#31
OK, this is going to get good.
Eric thinks wide fast turns work best for him. I think 45 degree turns are best on average with steeper turns useful in small cores. If fly as slow as I can without risking a stall. Lets have a poll. Tell us how you thermal. Bill Daniels |
#32
Bill,
I try to fly, if the conditions warrant it, a 45 deg. bank my wing loading is 8.3 lb/ft/sq at that bank my turn will be 22 seconds. My speed will be 52 kt. indicated. Udo PS. I will check some of my contest recordings to make sure my memory is still ok. Also I open up the turn when more lift is indicated and tighten when less lift. I use the Borgelt and I react to the trend, that is when the needle or sound just start coming out of the bottom or falling off. Works for me like a charm. Udo "Bill Daniels" wrote in message news:2bidd.499463$8_6.239366@attbi_s04... OK, this is going to get good. Eric thinks wide fast turns work best for him. I think 45 degree turns are best on average with steeper turns useful in small cores. If fly as slow as I can without risking a stall. Lets have a poll. Tell us how you thermal. Bill Daniels |
#33
Bill,
a small correction, wing loading remains 8.3 lb/ft/sq, average time around the circle 25 second at 50 kt Ground speed. Bank of between 40 and 45 deg. I use the Instrument screws as reference. I have a number of recordings. If any body cares to look at them let me know and I will send an http. Udo Bill, I try to fly, if the conditions warrant it, a 45 deg. bank my wing loading is 8.3 lb/ft/sq at that bank my turn will be 22 seconds. My speed will be 52 kt. indicated. Udo PS. I will check some of my contest recordings to make sure my memory is still ok. Also I open up the turn when more lift is indicated and tighten when less lift. I use the Borgelt and I react to the trend, that is when the needle or sound just start coming out of the bottom or falling off. Works for me like a charm. Udo "Bill Daniels" wrote in message news:2bidd.499463$8_6.239366@attbi_s04... OK, this is going to get good. Eric thinks wide fast turns work best for him. I think 45 degree turns are best on average with steeper turns useful in small cores. If fly as slow as I can without risking a stall. Lets have a poll. Tell us how you thermal. Bill Daniels |
#34
Bill Daniels wrote:
OK, this is going to get good. Eric thinks wide fast turns work best for him. "Fast" is relative: at 8.2 lb/sq ft, going a slower is counterproductive. I can slow down to 45 knots from the usual 50, but the glider isn't very steady, feels "draggy", and it doesn't climb any better, even in very smooth thermals (this measurement done when circling with other gliders). In anything but very smooth thermals, the 50-52 knots is needed to have decent control, anyway. I think 45 degree turns are best on average with steeper turns useful in small cores. If fly as slow as I can without risking a stall. This may be appropriate for the Nimbus 2, but not for the ASH 26, where the stall is noticeably lower than minimum sink. Waibel told me once that he considers this a safety feature. Lets have a poll. Tell us how you thermal. And what, and where. These are likely important reasons for your bank angle and speed preferences. Bill Daniels -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
#35
![]() "Eric Greenwell" wrote in message ... Bill Daniels wrote: OK, this is going to get good. Eric thinks wide fast turns work best for him. "Fast" is relative: at 8.2 lb/sq ft, going a slower is counterproductive. I can slow down to 45 knots from the usual 50, but the glider isn't very steady, feels "draggy", and it doesn't climb any better, even in very smooth thermals (this measurement done when circling with other gliders). In anything but very smooth thermals, the 50-52 knots is needed to have decent control, anyway. I think 45 degree turns are best on average with steeper turns useful in small cores. If fly as slow as I can without risking a stall. This may be appropriate for the Nimbus 2, but not for the ASH 26, where the stall is noticeably lower than minimum sink. Waibel told me once that he considers this a safety feature. Lets have a poll. Tell us how you thermal. And what, and where. These are likely important reasons for your bank angle and speed preferences. I just examined some IGC traces of mine and, correcting for density altitude, the IAS was about 43 mph in what looks like a 40 - 45 degree bank. I'm still looking for a representative climb in a small, strong core but I think I should have one from Moriarty, NM. The Nimbus 2C ailerons become very ineffective at low IAS but it still responds nicely to rudder inputs. I use Dick Johnson's slipping turn so the ailerons stay neutral and I fly the bank with rudder. The big glider is very stable in slow turns. If there's a strong core, I'm not concerned with sink rate in slow, steep turns. The strength of thermal cores will easily offset that. Bill Daniels |
#36
Actual SeeYou measurements
ASW-27B dry (8.2 lbs/sf) Altitude 13,000 ft TAS/IAS: 71/53 mph Measured radius: ~350 ft Implied bank angle: 43.5 degrees Stall speed (calculated): ~51 mph ASW-27B wet (11.5 lbs/sf) -- prior day Altitude 13,500 ft TAS/IAS: 84/61 mph Measured radius: ~515 ft Implied bank angle: 42.5 degrees Stall speed (calculated): ~57 mph 9B At 03:06 20 October 2004, Eric Greenwell wrote: Bill Daniels wrote: OK, this is going to get good. Eric thinks wide fast turns work best for him. 'Fast' is relative: at 8.2 lb/sq ft, going a slower is counterproductive. I can slow down to 45 knots from the usual 50, but the glider isn't very steady, feels 'draggy', and it doesn't climb any better, even in very smooth thermals (this measurement done when circling with other gliders). In anything but very smooth thermals, the 50-52 knots is needed to have decent control, anyway. I think 45 degree turns are best on average with steeper turns useful in small cores. If fly as slow as I can without risking a stall. This may be appropriate for the Nimbus 2, but not for the ASH 26, where the stall is noticeably lower than minimum sink. Waibel told me once that he considers this a safety feature. Lets have a poll. Tell us how you thermal. And what, and where. These are likely important reasons for your bank angle and speed preferences. Bill Daniels -- Change 'netto' to 'net' to email me directly Eric Greenwell Washington State USA |
#37
![]() "Bill Daniels" wrote in message news:2bidd.499463$8_6.239366@attbi_s04... Lets have a poll. Tell us how you thermal. Bill Daniels I do whatever it takes to make the averager number bigger! What that might be depends on whether I am at Truckee or Ely or Williams; whether the lift is turbulent or smooth, big or small core, alone or with other gliders, with or without water, bugs on the wings, etc. The correct bank angle and speed might change from one side of the circle to the other and is changing, experimenting, trying to iterate the best possible lift. When I see another glider climbing better in another part of the thermal, I just go there! It really matters that the climb rate is as high as possible in each climb taken. When I fly with others in our DuoDiscus I am amazed at how carefully many pilots follow the speed director (which is on a 30 second averager) in cruise, but climb sloppily and lazily, accepting whatever comes and not actively searching for the best thermals and using them to the max. Maximizing climb and avoiding sink are the best ways to cover miles (or km.). Interthermal glide speeds are relatively unimportant. Of course, most of this is just experience -- many hours of flying and thermalling -- and better learned in thermals than on Usenet... -Bob Korves 5H DuoDiscus 5K LAK-17a |
#38
Won't SeeYou underestimate the thermalling speed because it is
calculating speed based on the straightline distance between different points on a circle? Andy Blackburn wrote: Actual SeeYou measurements ASW-27B dry (8.2 lbs/sf) Altitude 13,000 ft TAS/IAS: 71/53 mph Measured radius: ~350 ft Implied bank angle: 43.5 degrees Stall speed (calculated): ~51 mph ASW-27B wet (11.5 lbs/sf) -- prior day Altitude 13,500 ft TAS/IAS: 84/61 mph Measured radius: ~515 ft Implied bank angle: 42.5 degrees Stall speed (calculated): ~57 mph 9B |
#39
I don't believe in a shallow bank for 180 degrees. The trade off in efficiency is more than offset by getting out of the sink and into the lift quicker. Reichman's rules: Increase bank in sink, shallow bank as vario rises, increase bank in lift. My numbers say min sink is 44 ktws, 30 degree min sink is 49, 45 is 52, and 60 is 63 kts. If themals are tight and narly, then crank 45-60, decreasing with altitude as thermals generally widen. Like many here, the screws on the instruments are the 45 degree indicator (a golden nugget from a CSA instructor). I would rather increase my airspeed than shallow the bank since the increase in airspeed effectively increases the turn radius with minimal drag effects and low time lag. To me, crankin and bankin to get into the best lift is worth it...plus much more fun! Jim Vincent N483SZ illspam |
#40
I used to think that I could climb faster with steeper turns in the
strongest part of the thermal, but after flying with the some of the best open class pilots in the USA, and seeing them outclimb me, it seems to me that lower bank angles, 30-45 degrees, and slower speeds are better than tightening up in the core and using steeper banks angles, and higher IAS. Maybe this isn't as true with 15m wings. I have seen days though, when you couldn't even climb if you didn't wrap it up hard and use bank angles of at least 60 degrees or more. It may not always be the most efficient, but I do think it's fun to circle at very high bank angles for a few turns, or more once and a while. It is such a rush to just stand a sailplane on it's wing., and climb at 3 or 4+ g's! Gary Boggs "Jim Vincent" wrote in message ... Lets have a poll. Tell us how you thermal. I don't believe in a shallow bank for 180 degrees. The trade off in efficiency is more than offset by getting out of the sink and into the lift quicker. Reichman's rules: Increase bank in sink, shallow bank as vario rises, increase bank in lift. My numbers say min sink is 44 ktws, 30 degree min sink is 49, 45 is 52, and 60 is 63 kts. If themals are tight and narly, then crank 45-60, decreasing with altitude as thermals generally widen. Like many here, the screws on the instruments are the 45 degree indicator (a golden nugget from a CSA instructor). I would rather increase my airspeed than shallow the bank since the increase in airspeed effectively increases the turn radius with minimal drag effects and low time lag. To me, crankin and bankin to get into the best lift is worth it...plus much more fun! Jim Vincent N483SZ illspam |
Themi thermal locator | John Jones | Soaring | 5 | April 30th 04 04:16 AM |
For Auction: Thermal Imaging Camera - One Day Left | sell2all | Rotorcraft | 0 | April 29th 04 08:29 PM |
For Auction: Thermal Imaging Camera - One Day Left | sell2all | Military Aviation | 0 | April 29th 04 06:45 PM |
Spin on thermal entry - how-to | Bill Daniels | Soaring | 0 | January 29th 04 05:43 PM |
Thermal to Wave contact! | C.Fleming | Soaring | 1 | January 21st 04 01:54 PM |
