Battery switching without tears
Old April 6th 20, 04:02 PM posted to rec.aviation.soaring
jfitch
Default Battery switching without tears
On Sunday, April 5, 2020 at 7:02:13 PM UTC-7, 2G wrote:
On Sunday, April 5, 2020 at 11:25:37 AM UTC-7, jfitch wrote:
On Sunday, April 5, 2020 at 10:03:31 AM UTC-7, kinsell wrote:
On 4/5/20 9:45 AM, jfitch wrote:
On Saturday, April 4, 2020 at 6:23:44 PM UTC-7, 2G wrote:
On one of my flights last year I had to switch between my avionics battery and engine battery when the avionics battery voltage dropped too low (I had left the master on after the last flight and could only partially charge the avionics battery before launching). The switch over seemed to go okay, but then I noticed that my LX9000 was giving me unbelievably short glide distances. It turns out that the QNH altitude had been reset to the altitude at the time of switching. This was unacceptable, so I resolved to do something about it before this season. The simplest solution was to add a capacitor to the avionics power bus. The capacitor supplies power as the power selector switch is moving, and breaking, from the avionics battery, and connector, or making, to the engine battery (this is called a "break before make" switch. But how big of a capacitor to use? The basic equation involved is:
V = I * t / C or C = I * t / V
where V is voltage, I is current and t is time.
Translation: the bigger the capacitor the smaller the voltage drop.. If the requirement is to keep the voltage drop to 1 V, the current is 2 A (my situation) and t is 0.1 s, then C = 0.2 F (200,000 μF). The capacitor would also have to be rated for 16 V, min. That is a pretty big capacitor, so I decided I could tolerate a larger voltage drop (4 V), which cuts the size of the capacitor to 50,000 μF. I ended up finding a suitably sized 39,000 μF capacitor rated for 25 V. A smaller capacitor could by used if the current drain is lower, which is likely for most gliders.
https://www.digikey.com/product-deta...301-ND/6928303
I installed the capacitor yesterday and monitored the bus voltage during switch-over with an oscilloscope, which was anti-climatic: there was no detectable drop in bus voltage. Apparently the bread-to-make time is very short, perhaps a millisecond. Haven't had a chance to fly with it yet, but should be able to soon. The scope waveforms and capacitor installation can be seen at:
https://flic.kr/s/aHsmMo9rN7
What is the inrush current when you first switch the power on? Must not be enough to blow the fuse, but that'd be something I'd want to O'scope with a current probe.
Yep. High enough current might eventually erode the switch contacts, or
even damage the capacitor.
The commonly used rotary switches are already being run over spec in modern panels. Schleicher and most others are typically using something like the NKK MRY106 or equivalent, these are called a 2A switch but that is the AC rating, DC rating is 1A. A modern panel uses something like 1.5A, and that is before you key the PTT switch.
When I redid my panel I used an MRT23 which is 3A, and paralleled the contacts for a 6A total. Rotary switches with a higher rating are normally much larger physically.
Schleicher parallels two sets of contacts of that 4-throw, dual pole switch.
Tom
That gets you to 2A - still less than the panel draws with the PTT pressed I'd bet. The time constant of the Klixon is quite long compared to the inrush current (if the impedance is low). Do you have a high bandwidth current probe for your O'scope? The peak current may depend mainly on the arcing characteristics of the contacts in the switch.
It's too bad they can't figure out how to make an LX9000 that can take a momentary interruption in power - many others have figured out how to do this..
  #32
Old April 6th 20, 04:05 PM posted to rec.aviation.soaring
kinsell
Translation: the bigger the capacitor the smaller the voltage drop. If the requirement is to keep the voltage drop to 1 V, the current is 2 A (my situation) and t is 0.1 s, then C = 0.2 F (200,000 μF). The capacitor would also have to be rated for 16 V, min. That is a pretty big capacitor, so I decided I could tolerate a larger voltage drop (4 V), which cuts the size of the capacitor to 50,000 μF. I ended up finding a suitably sized 39,000 μF capacitor rated for 25 V. A smaller capacitor could by used if the current drain is lower, which is likely for most gliders.
These capacitors are intended for power supply applications and can handle high currents (note the size of the connector posts), although there aren't high currents in my panel.
Tom
There sure are high currents when you power up the panel. Current into
the cap is capacitance times dv/dt, where capacitance is large and dv/dt
is near infinite. Do the math. The switch may survive for a while then
fail due to the repeated surges. The fact the Klixon didn't trip
doesn't mean anything, fuses and breakers can take huge overloads for
brief periods without tripping.
There's better ways of doing this with diodes than just putting on a
monster cap.
Dave
  #33
Old April 6th 20, 04:33 PM posted to rec.aviation.soaring
Tango Eight
Switches are generally rated according to interrupt capacity, and that's why the AC and DC ratings are different. In the immortal words of a friend of mine in the business, "DC just doesn't switch worth a ****". As the contacts open, an arc is struck. With AC current, the arc self extinguishes (for small switches) when the current goes to zero. The arc persists longer with DC, causes more contact wear, hence a reduced rating.
A "1A DC" switch is not going to fail or in any way be stressed by keying the mic and momentarily running 2, or even three or four amps. Try not to turn off the master while you are talking on the radio :-).
My panel has a CN2, CNv, radio, flarm. I have the standard issue Schleicher rotary switch, no modifications. Switching between batteries is simple: turn the knob. No drama, no instrument problems.
Evan Ludeman
  #34
Old April 6th 20, 07:20 PM posted to rec.aviation.soaring
Dan Marotta
MAKE before BREAK, not the reverse, which will momentarily interrupt
power to your panel.Â* Of course, if you're really, really fast, you
might get by...
On 4/5/2020 6:28 PM, Martin Gregorie wrote:
The same setup may well sort out a break-before-make switch too, with the
advantage that fitting it across the +12v and ground lines on the panel
side of the switch can most likely be done without disturbing anything
that's already in your panel and is both inexpensive and easy to make and
install.
Dan, 5J
  #35
Old April 6th 20, 07:23 PM posted to rec.aviation.soaring
Dan Marotta
Tom,
Isn't the rotary panel switch in a Schleicher glider a make before break?
OK, I'll stop posting to this thread now.Â* My solution, which I've
relied on for years without ever losing a connection or blowing a fuse
seems to be too simple to be acceptable.
On 4/5/2020 7:45 PM, 2G wrote:
The glider, an ASH 31 Mi, is already wired with a battery selector switch for the avionics, and is the way to go. You definitely don't want to parallel Pb and LFP battery's accidentally.
Tom
Dan, 5J
  #36
Old April 6th 20, 07:24 PM posted to rec.aviation.soaring
Dan Marotta
I'll grant you that!
On 4/5/2020 7:52 PM, 2G wrote:
That would require changing the switch on the panel. The course of least resistance (hence the title "Battery switch without tears") was to simply add a capacitor. It also avoids shorting of two dissimilar batteries.
Tom
Dan, 5J
  #37
Old April 6th 20, 07:54 PM posted to rec.aviation.soaring
jfitch
Evan Ludeman
No, a 1A DC switch will probably not instantly fail at 2A. An engine redlined at 7000 will probably not instantly fail at 8000. A glider rated at 5.5G will probably not instantly fail at 7G. Still, designing something to routinely operate out of spec isn't considered good practice in my shop. And the switch might fail with an inrush current of 20A, while switching, after awhile.
CN, like most other manufacturers designed to the reality of switching power sources in operation. LX, apparently, did not. I have no problem with switching my break-before-make rotary switches on a full panel of (non LX) electronics - nothing resets.
The continuation of this thread is proof that we are quarantined.
  #38
Old April 6th 20, 09:40 PM posted to rec.aviation.soaring
Evan Ludeman
Case in point to illustrate Evan's statement: I've tried to use a small water heating tank to use excess solar power to heat some water. Its heating element is rated 120VAC 15A. It has a thermostat with an internal switch to match. I fed it about 50VDC 6A from solar panels. That switch died in short order. Also note that we're warned not to disconnect solar panel connectors while the sun is shining and the power is being used, because the arc will damage the contacts in those connectors.
  #39
Old April 7th 20, 05:36 AM posted to rec.aviation.soaring
2G
Tom
The scope and probe are 100 MHz. I don't have a current probe (would have to use a series resistor which would change it from "without tears" to "many tears." Remember, the capacitor is providing the energy to the instruments when the switch is between break and make, so no current is required from the battery when it makes.
  #40
Old April 7th 20, 05:40 AM posted to rec.aviation.soaring
2G
Tom
monster cap.
Dave
Remember how they come up with these current ratings. It is based on heating of the contact - a very short current pulse (μsec) that results in virtually no heating.
Airplane tears off winglet on jet bridge a[_3_] Piloting 0 July 8th 10 08:06 PM
Tears in the eyes, - 1 attachment RobG Aviation Photos 4 June 17th 08 10:51 AM
The Tears Of Finding The Truth algaga Piloting 9 January 3rd 08 04:33 PM
“Particularly on May 19th”— with the tears of his father X98 Military Aviation 0 May 18th 04 10:34 AM
