Some LiFePO4 Battery Testing Results Manual and Automated
Old April 18th 19, 02:58 AM posted to rec.aviation.soaring
Default Some LiFePO4 Battery Testing Results Manual and Automated
Every year I test my two LiFePO4 batteries to gauge how long they will last during a flight. I decided to open the field a bit and also tested some soaring friend's batteries.
You can read about my simple cheap manual process (later automated - see below) here http://aviation.derosaweb.net/#batterytest which was also detailed in Soaring (Feb 2012). Yeah, I know there are automated testers on the market but I want to create something cheap that everyone can make.
My battery go/no-go is how long it will take for the battery to drop to 12.0Vdc with a continuous 12Ω (~1A) resistive load. Here is what I found;
2013 Bioenno Model BLF-1209T- 6.5H
2015 Stark Model SP-12V9-EF - 5.5h
2015 Bioenno Model HN12V9AHF- 7.0H
2017 Bioenno model BLF-1209WS - 9.0H
Full details of my results can be found here http://aviation.derosaweb.net/batter...s_04.08.19.pdf
Anyone else tested their batteries in this same way? What are your results?
Automation - Manually gathering data every 10 minutes for 6-9 hours on four different batteries is tedious at best. I watched a lot of movies. So I decided to automate the process with an cheap $10 Arduino Duo. The Arduino software takes a reading at different points of time based on the current voltage. Every one minute at the beginning and end of the test, and every 10 minutes in the middle.
It still takes 6-9 hours to run the test but recording the voltages is fully automated so running the test is a start-then-walk-away-and-come-back-later-for-the-findings kind of deal. Luckily with the LiFePO4 batteries when they get below ~11.0Vdc the BMS basically shuts the battery off. The program detects any voltage drop below 8Vdc and terminates itself.
If anyone is interested in duplicating my Arduino test rig, drop me a line and I will share the details. My Arduino code can be found at http://aviation.derosaweb.net/batterytest/arduino.
John OHM Ω
Test results LiFePO4 glider batteries after 6 years SF Soaring 102 August 9th 18 06:46 PM
Resetting a Bienno LiFePO4 Battery OHM Ω http://aviation.derosaweb.net Soaring 3 June 26th 18 09:26 PM
LiFePO4 battery technolocy [email protected] Soaring 9 October 17th 12 10:05 PM
LiFePO4 battery ASM Soaring 4 December 6th 11 07:00 PM
Spring Cleaning and Battery Testing ContestID67[_2_] Soaring 34 March 20th 11 06:49 PM
