Looking for A-14 (or similar) pressure breathing diluter demand regulator
Old December 19th 18, 03:34 PM posted to rec.aviation.soaring
Default Looking for A-14 (or similar) pressure breathing diluter demand regulator
The diluter-demand function of the A14, from what I have read, occurs below a certain altitude, 30,000' if I recall correctly. In this mode the mixing chamber mixes cabin air with O2 and the amount of O2 increases with altitude. Above this altitude it supplies 100% O2. The pressure breathing function is a separate function that has different dial settings for increasing altitudes. Here the pressure of the O2 supplied not the mixture to the mask increases. The markings on the A14 dial suggest 5 different pressures for settings of Safety, 41,000', 43,000', 45,000', & above 45,000'. Not sure why the 1st dial setting is marked Safety but it is the 1st position when the dial is turned off normal.
I've read the same about blood boiling. I think, as you have pointed out, they are referring to an uncontained and uncirculating liquid and meant to make a point about how low the pressure is. Articles I've read also use statements like "seems to boil" instead of boils. I guess the body can contain the vapor pressure sufficiently so it doesn't reach atmospheric pressure and really boil. Apparently the skin will expand and early experiments with dogs in space or a vacuum chamber discovered this. Saliva boiling on the tongue makes sense.
I do plan to get experience in a hypobaric chamber and am hoping they will let me use my own mask, regulator, and bottle however, I suspect this might be considered a liability for then to allow. I still plan to ask. What better way to test the performance of the system I intend to use at FL350-400!
  #32
Old December 19th 18, 05:44 PM posted to rec.aviation.soaring
Just updating my initial post with availability and cost of New Surplus (NS) A14 regulators manufactured by FPI in 1990 with part #1550. These are new in the original OEM packaging. Stock is currently 10 units and the cost is $600 per unit. Let me know if anyone needs a unit and I will put you in touch with the shop in CA that is stocking these. Also, if anyone knows of a shop that can overhaul these units besides FPI, and especially someone out west, please advise.
VVII
  #33
Old December 19th 18, 07:20 PM posted to rec.aviation.soaring
BobW
Default Looking for A-14 (or similar) pressure breathing diluter demandregulator
FWIW...
Everything I've read (inhaled, unavoidable pun) since the early 1970s -
primary source: "Soaring" mags" (multiple/excellent "near-first-hand"
articles/columns throughout '70s/'80s) - said the same thing(s). Nothing on
RAS to which I lend credibility (i.e. "hearsay" seriously discounted) has
contradicted any of the above, since my RAS-introduction/continuing-exposure
ca. '96.
be considered a liability for them to allow. I still plan to ask. What
FL350-400!
That's "exactly" what the late Bill Ivans (ca. '92) told me he did in the
years after WW-II before setting the world-altitude soaring-record (42,100',
as I seem to recall; '52?) that Paul Bikle broke (1961); memory sez both were
set in Schweizer 1-23s. Excerpts of my tape-recorded interview with Ivans
about those years of his soaring can be found in the book "Exploring the Monster".
Kinda-sorta related, I also interviewed (several times) Dr. J. Kuettner
(credited with the "scientific discovery" of standing lee waves, & Lead
Investigator of the subsequent Sierra Wave Projects), about: wave; his
experiences in same; his involvement(s) in illuminating waves' atmospheric
physics; his perception of "existing knowledge" of high-altitude physiology in
the timeframe ~'35-'55; etc.
My takeaways from my brain-picking - and a "chamber ride" ca. early-'80s) -
were/remain several...
- humans are physiologically complex critters, and one size definitely does
NOT fit all; almost certainly YMWV
- any "cast in concrete" safety claims regarding "high-altitude (say 35k'),
unpressurized-cockpit, supplementally-O2-assisted" flight beyond "It's
definitely life-threateningly risky," are likely misleading/inaccurate. "Back
then," high-altitude human physiology was FAR from being "pigeon-holed by
science" in "absolute safety" terms, and in a related vein,
"personally-derived high-altitude limits" seemed to be the accepted norm, at
least among the Sierra Wave Project participants. (Anecdotes below...)
Bill Ivans couldn't remember exactly how high he'd been taken in his chamber
ride, but "definitely" above 40k' (possibly 46k'). Without digging into
ancient notes, I can't remember how-high he set his personal limits prior to
his record-setting altitude flight, but I DO remember him chuckling that the
flight completely satisfied his "altitude curiosity!" I took that to mean he
felt he'd no continuing need to soar "near the physiological edge" going
forward. His job prevented him from piloting during the Sierra Wave Projects,
and I don't know if he was sounded out about doing so or not, but had he been
able, my long-after-the-fact guess was he might've declined.
The long-standing 2-seater world-soaring-altitude/gain flight of ~42k' set in
a Pratt-Read by Larry Edgar and Hal Klieforth (broken by Einar Enevoldsen and
the late Steve Fossett, I believe), had been intended to go no higher than
40k', the nominal limit the Sierra Wave Project soaring participants
pre-selected as their safety-limit for physiological reasons. The extra height
was due solely to the search time required to find descending air, once the
crew had decided "enough for today."
None of the Sierra Wave Project pilots could remember, or admitted to, any
"serious physiologic issues" on/after any of their high-altitude forays
(intestinal gas and cold temperatures notwithstanding). They all practiced
"best practices" before/during each flight, e.g. dietary choices, sleep
practices (not always hewed to, per Dr. K., commonly becuzza the need to
change-out batteries post-flight during a spell of more-or-less-daily standing
waves good for research), pre-breathing 100% O2, etc.
My sense is much of the "high-altitude-physiological-related" institutional
knowledge within the general sport-soaring world (U.S. anyway) has been
gradually lessened/lost due to the passage of time/aging/decreasing
availability of high-altitude chamber access for civilians/etc., to be
"commonly replaced" by a generation of pilots having distinctly different
norms for acceptable risk than the WW-II and immediately-following generations.
Insofar as deciding to take up a voluntary sporting activity (soaring, in this
case), some level of general ignorance is normally the beginning state.
Sometimes (often?) this natural ignorance is expressed in
needlessly/misguidingly stated maxims that quite simply are incorrect. This -
IMHO - is fairly common regarding high-altitude soaring flight...which is
definitely increasingly-seriously risky with increasing altitude, but those
risks are "adequately comprehensible and systematically-addressable," as
(thinks I) the history of post-WW-II high altitude soaring in the U.S. well
documents.
Personally, have at it and may good fortune accompany your preparations!
Bob W.
This email has been checked for viruses by AVG.
https://www.avg.com
  #34
Old December 19th 18, 10:05 PM posted to rec.aviation.soaring
Wow, thats quite some history Bob! I need to read up on wave history a lot more! Did you ever track any of the flights from up in Cowley, Alberta at the so called Diamond Mine? I had my 1st wave flight there about 9 years ago and I was hooked! I also learned a few new acronyms from you-FWIW and YMWV I could decipher but RAS? Silent Leader? Appreciate all your comments and I do look forward to a chamber ride before committing to anything above FL300! This is purely a recreational pursuit and one of several gliding challenges for me but it's definitely not to be taken lightly as my two favorite aviation sayings remind me......1) takeoffs are optional but landings are mandatory &...... 2) I'd rather be on the ground wishing I was in the air than (very high) in air wishing I was on the ground!
VVII
  #35
Old December 19th 18, 10:56 PM posted to rec.aviation.soaring
FWIW.....for what it's worth
YMMV.....your mileage (situation) may vary
RAS......recreational aviation....Soaring...(this forum where you're posting...)
  #36
Old December 19th 18, 11:07 PM posted to rec.aviation.soaring
Got the 1st two. RAS, of course-too obvious!
VVII
  #38
Old December 20th 18, 12:58 AM posted to rec.aviation.soaring
Yes, I met Ursula. She's married to Tony Burton an active CuNim pilot. I have the book as well but mine is not autographed! Cowley is THE wave destination in Canada.
Wonder if that L-13 you picked up was from CuNim? They sold one to Lee Cook I think flying out of Crystal. ISK if I'm not mistaken. I trained in that ship and I heard it got written off not long after it arrived in CA. Most of the L13s were grounded soon after that. Great 2-place workhorse.
VVII
  #40
Old December 22nd 18, 08:08 AM posted to rec.aviation.soaring
Fuzzy memory says the pickup was in BC (Hope?), ultimately destined for
Oklahoma...
Bob W.
https://www.avg.com
Your fuzzy memory is correct about Hope. You picked up the Vancouver Soaring Associations L-13 C-GZEU. Dearly loved and much missed by me - and many others in the club. It was the first glider I ever flew in, I did my first solo and also made my first flight as a licensed pilot in that ship too. She was essentially timed out though as Transport Canada enforced the factory life limits and getting an extension of 250 hours would have been financially prohibitive. I remember coming out to the airport so you could pick her up. Sorry to hear about the re-entry difficulty and I certainly wish the wing AD hadn't grounded the L-13 a few years later.
I also remember being surprised that the guy who wrote a series of books that I had read multiple times was one of the guys who came to collect the glider!
Pressure breathing O2 regulator these days? Bob Kuykendall Soaring 11 November 16th 14 11:48 PM
A-14 Diluter Demand Regulator with blinker, tank, bailout bottle flgliderpilot[_2_] Soaring 0 July 18th 14 04:55 AM
Fuel Pressure Regulator for Aviation DonMorrisey Home Built 2 March 23rd 07 03:00 AM
Scott oxygen mask and diluter demand regulator for sale nzuri Soaring 0 October 5th 03 08:18 AM
Scott oxygen mask and diluter-demand regulator for sale in UK nzuri Soaring 0 September 28th 03 10:46 PM
