Cobra Trailer Fenders
Old November 25th 19, 06:30 AM posted to rec.aviation.soaring
2G
Default Cobra Trailer Fenders
On Sunday, November 24, 2019 at 5:51:34 PM UTC-8, Tom BravoMike wrote:
On Sunday, November 24, 2019 at 6:29:31 PM UTC-6, wrote:
It hurts to replace tires that look like new, but....
Just buy new tires every five years.
Rubber rots.
All tire manufacturers advise replacing tires at five years.
It is not my in intention to argue about the usefulness or necessity of changing tires every 5 or 6 years - sounds reasonable - but I would like to hear from some independent source, maybe an automobile club like AA or RAC or similar, provided not corrupted by lobbyists. Maybe the German 'Stiftung Warentest'?
https://www.test.de/
Don't smartphone manufacturers suggest we should buy a new phone every 2 years, a new TV set every 4 years. Shouldn't houses be built for just one generation so that the construction industry can go on and on? Isn't it farmers who advertise: Drinka pinta milka day?
I did post such a reference - go back and read it.
  #32
Old November 25th 19, 02:42 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Tim Taylor wrote on 11/24/2019 9:42 PM:
"The NHTSA recommends that tires be replaced every six years regardless of the number of miles driven. Proper inflation is the Holy Grail of tire maintenance. Too much or too little air in your tires is guaranteed to cause you trouble and uneven or excessive wear over time.Dec 17, 2013"
The current recommendation is not so strict (2017):
"As tires age, they are more prone to failure. Some vehicle and tire manufacturers
recommend replacing tires that are six to 10 years old, regardless of treadwear.
You can determine how old your tire is by looking on the sidewall for your DOT
Tire Identification Number (TIN)."
https://www.nhtsa.gov/equipment/tires#topic-aging
  #33
Old November 25th 19, 02:47 PM posted to rec.aviation.soaring
I shattered a plastic Cobra fender when my ASW 24 was less than a year old. Not impressed. I replaced them with galvanized steel fenders from (then) Northern Hydraulics. Salvaged the mud flaps from the plastic junk and tossed the wheel chocks in the front of the trailer where no one would walk away with them in a parking lot. I've since lost two tires (we've had the tire discussion many times so do what you like) and damaged a fender both times. I just banged it back out. I do need to replace them now (they're 25 years old and stained/bent) but I'll just get another set of cheap metal fenders. You'll probably have to drill a few holes but no big deal.
Just my opinion. But $300 for a set of plastic fenders that will break the first time you hit debris or blow a tire? Please. I'm willing to baby the glider. The trailer I want to be bulletproof. Poor choice of words.
Chip Bearden
JB
  #34
Old November 25th 19, 03:03 PM posted to rec.aviation.soaring
Something I never knew about tyres - from the Uniroyal website:
"tyres contain anti-oxidising chemicals which significantly slow down the rate of ageing, this wax-like substance is only released when the tyre is in motion. Therefore, if the tyre is not used frequently or is stored away ineffectively, they will age more quickly rendering them unroadworthy when returned to use"
  #35
Old November 25th 19, 04:23 PM posted to rec.aviation.soaring
Tom BravoMike
So I did go back and read your posts. I found this link you left:
https://www.discounttire.com/learn/tire-aging
You don't consider this to be an independent source, do you? I apologize if I'm missing something. Please help.
Happy Thanksgiving, anyway!
  #36
Old November 25th 19, 04:52 PM posted to rec.aviation.soaring
On Monday, November 25, 2019 at 9:48:01 AM UTC-5, wrote:
I shattered a plastic Cobra fender when my ASW 24 was less than a year old. Not impressed. I replaced them with galvanized steel fenders from (then) Northern Hydraulics. Salvaged the mud flaps from the plastic junk and tossed the wheel chocks in the front of the trailer where no one would walk away with them in a parking lot. I've since lost two tires (we've had the tire discussion many times so do what you like) and damaged a fender both times.. I just banged it back out. I do need to replace them now (they're 25 years old and stained/bent) but I'll just get another set of cheap metal fenders. You'll probably have to drill a few holes but no big deal.
Chip Bearden
JB
If I were to have to replace a fender, I'd go with steel for durability. I'm also set up to paint with good primers and paint.
My perspective.
A blown tire has the following likely costs:
Replace tire- about $125 or so.
Possibly replace fender. About $100 of you replace both fenders with metal. Cobra plastic is more.
If you are towing with a motor home(and no monitoring) it is very likely you will destroy the wheel. Ask Chip how hard they are to find.
After you put the spare on you have to really watch because you now have no spare.
I support 5 trailers for my ships. I'm buying tires for one of them every year. I consider the money to be well spent.
FWIW
UH
  #37
Old November 25th 19, 05:49 PM posted to rec.aviation.soaring
JS[_5_]
The only problem with a steel fender I've run across was how to bend it back or remove it at the side of the road after the blown tire mangled it.
At least the plastic ones from Cobra are now the "beer friendly" variety.
  #38
Old November 25th 19, 07:47 PM posted to rec.aviation.soaring
Tango Eight
On Sunday, November 24, 2019 at 12:16:47 PM UTC-5, Patrick McMahon wrote:
A few items, the tires were considered in the purchase, I think 5 years old, pressure checked, sat on concrete patio stones with UV covered when not in heated storage. They were replaced as blown with 155/80/R13's
It would be interesting to know what your tire pressure was.
Useful to know: all tires have a date code molded in.
155s are marginal. Most are SL or 79 load index and that's not enough for the application unless you are going to drive slow (60 mph). If you have enough clearance (almost certainly yes) and 4.5" rims (maybe) you could switch to 175/70-13 (same OD) which will give you a better selection to choose from. I would recommend at least 1100# load rating, at least 50 psi max, S or T speed rating would be good.
North American drivers in 2019 expect performance that wasn't on Cobra's map when your trailer was new.
T8
  #39
Old November 26th 19, 04:25 AM posted to rec.aviation.soaring
2G
Yes, I DO consider it to be an "independent source," don't you?
  #40
Old December 7th 19, 01:06 AM posted to rec.aviation.soaring
Dirk_PW[_2_]
I like the cheap plastic fenders because they act as a weak link when something hits them. They shatter instead of transferring the impact loads to the side of the trailer. If something hits a metal fender, don't be surprised if it bends or wrinkles the side wall of the trailer where it is mounted. Other road debris can slam into the fenders that can do more damage than lost tread.
Removing oxidation from Cobra trailer trim rubber and plastic fenders Dave Nadler Soaring 11 September 25th 17 05:57 PM
FS Cobra Fenders Red NG Soaring 0 February 22nd 14 09:09 PM
2013 Cobra trailer price list needed for TA trailer sale [email protected] Soaring 0 June 22nd 13 02:42 PM
plastic or metal fenders on the trailer? chris Soaring 14 December 20th 10 09:51 PM
Cheap Cobra Trailer Lights 1998 Trailer on E-bay USA ONLY! flyingmr2 Soaring 4 November 16th 10 02:11 AM
