2 aircraft cleared onto the same runway at the same time
Old March 27th 05, 04:39 AM
Steven P. McNicoll
"Robert Chambers" wrote in message
om...
It may depend on the field, but if you have an IFR arrival inbound on an
ILS approach, and an IFR departure waiting to take to the skies, the guy
on the ground is not going to be released.
That is not correct.
At larger airports where they have more runways or larger distances
separating incoming from outgoing they can squeeze the timing a bit. From
my home field (class D) I know this to be the case.
You believe that to be the case, but that is not the case. You are
misinformed.
  #32
Old March 27th 05, 04:42 AM
Steven P. McNicoll
om...
And what happens if the incoming plane goes missed?
Nothing.
You're assuming an awful lot about what the tower guy can and cannot see.
My home field tower doesn't have radar, or a brite scope slaved from the
approach control.
If there's an incoming IFR flight, and you want to go out IFR, you are not
going to be released until the incoming plane either lands or cancels IFR.
Well, it's done regularly. Whoever told you this stuff doesn't know what
he's talking about.
  #33
Old March 27th 05, 06:23 AM
Jose
For the same reason a plane holding for IFR release cannot take off until
the IFR arrival he's waiting for has either cancelled IFR or has landed.
Not true at a controlled field.
Assuming IMC, what does a controller do to ensure separation in the air
for the departing aircraft from an arriving IFR aircraft who has not
cancelled IFR or landed?
Or is your comment limited to VMC?
Jose
r.a.s trimmed
Get high on gasoline: fly an airplane.
  #34
Old March 27th 05, 06:26 PM
Newps
No reason not to if there is a tower.
they have more runways or larger distances separating incoming from
The number of runways or their spacing is irrelavant.
  #35
Old March 27th 05, 06:28 PM
Newps
He is issued a vector.
You're assuming an
No I am not. Been there done that.
approach control.
Neither did the one I worked at.
not going to be released until the incoming plane either lands or
cancels IFR.
Your tower is not using all the tools available to it.
  #36
Old March 27th 05, 06:30 PM
Newps
Jose wrote:
Assuming IMC,
Which isn't relavant.
Issue a heading that guarantees separation.
Doesn't matter.
  #37
Old March 27th 05, 10:45 PM
Steven P. McNicoll
"Jose" wrote in message
news
He applies an approved form of separation. There are a variety to choose
from, visual and radar are probably the most commonly used, but there are
nonradar techniques as well.
http://www.faa.gov/atpubs/ATC/Chp6/atc0603.html
Nope.
  #38
Old March 28th 05, 03:09 AM
B. Jensen
Tom,
I believe that as long as both aircraft are diverging by 30 degrees on
climbout headings, this is perfectly legal.
BJ
Tom Fleischman wrote:
This was a new one for me.
I was IFR this afternoon out of HPN for short practice flight. I was in
sequence number two at the runway waiting for departure. As the tower
controller cleared the Cessna in front of me to position and hold, he
asked him his direction of flight. The Cessna pilot responded
"Northbound". The controller then instructed the Cessna to position 50
feet north on Rwy 34, and then he cleared me to position and hold
behind the Cessna. The Cessna was VFR. I questioned the clearance,
reminding him that there was an airplane on the runway in front of me.
He told me to position and hold behind the traffic. As I taxiied into
position, he cleared the Cessna for takeoff and as soon as the Cessna
broke ground he cleared me for takeoff. I was using a DP which includes
a turn to the left. The Cessna was instructed to turn out to the right.
I've been flying out of HPN since 1992 and I have never seen or heard
of anything like this being done there before, ever.
Did I miss something??
  #39
Old March 28th 05, 03:11 AM
Jose
for the departing aircraft from an arriving IFR aircraft who has not cancelled IFR or landed?
What are the separation requirements?
Jose
  #40
Old March 28th 05, 03:15 AM
Jose
Thanks Steven - very helpful.
Jose
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 0 December 2nd 04 07:00 AM
Boeing Boondoggle Larry Dighera Military Aviation 77 September 15th 04 02:39 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 April 5th 04 03:04 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 2 February 2nd 04 11:41 PM
