% efficiency might be
worth claiming to avoid a routine 5-10 minute undertime (at 0%
efficiency).
I will admit that it is not entirely impossible that you could gain by
this strategy, but the phrase "extremely unlikely" does not seem
powerful enough to describe it.
To recap, your insurance lap would only be useful with a no turn MAT
(rare nowadays), called on a day with no expected weather problems (when
other, less flexible tasks are *far* more likely to be called; no turn
MATs are usually called specifically because there are expected weather
problems), all of your competitors start (what turns out to be) too
late, and along comes a weather problem too severe for the flexibility
of the MAT to deal with. I'd call it a one in a million chance.
And I don't agree that this insurance is cheap; you simply haven't
calculated the cost. You might have to try this insurance lap trick many
times before the proper conditions arise to make it useful, and:
1. You might land out while your competitors are safely back near the
contest site playing start gate roulette. Believe me, I know what it
feels like to land out before one's expected start.
2. The conditions could change while you are on your insurance lap,
causing everyone else to start en masse before you get back for your
expected start. Even on a no turn MAT, there is often only one obvious
direction to go. Your competitors will have thermal markers, and you
will have none.
3. Even when the proper combination of conditions comes along, you
cannot be sure all of your competitors will start late. If one starts
early, he will have the advantage over you of being able to place a
higher proportion of his flight in the area of best lift. Your insurance
lap will necessarily be close to home, and, in my experience, that is
rarely where the best soaring conditions are located.
The premium you pay for your insurance lap is much higher than the
potential claim payout.
Thanks. You admit the loophole. I leave it to better pilots to work
out the operationally sound strategies.
And if there are no operationally sound strategies, is it still a
loophole?
Gary Ittner P7
"Have glider, will race"
Yes. Because the long shot pilot whose "policy" pays off does not
have to have good long term prospects to screw up a day's scoring (his
outstanding performance effectively further devaluing the day by
reducing the point spread between the contending, undertime top dogs
following good strategy.)
Yes. Because pilots should understand what the rules permit and either
come to their own conclusions about what to do, or just sensibly
accept the experts' advice on the subject.
Thanks for sharing your keen racing strategizing, and for responding
to the issues I raised. I feel that many racers would not be as
comfortable as you are with this "non-loophole" (if they knew it
existed). Like JJ they might think anyone that did it was cheating.
Me to! But I also believe that like the illusion of the witch and the
beautiful woman, log files show both the "cheating" and the normal
racing re-starts, and the two are not always objectively
distinquishable.
Jonathan Gere 34
  #35
Old September 6th 04, 04:55 AM
Kilo Charlie
Disclaimer....this post has very little to do with the current discussion:
Guy....you have an outstanding scoring program so I for one would like to
say thanks and want to let you know how appreciative most of us are that you
have spent so much time perfecting it!
711 and 9B...where the heck are you guys this weekend??? We expected to see
both of you for the Southwest Championship races! It has been miserable
conditions for this time of year and wish that you all could have shared it
with us. Besides it is obvious from your multiple posts that neither of you
had much going on to keep you from coming to Arizona! ;-)
Casey Lenox
KC
Phoenix
Legal question - Pilot liability and possible involvement with a crime John Piloting 5 November 20th 03 09:40 PM
Special Flight Setup Question (COF) Dudley Henriques Simulators 4 October 11th 03 12:14 AM
History of Contest Scoring Bill Feldbaumer Soaring 8 October 8th 03 02:14 PM
new TASKs and SCORING - or roll the dice CH Soaring 0 August 10th 03 07:32 AM
