Gyrocopter Speed
Old August 12th 05, 08:59 AM
Kevin O'Brien
On 2005-06-07 13:43:59 -0400, Dennis Fetters
said:
Kevin O'Brien wrote:
The experience of flying a lot of different helos probably would have
helped. I think that negative transfer from a lifetime of flying Bells
was as big a contribution to the demise of Allen Barklage as the
exhaustively-discussed engine-out characteristics of the Mini-500.
I don't care about the rest of your discussion here, so no comment.
But, you got it wrong about Allen Barklage an his accident in his
Mini-500. The Mini-500 has excellent engine-out characteristics, as
demonstrated at almost every major air show.
I recall one of them pranging at Sun n Fun, I think it was. A yellow
one? Indeed, it might have been your demonstrator? Engine seize led to
a hard landing and rolloever, IIRC, but I will look it up and get my
facts straight if you want to argue about it.
If properly set up by the builder, it could autorotate and land safely
as low as 40 mph.
What about the nose tuck? I have Rick Stitt's answer to that, and I
wonder what yours is.
Allen had great experience in his Mini-500 and was an expert at
demonstrating autorotations.
I'm aware of Allen's Mini-500 experience. He was probably the second or
third highest time pilot in type at the time of his death, wasn't he?
There was another fellow who had some 800 hours at the time, IIRC.
Where would lack of transition time from one helicopter to another have
anything to do about Allan's accident, in the way you just tried to
convey here? None whatsoever.
I'm not suggesting that it was transition "time" but negative transfer
of skill, of experience, and of "muscle memory" under pressure, to use
the latest fad term. Allen had done at least five for-real autos in the
helicopters he was most familiar with, Bells.
The Bell teetering rotor system has, as you well know, some
similarities with the Mini and some rather pronounced differences. The
biggest difference being (IMHO) rotor inertia. A standard drill at Army
flight school is (or was in Allen's day, at least) to set the machine
down, pick it up, pedal turn it 180 degrees, and set it down again.
You wouldn't pull that off with a low-inertia design like the Mini --
or the R-22 for that matter. But you can do it with a Bell 47, UH-1, or
206/OH-58. Having had for-real autos in these machines, a pilot has a
"feel" for what he can do. Like stretch a "glide" over some wires.
Except you're not in the Bell, you definitely can't.
I think negative transfer also contributed to some of the Robbie
mishaps that led to the SFAR on training in the R-22.
(FWIW, F.R. now says that if he knew his helicopter would have become
the most popular trainer, he'd have designed it completely differently.
He intended it to be a light, responsive machine for the experienced
pilot seeking a sport or transport helicopter. He built the machine he
wanted to fly himself).
In a related matter, of fitness for purpose, I note that RHCI's very
effective ads stressed all the cool things you could do and places you
could go in a Mini-500. They imply it was easy as a bicycle and safe as
mother's milk -- neither of which is true, you'll admit, of any
helicopter.
Allen took off in his Mini-500 after it had an engine seizure due to
improper jetting a flight before. He didn't bother to inspect the
engine for seizure damage, and just flew it away as if nothing wrong
had happened.
NTSB does not mention any prior seizure, or anything to do with
carburettor jets. They do say: "A loss of engine power due to cold
seizure of the power-takeoff cylinder." They retained the engine for
examination after releasing most of the wreckage.
https://www.ntsb.gov/ntsb/brief.asp?...11X11011&key=1
Worse yet, he hugs the ground during his flight, and flies over a power
line complex without gaining altitude.
Witness: "It was approximately 200 feet above the ground."
Source:
https://www.ntsb.gov/ntsb/brief2.asp...FA353& akey=1
The
The engine finally failed over the lines, and he tried to milk the
rotor rpm for more than any helicopter could have offered, and nosed
into the ground after stalling the blades.
The witness also noted that "The helicopter did not do a nose tuck,"
which indicates some familiarity with the type, if he was expecting
that.
Simple as that. It had nothing to do with transition time from one
helicopter to another. It had already been determined that there is
probably no single engine helicopter built that could have lost it's
engine at that time and auturotated that distance at such a low
altitude and landed safely.
"It had already been determined" -- the passive voice is a bit evasive
sounding here? Who determined that no single engine could lose its
engine at 200 ft. and climbing (Witness: ""He was level and climbing,
going away from me when all of a sudden, the sound (engine sound) went
quiet, followed by a pop." - same NTSB narrative) and autorotated
safely?
I'm curious as to why your narrative is at such wide variance with
NTSB's. They don't list RHCI as a party to the investigation, either.
Buit I don't believe RHCI folded until one or two big shows after
Allen's demise.
Sorry for the belated reply, Dennis, and all. I don't check the
newsgroups very often these days.
cheers
-=K=-
Rule #1: Don't hit anything big.
  #32
Old August 14th 05, 09:53 PM
10ft. of Decorative Chain
RHCI don't need outside help to investigate accidents!
Dennis "planeman" Fetters plays many roles, see the link below.
You might have missed this gem:
http://tinyurl.com/9m52c
  #33
Old August 15th 05, 08:15 PM
Dennis Fetters
Bells was as big a contribution to the demise of Allen Barklage as
the exhaustively-discussed engine-out characteristics of the Mini-500.
one? Indeed, it might have been your demonstrator? Engine seize led to a
hard landing and rolloever, IIRC, but I will look it up and get my facts
Dear Mr. O'Brien,
I'm at a loss as to your counter-answer to my answering the statement
you made about Allen's accident or it's relevance, and although I have
published this here before, here is the correct information again. It
was not Sun n Fun, it was Oshkosh. It was not a yellow one, but a red
factory demonstrator. As for the cause of the accident, here is what the
RHCI chief pilot published:
""As published in the September 1995 “Reaching the Customer” newsletter,
the following report was written by Brian Thomas (RHCI’s Test Pilot):
Many of you have been asking questions about the autorotation
capabilities and crashworthiness of the Mini-500. Well, I will answer
some of those questions, but this time with an actual experience...
Oshkosh was less than a week away, the composite department was still in
the learning stage and needed much supervision, and the assembly manual
was a priority. Our minds were divided onto these other projects while
we were working on preparing the aircraft for the show. As a result of
this, we made three mistakes which caused this whole incident.
First, we installed a new rotor/engine tachometer in the aircraft just
before the fly-in. We thought the gauge was calibrated correctly.
Also, we were using a new EGT gauge that was supposed to be
self-compensating for temperature. The week before Oshkosh, the
temperature at the factory was 95 to 100 degrees F. with 95% humidity.
After making these changes, the aircraft experienced a loss in
performance. Our EGT temperatures were only running about 900 to 1000
degrees F. We attributed this loss of performance to the high
temperature and humidity. Using the EGT gauge as a guide, we leaned the
mixture by installing much smaller main jets and lowering the needles.
This brought the temperature up to 1100 and 1200 degrees F., but with no
significant increase in performance. Through testing, we then learned
that the rotor/engine tachometer was calibrated too low. After
re-calibration, our performance returned. EGT’s were still reading
normally and were left as changed. I immediately conducted a short test
flight and everything seemed to be working well.
Second, we installed wear shoes on the bottom of the skids to prevent
excessive wear on concrete and rocky surfaces. Our intentions were to
make this an option later. These shoes consisted of eight pieces of
steel, four per skid, approximately five inches long, riveted with six
rivets each, evenly spaced along the skids.
Third, we did not test the skid shoes on grass or dirt to see if they
would change the run-on landing performance.
Now for what happened at Oshkosh. It was the first flight on the first
day of the show. I started the aircraft and hovered around the grass
runway for a few minutes and the aircraft was operating normally. I
then departed and entered the traffic pattern. On my first trip around
the pattern, the aircraft was performing perfectly. I was keeping an
eye on the EGT gauge to make sure that the temperatures were still good,
since it was cooler at Oshkosh than at the factory. The temperature was
still 1100 and 1200 degrees F. On my second trip around the pattern,
the engine suddenly stopped. The EGT gauge that we installed was not as
accurate as we thought and the engine hot seized. At the time the
engine quit, I was at 300 feet AGL with an airspeed of 70 MPH. I
entered autorotation and steered for a nearby clover field. The
autorotation was uneventful, as was the flair and touchdown.
As I have previously said, the Mini-500 is one of the best autorotating
helicopters I have ever flown. The problems began during the ground
slide. Immediately upon touchdown, the skid shoes caught in the clover
and soft dirt so hard that one shoe was pulled off the skid! The left
skid caught and jerked so hard that the legs buckled. The legs did not
buckle because they are not strong enough. They buckled from the
enormous force of trying to stop 730 lbs. of aircraft so quickly. The
skid shoes were the cause, not the legs. When the left skid buckled,
the aircraft started to go onto its left side. As a result, one rotor
blade contacted the tail boom. Part of the reason that the skid shoes
caught so hard is that the normal procedure for the Mini-500 is to lower
the collective all the way down after touchdown from an auto. On most
helicopters with skid shoes, the procedure is to hold the collective up
until the helicopter comes to a stop to prevent the shoes from digging
in too badly. I am very familiar with this procedure, but failed to
relate it to the Mini-500.""
Completely our fault.
safely as low as 40 mph.
Rich Stitt is a back stabbing thieving parasitic traitor that bits the
hands that and feed him. The is a convicted child beating criminal that
takes advantage of old single ladies emotions and then drains their bank
accounts before he moves on to the next one. If you want to believe
anything he says, go for it.
As you can read what I said above: "If properly set up by the builder,
it could autorotate and land safely as low as 40 mph." I have already
answered this here before, but, there were a few customers that listened
to the advice of another famous customer and set their blade tips at
negative 1.5 degrees instead of the 0.5 negative the factory stated.
This would lead to a nose tuck when dumping the collective, and in one
case caused the main blades to droop so low as to cut a grove out of the
customers tail boom. If following instructions, as you should, by
setting the blades to factory specifications and leading with cyclic
before collective, just like in an R-22, there was no significant nose
drop. After further development, RHCI came up with a trim tab and a
stall strip that took away all nose drop when you dumped the collective.
Just read the KitPlanes pilot evaluation report they published.
Good for you for being aware, then what's your point because I'm missing it?
He didn't have nearly 800 hours, but here is what you are eluding too:
"The pilot had installed his Mini-500 “Power Enhancement Package” (PEP),
and against RHCI’s severe warnings, chose not to use the provided jet
package containing a 2.76 needle jet. Instead he installed a 2.78
needle jet which meant that he needed a 155 main jet to achieve the
proper EGT in hover. RHCI informed the pilot that the engine would
seize with this small main jet, when at high-power settings it could not
supply sufficient fuel to the engine, causing it to heat and seize. The
main jet should have been a 165 or 170. Also, he had erroneously set
the needle in the third position on the cylinder that seized; the other
was correct in the fourth position. He was flying over a forest when
the engine seized, and autorotated into a 50-foot tall tree. The impact
broke the mast and the aircraft fell and landed upside down on the ground."
Pilot error.
have anything to do about Allan's accident, in the way you just tried
to convey here? None whatsoever.
OK, let's do it again: Where would lack of "muscle memory" from one
helicopter to another have anything to do about Allan's accident, in the
way you just tried to convey here? None whatsoever.
The Bell teetering rotor system has, as you well know, some similarities
with the Mini and some rather pronounced differences. The biggest
difference being (IMHO) rotor inertia. A standard drill at Army flight
school is (or was in Allen's day, at least) to set the machine down,
You wouldn't pull that off with a low-inertia design like the Mini -- or
I didn't write the above statement. But you are correct.
I think negative transfer also contributed to some of the Robbie mishaps
No comment, let Frank answer that. I love to fly the R-22 and R-44. In
my opinion they are fine designs.
Let Frank answer that, I don't claim to know anything that was in his
mind at the time. What ever it was, was correct, because I think he is
the most successful helicopter producer in the world.
mother's milk -- neither of which is true, you'll admit, of any helicopter.
You are wrong. We did say all the cool things you could do, because you
can. And we did them, and some still do. But, you will never see in
anything published by RHCI where we said flying a helicopter is safe,
because flying helicopters is not safe, and in fact full of risks. Our
warnings alone made some people not buy. At the air shows we always had
an assembly manual on the table, and the first few pages were dedicated
to the risks involved in helicopter flight, with a skull and cross bones
and 8 different warnings, so on.
The Mini-500 is easy to fly, and many stated it was the easiest and most
stable helicopter they had ever flown. But, we never implied anyone
could fly it without training. As a matter of fact, we forced our
customers to prove they had training before we would ship them the
complete kit. No other manufacturer I know of did that when we were in
business.
Your comment above was false, out of place and even malicious.
had happened.
That's right, nor do they probably know anything about Rotax engines in
helicopters and the differences involved, as they demonstrated to me on
more than one occasion. Nor did they bother to say just a short time
before he crashed his Mini-500 by climbing out of it with the blades
still turning at full RPM, so he could point to some people where to
land, and his Mini-500 took off!! And he didn't report it, and even
though his FAA buddies found out they never did anything about it. No
wonder it was not mentioned in the accident report later.
Let's look at this for a moment:
The witness was on the airport, and the Mini-500 was 150 or less above
him, and still over the airport. The power lines are about 1000 feet
away from the witness. Already 150 feet high over the witness, Allen
only climbed 50 more feet over a 1000 foot distance to clear a power
line complex. It shows that he had no concern about climbing high
enough, as we are all trained to do to clear an obstacle in case of
engine failure. Pilot error.
It was 83 degrees F. The witness, standing on the opposite side on a
large hanger, heard the Mini-500 running behind the hanger complex, then
he watched it fly from around the hanger making a wide and level turn
towards him climbing to 150 feet or so, then flying away almost 900 feet
before the engine failed. The point is, between the mandatory warm-up
time, hover time, flying from around the hanger time, wide level turn
time, flying toward the witness while climbing to 150 feet time, and
flying 900 feet away while climbing an additional 50 feet time, the
Mini-500 had plenty of warm up time not to have cold seizure.
Cold seizures in a Mini-500 have only happened when the pilot starts the
engine cold, and immediately lifts into a climbing departure, and then
the engine will seize within 100 feet or so and not turn until later
after the piston cooled enough to allow it to do so. It's Pilot error.
Look at the report:
"The top of the piston showed foreign material impact strikes in the
squish-band area. Small particles of foreign metallic material were
found embedded in the piston head. Impact marks were found in the top
dome of the power-takeoff cylinder. The two power-takeoff cylinder spark
plugs' electrodes showed no gap. The bottom of both electrodes showed
impact marks." "the sound (engine sound) went quiet, followed by a pop".
Again, dose that sound like an engine that just cold seized, when the
engine can still turn to allow a "pop" from a misfire. The engine quit
because the spark plug gaps were closed from the previous contamination
pounding them shut.
Dose that sound like something was COLD? Not at all. That was an engine
failure due to disintegration of parts. Just like if you seize an
engine, and then run it again without fixing it by removing the damaged
parts and metal, and just like what I said when Allen himself called me
to tell me he seized his engine and he didn't bother to fix it right
before the crash. The engine got hot, and darn hot at that. Nothing cold
about it. In fact, a cold seizure shows only scuffing from sudden
expansion of the piston squeezing in the cylinder, because the cylinder
was not given time to expand. You will not find the metal as what was
found in Allen's engine that was large enough to de-gap the plugs.
power line complex without gaining altitude.
Source:
Just like I said. 200 feet high and 1000 feet away from the airport
property boundries, and only climed 50 more feet in that distance from
the airport. Pilot error.
which indicates some familiarity with the type, if he was expecting that.
I didn't say it did a "nose tuck". I said it nosed into ground after
stalling the blades, meaning the nose pointing the direction of travel.
As the report indicated, he still had some forward speed, just no lift
and little RPM, as the blade damage described in the report would indicate.
quiet, followed by a pop." - same NTSB narrative) and autorotated safely?
My conversation with the FAA and other expirianced helicopter people in
the area. They said it.
Allen's demise.
My above answers should also answer this question. The only thing I'm
disagreeing with in the FAA report is the cold seizure. They are in
error to report that, because that was not the cause of the engine
failure, as I comprehensively explained above.
Welcome back.
Sincerely,
Dennis Fetters
  #34
Old August 15th 05, 08:21 PM
Dennis Fetters
Yes, I wrote everything in every post that has my name on it in the link
you give above. However, I did not write anything that has someone
else's name to it. I write for myself, and hide behind no false names,
as you do.
Dennis Fetters
  #35
Old August 16th 05, 06:22 AM
as you do.
Dennis Fetters
Simply impossible, and having your IP changed after you were exposed did
nothing to cover your tracks.
We saw Dennis Fetters and "planeman" posting back and forth, both using
the same IP address, for nearly a week...
An address that traces back to Anaheim/Irvine area in So. Cal
Shame on Dennis Fetters.
  #36
Old August 16th 05, 04:27 PM
Dennis Fetters
link you give above. However, I did not write anything that has
someone else's name to it. I write for myself, and hide behind no
false names, as you do.
Dennis Fetters
Think what you want Mr. No Name. Who cares.
  #37
Old August 16th 05, 11:28 PM
Dennis Fetters
did nothing to cover your tracks.
using the same IP address, for nearly a week...
It's all about trust, and everyone cares.
You shouldn't have posted your little charade without knowing what you
were doing, Mr. "Planeman" Fetters.
Landing and T/O distances (Was Cold War ALternate Basing) Guy Alcala Military Aviation 3 August 13th 04 12:18 PM
Va and turbulent air penetration speed. Doug Instrument Flight Rules 70 January 11th 04 08:35 PM
Va and turbulent air penetration speed. Doug Owning 69 January 11th 04 08:35 PM
Speed Astir Guy Acheson Soaring 0 December 11th 03 02:24 AM
New Film: The Need For Speed - Going to war on drugs Phil Carpenter Military Aviation 0 July 23rd 03 07:43 AM
