Fueling from plastic gasoline containors
Old March 2nd 05, 02:25 PM
Corky Scott
On Tue, 1 Mar 2005 23:50:28 -0500, "Morgans"
You know how some people with cars put hi octane in, thinking it is going to
get them better performance? Waste of money, since no more power is
produced, without re-tuning the engine, but no problem.
Unless it's one of those engines that has computer controlled
individual cylinder timing using a knock sensor. Those things will
retard the timing if knocking is sensed, and advance the timing as far
as possible when knocking is not sensed.
I remember seeing a Saab with such a system being dynoed using regular
first and then high test. The engine gained some power, although I
don't remember the exact figures. I just remember that it did gain
some.
With engines that do not have constantly adjusting timing, you are
correct, using high octane gas won't make any difference in power.
Corky Scott
  #32
Old March 2nd 05, 05:02 PM
Marv
Some links that may be of interest on the subject of static
discharge while fueling:
http://www.faa.gov/avr/afs/news/arch...ch/Static1.htm
http://www.faa.gov/avr/afs/news/arch...ch/Static2.htm
http://www.faa.gov/avr/afs/news/arch...ch/Static3.htm
http://www.globalair.com/discussions...cle~/msgID=237
3 of the above articles are at:
http://www.faa.gov/avr/afs/news/archive/march.cfm
  #33
Old March 2nd 05, 07:01 PM
jls
I have been fueling for years with plastic containers. As the first link
(from FAA) recommends, the fuel container nozzle is inserted into the tank
opening before fuel begins to flow, and the container nozzle continues
contact with the aircraft fuel tank throughout the process. I have never
seen a spark or had a fire, but always keep a halon fire extinguisher handy.
The aircraft is, of course, never refueled in the hangar. It is always out
on the ramp away from buildings, vehicles, and other aircraft.
That's not to say that a grounding wire should not be used.
"Marv" wrote in message
  #34
Old March 2nd 05, 11:06 PM
Morgans
Corky Scott
Given the fact that most airplane engines don't even have the most basic
advantage, even of vacuum advance, I didn't think that was a very important
factor. g
Good point, but most will only advance within a certain set of parameters.
I doubt if it would be enough to take advantage as much as if you changed it
manually.
Life rules state that there are always exceptions to the rules, right?
FS: Revell Monogram "F-14A Tomcat" Plastic Model Kit (1:48 Scale) J.R. Sinclair Aviation Marketplace 0 August 16th 04 05:59 AM
The answer to the gasoline problem Veeduber Home Built 4 May 22nd 04 08:58 PM
FAR Reference - Self Fueling Ben Smith Owning 8 April 8th 04 11:07 PM
$3.00 a gallon gasoline by summer(read all of this, it just might work) Fastglasair Home Built 8 March 10th 04 12:12 AM
Repairing Plastic Jay Honeck Owning 5 February 2nd 04 09:20 PM
