Any recommendations on what to use to fill small holes in an aluminum panel?
Will bondo work?
TIG welder?
On Saturday, December 7, 2019 at 4:24:07 PM UTC-7, soaringjac wrote:
Will bondo work? Bondo might work, but is brittle. You might want to look at an epoxy based filler that would be more flexible in the long run. AEROPOXY LIGHT from Spruce would likely be a better choice. For a few small holes you could try something like JB Weld. If you have some cotton flock, I would mix some with JB Weld and use that. It would provide an epoxy base with the structural strength of fiber to minimize cracking. |
On Saturday, December 7, 2019 at 5:39:40 PM UTC-7, Tim Taylor wrote:
On Saturday, December 7, 2019 at 4:24:07 PM UTC-7, soaringjac wrote: Will bondo work? Bondo might work, but is brittle. You might want to look at an epoxy based filler that would be more flexible in the long run. AEROPOXY LIGHT from Spruce would likely be a better choice. For a few small holes you could try something like JB Weld. If you have some cotton flock, I would mix some with JB Weld and use that. It would provide an epoxy base with the structural strength of fiber to minimize cracking. Just saw that JB Weld makes a putty: SteelStik⢠Epoxy Putty - 2 oz Looks like it would work as well. |
On Saturday, December 7, 2019 at 4:45:03 PM UTC-8, Tim Taylor wrote:
On Saturday, December 7, 2019 at 5:39:40 PM UTC-7, Tim Taylor wrote: On Saturday, December 7, 2019 at 4:24:07 PM UTC-7, soaringjac wrote: Will bondo work? Bondo might work, but is brittle. You might want to look at an epoxy based filler that would be more flexible in the long run. AEROPOXY LIGHT from Spruce would likely be a better choice. For a few small holes you could try something like JB Weld. If you have some cotton flock, I would mix some with JB Weld and use that. It would provide an epoxy base with the structural strength of fiber to minimize cracking. Just saw that JB Weld makes a putty: SteelStik⢠Epoxy Putty - 2 oz Looks like it would work as well. Cool thanks Tim! I might give that SteelStik a try |
How about your Silver and Gold badges!?
On Saturday, 7 December 2019 18:12:08 UTC-5, soaringjac wrote:
Any recommendations on what to use to fill small holes in an aluminum panel? How small? |
On Saturday, December 7, 2019 at 6:52:38 PM UTC-8, weemacgregor wrote:
On Saturday, 7 December 2019 18:12:08 UTC-5, soaringjac wrote: Any recommendations on what to use to fill small holes in an aluminum panel? How small? about 3/8th |
On Saturday, December 7, 2019 at 3:12:08 PM UTC-8, soaringjac wrote:
Any recommendations on what to use to fill small holes in an aluminum panel? Well I used the SteelStik and that seems to have worked great so far! I guess we will see how it holds over time |
| Thread Tools | |
| Display Modes | |
| How to determine if your ASG29 has the large or small panel? | Sean Fidler | Soaring | 37 | November 19th 14 07:50 PM |
| Trying to fill some holes in the instrument panel | [email protected] | Soaring | 2 | February 12th 14 03:55 AM |
| Cutting 57mm holes in the instrument panel.....how to? | John Bojack[_2_] | Soaring | 20 | November 12th 10 10:15 PM |
| When Poorboys drill holes ...was: Drilling holes in steel tubing | wright1902glider | Home Built | 4 | November 4th 05 02:19 AM |
| Filling Holes | AKperson | Owning | 1 | July 20th 05 04:54 PM |
