Locating Transponder Antenna on top of the fuselage instead of under it.
Old December 30th 19, 02:48 AM posted to rec.aviation.soaring
2G
Default Locating Transponder Antenna on top of the fuselage instead ofunder it.
On Saturday, December 28, 2019 at 6:43:02 PM UTC-8, Darryl Ramm wrote:
On Saturday, December 28, 2019 at 4:10:30 PM UTC-8, wrote:
"Pay attention to the proper ground plane installation with any of the standard external transponder 1/4 wave antenna. That is very important."
Can the ground Plane be inside a carbon fibre fuselage for an external blade type antenna ?
Dan
The ground plane you install would normally be inside the CF fuselage. And the antenna manufacture or glider manufacturer should provide instructions on how to do this properly. A part of the point of that aluminium plate or foil tape ground plane is to help with a good connection to the coax cable ground. In some cases you might scuff the inside of the fueslage to help make additional electrical connection to the carbon fibre weave. *Follow the directions your glider manufacturer provides.* A plate especially can also help provide a good solid surface for antenna lock washers to engage with.. Clearly here the CF will act in part as a ground plane (even without a good direct electrical connection, but by backing it with a better conductor with good connection to the coax you are helping things along).
Not all transponder antennas need a ground plane:
https://wingsandwheels.com/avionics-...as/l2-aae.html
  #32
Old December 30th 19, 02:58 AM posted to rec.aviation.soaring
Darryl Ramm
Dan
The ground plane you install would normally be inside the CF fuselage. And the antenna manufacture or glider manufacturer should provide instructions on how to do this properly. A part of the point of that aluminium plate or foil tape ground plane is to help with a good connection to the coax cable ground. In some cases you might scuff the inside of the fueslage to help make additional electrical connection to the carbon fibre weave. *Follow the directions your glider manufacturer provides.* A plate especially can also help provide a good solid surface for antenna lock washers to engage with. Clearly here the CF will act in part as a ground plane (even without a good direct electrical connection, but by backing it with a better conductor with good connection to the coax you are helping things along).
You are replying to a thread that clearly stated "with any of the standard external transponder 1/4 wave antenna." Are you adding value here?
  #33
Old December 30th 19, 03:32 AM posted to rec.aviation.soaring
2G
Dan
The ground plane you install would normally be inside the CF fuselage.. And the antenna manufacture or glider manufacturer should provide instructions on how to do this properly. A part of the point of that aluminium plate or foil tape ground plane is to help with a good connection to the coax cable ground. In some cases you might scuff the inside of the fueslage to help make additional electrical connection to the carbon fibre weave. *Follow the directions your glider manufacturer provides.* A plate especially can also help provide a good solid surface for antenna lock washers to engage with. Clearly here the CF will act in part as a ground plane (even without a good direct electrical connection, but by backing it with a better conductor with good connection to the coax you are helping things along).
Yes.
  #34
Old December 30th 19, 05:22 AM posted to rec.aviation.soaring
Jonathan St. Cloud
On Sunday, December 29, 2019 at 12:26:19 PM UTC-8, wrote:
The Jonker website says that they are putting both the transponder antenna and the Flarm antenna in the vertical tail. Any reports on how that is working out?
See above, I mentioned how that is working out.
  #35
Old December 30th 19, 05:36 AM posted to rec.aviation.soaring
GliderCZ
On Saturday, December 28, 2019 at 10:27:43 PM UTC-8, Darryl Ramm wrote:
On Saturday, December 28, 2019 at 9:23:02 PM UTC-8, wrote:
Well here is a link to a picture of a Ventus with the transponder antenna located as per Schempp Hirth.
Seems to work well only is straight flight. In any banking flight, the antenna is shadowed by the fuselage and/or wings.
Maybe a location on the turtledeck is better ?
https://www.airliners.net/photo/-/Sc...HgcaJ1/QJ2lC9A
Dan
Thanks for the photo, ouch yep that looks like a dopey position, if above is the only other practical option I'd do that.
I've got a Ventus 2c with a flexible antenna positioned exactly like that, per SH recommendations, and have passed a dozen ADS-B checks in the last year, with lots of low altitude yanking and banking.
  #36
Old December 30th 19, 05:47 AM posted to rec.aviation.soaring
Do you have the Blade type antenna or the cylinder/ball one ?
Thanks, Dan
  #37
Old December 30th 19, 06:06 AM posted to rec.aviation.soaring
GliderCZ
Thanks, Dan
Flexible, similar to the one linked (not HpH branded, as far as I know).
https://wingsandwheels.com/hph-trans...r-antenna.html
  #38
Old December 30th 19, 06:08 AM posted to rec.aviation.soaring
Darryl Ramm
On Sunday, December 29, 2019 at 10:11:09 AM UTC-8, 5Z wrote:
On Friday, December 27, 2019 at 5:22:04 PM UTC-8, wrote:
I put mine on a turtle deck on my ASW 27 and it works fine no issues with anyone seeing me or even worrying about it I really like the fact that it's there and was really easy to install compared to down by the gear
Long ago someone (I believe from Arizona) posted here about doing some research by talking to folks very familiar with FAA radar design about putting the transponder antenna on top of the fuselage. The conclusion was that if very near and above the radar site, the signal *might* be blocked. Other than that, it should be fine. Since we do a lot of turning, the antennal will be blocked for times anyway.
Unfortunately "it's more complex" applies to lots of stuff with aircraft surveillance.Â*And I would hope any research folks did thought about some of the things I'll describe here.
My concern with upper surface antennas is more blanketing from the wing, and that includes to distant SSR sites. The fuselage directly blocking the antenna like when near/overhead an SSR is not the main concern I have because already the SSR likely can't see you.Â*(OK sure if the long length of the fuselage points directly at the antenna you might have an issue).
If you are very near, i.e. ~overhead a radar site you may well be in the "cone of silence" of both the primary radar and SSR and likely not seen regardless of transponder antenna location or orientation. SSR and primary radar have a fairly wide cone of silence/shallow viewing angle above the horizon.. Think things like an SSR sees things only below ~30 degrees above the horizontal around the antenna.
Transponder antennas also have a cone of silence pointing out the end of their antenna. Hopefully a bit narrower than the SSR cone.
An antenna mounted on an upper fuselage area on a glider might be helped by diffraction around the glider fuselage, and that weak diffracted part of the signal may be OK when closer to a SSR (or ADS-B ground site) but still within that say 30 degree angle above the horizon. As the transponder antenna looks out more towards a distant SSR antenna the angle shallows and hopefully seeing a bit better signal due to decreased angle, but you can have significant range loss, especially say if relying on a distant (up to ~200NM!) en-route SSR to fill in details). But it's complex and would need modeling to see what happens.
Ah the irony is that very local overhead performance to an SSR antenna may depends on other (possibly quite distant) SSR sites.... SSR cones of silence get somewhat addressed by integrating together data from overlapping radar systems.Â*That is what the FAA Fusion system does, and it also folds in ADS-B data. (And ADS-B ground stations themselves have similar cone of silence issues, and a similar solution of adjacent ground towers partially covering each other).Â*
Any analysis you would want to look at upper and lower antenna performance to local SSR interrogators at around that 30 degree angle, and at more distant SSR sites that are filling in the data for the cone of silence at shallower angle. And my concerns again are more things like wings obscuring line of site, and wanting to make sure that any ground plane and antenna installation is as good as posible to maximize signal quality to/from more distant SSR sites regardless of wether the antenna is top or bottom mounted.
And I sure appreciate Dan posting a followup link to that picture of the antenna stuck out the side of a fuselage. I had never seen that before, much worse than I had imagined, and I sure did not want to seem to be recommending it.. blanketed directly above by the wing, blanketed to the side by the fuselage and side/below by the gear when extended, and ~90 degree crossed signal polarization when the glider is banking left.Â*
One reason for a transponder is to be seen by large aircraft TCAS, it's more likely they will be descending on a collision course, so having the antenna on top is a better idea....
5Z
Like Eric I don't understand why TCAS threats are assumed to come from above. I would suspect an equal distribution, and threats are going to be approaching near the same altitude with a relatively shallow climb or descent angle. In a bad case TCAS IIÂ* is going to command an RA which could put you relatively close laterally but above or below the threat aircraft... and I would assume those RA directions are equally distributed as well. And you've already executed the RA command before the angle above/below the threat gets very steep. I think there are studies/modeling of aircraft showing TCAS performance with single antennas if I can find them I'll point them out (but the system exists as it does with all light aircraft largely having single lower antennas).
With it being hard to guess/know how well things are really working one thing I have thought would be neat is a transponder antenna performance test tool similar to FLARM range tool or OGN/KTrax used ground and/or airborne 1090 MHz/ADS-B receivers. (Mark Hawkins are you looking for a project? :-))
  #39
Old December 30th 19, 06:16 AM posted to rec.aviation.soaring
jfitch
On Sunday, December 29, 2019 at 12:23:28 PM UTC-8, Darryl Ramm wrote:
On Sunday, December 29, 2019 at 9:53:24 AM UTC-8, jfitch wrote:
On Sunday, December 29, 2019 at 9:15:03 AM UTC-8, Jonathan St. Cloud wrote:
On Saturday, December 28, 2019 at 8:55:37 AM UTC-8, jfitch wrote:
On Saturday, December 28, 2019 at 12:26:15 AM UTC-8, Tango Whisky wrote:
My transponder hs 250 W output, no way I would want that any place near my head or my balls.
The normal location (recommended by many manufacturers) just ahead of the gear doors is much closer to your balls than an L2 in the nosecone (or the instrument pod), if that worries you. Probably less than 2' away. I always wear tin foil underwear to match my tin foil hat. But my transponder antenna is in the nosecone and works perfectly as tested by external radiated power and FCC ADS-B out reports.
But you don't wear tin-foil socks, do your toenails grow faster during soaring season? Would like to get a bit more information on the tin-foil hat, I think I need one. I have my transponder antenna in the fin works great, no need for time foil panties.
There's not much point in the tin foil hat, when 5G is deployed we will be dying and/or mutating by the 10s of thousands. I read that on the internet, so I'm certain it's true.
In the Ventus picture, you can see that the antenna is about half the distance to the pilots privates than it would be up in the nose cone.
And uh.... not relevant... the pilot is inside his carbon fiber partial faraday cage cockpit, and (agreeing with Eric) the pattern from the 1/4 wave antenna with groundplane shields the pilot from the antenna.
Over a beer some time: details of teaching assistants punking male students in their undergrad physics lab classes into wearing aluminium foil "mini skirts" during a _very_ low power microwave experiment. Oh so well done.
You'd need to show me the data on that. A minimally conductive carbon fuselage with some huge holes in it, a very imperfect 1/4 wave vs. twice the distance. We're talking r^3 here. I'm not actually sure what measurements might show, and I wouldn't bet my glider on one answer over the other.
  #40
Old December 30th 19, 06:43 AM posted to rec.aviation.soaring
Well, Here is a picture of Schlicher's recommended location for the Antenna-same as Schempp Hirth-Above landing gear doors.
Interesting.
https://www.alexander-schleicher.de/...reinbau-27.pdf
Dan
PowerFlarm Antenna Locations on Carbon Fuselage Dan Marotta Soaring 9 August 15th 19 08:38 PM
ASW27 Trasponder Antenna Installation Inside Fuselage. Paul Birkett Soaring 45 January 8th 18 03:31 AM
ASW-24 - Transponder Cable Routing in Fuselage [email protected] Soaring 6 February 3rd 15 05:00 PM
Transponder Antenna Placement Fuselage Bottom - Minimize Damage?Exact Location WaltWX[_2_] Soaring 9 January 19th 15 11:00 PM
Transponder and antenna Paolo Soaring 1 March 6th 04 03:32 AM
