Another E glider concept
Old August 29th 20, 06:07 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
Default Another E glider concept
On Sat, 29 Aug 2020 08:37:47 -0600, BobW wrote:
With luck, maybe we'll get to see how Mr. Otto's project fares in its
targeted flying niche.
Its obvious that as you make small commuter aircraft more efficient and
drive down the operating cost per hour and their small size may reduce
landing fees, but their small passenger capacity ramps up the cost of
flight crew as a fraction of ticket price in comparison with conventioinal
short-haul airliners, i.e. A320s etc.
So, I wonder how these two factors affect seat prices and hence airline
operating costs. Did Eclipse Aviation's Eclipse 500 ever get off the
ground?
Martin | martin at
Gregorie | gregorie dot org
  #32
Old August 29th 20, 07:00 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Martin Gregorie wrote on 8/29/2020 10:07 AM:
ground?
Easy to find out: 260 delivered.
  #33
Old August 29th 20, 07:32 PM posted to rec.aviation.soaring
ground?
I visited what I thought was their website: http://oneaviation.aero/
but the most recent item on it is about brake tests in 2012. No delivery
details there.
Additionally, it turns out that first Eclipse Aviation and then One
Aviation have become bankrupt.
But my original point remains unanswered: for short-range commuter or
taxi service operations, at what size of aircraft does the proportion of
the ticket price due aircrew cost excssed savings due to improved
airframe efficiency and reduced landing costs?
Martin | martin at
  #34
Old August 29th 20, 08:49 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Martin Gregorie wrote on 8/29/2020 11:32 AM:
ground?
details there.
Maybe the Celera people have that kind of info on their website.
  #35
Old August 29th 20, 10:04 PM posted to rec.aviation.soaring
airline operating costs. Did Eclipse Aviation's Eclipse 500 ever get
off the ground?
delivery details there.
of the ticket price due aircrew cost excssed savings due to improved
They don't, but its an interesting site anyway.
Martin | martin at
  #36
Old September 2nd 20, 03:53 PM posted to rec.aviation.soaring
John McLaughlin
Default Pitot leak?
Having disturbed the plumbing, I have a pitot leak! Being a turbo, the
glider has a pneumatic switch to select between nose and tail pitot
tubes. With nose selected, there's a leak. With tail selected, things are
much worse and I can't measure any pressure at all from the tail pitot
tube.
So should I suspect the switch or the connections to the switch? And is
it possible for the switch to have an internal fault which could cause
these symptoms?
  #37
Old September 2nd 20, 04:26 PM posted to rec.aviation.soaring
Default Pitot leak?
tube.
these symptoms?
Yes, pneumatic switch can fail....first check is tubing (sometimes nipping 1/4" from tubes and reattach), maybe a switch clean/lube can fix the issue. Tube nipping is what I did in '70's/'80's US cars with emissions. Just a bit to get a better seal. My method is sorta cheap/easy....check again. Some sort of pressure/vacuum device gauge is more accurate. Yes, make sure it holds a value.....I remember a spring flight where "blowing on the probe" showed needle movement....long term showed the mouse holes in cockpit tubing.....good for me, I could fly wind noise, pitch attitude, "seat of the pants".. I did a couple hours local with no real instruments..
  #38
Old September 2nd 20, 05:18 PM posted to rec.aviation.soaring
Dan Marotta
Default Pitot leak?
I've used a spare altimeter and a syringe to demonstrate sealed
pneumatic hoses.Â* You could also make a simple manometer.
tube.
these symptoms?
Yes, pneumatic switch can fail....first check is tubing (sometimes nipping 1/4" from tubes and reattach), maybe a switch clean/lube can fix the issue. Tube nipping is what I did in '70's/'80's US cars with emissions. Just a bit to get a better seal. My method is sorta cheap/easy....check again. Some sort of pressure/vacuum device gauge is more accurate. Yes, make sure it holds a value.....I remember a spring flight where "blowing on the probe" showed needle movement....long term showed the mouse holes in cockpit tubing....good for me, I could fly wind noise, pitch attitude, "seat of the pants". I did a couple hours local with no real instruments..
Dan, 5J
  #39
Old September 2nd 20, 06:28 PM posted to rec.aviation.soaring
Default Pitot leak?
A Cristal tube water column is almost a fundamental measuring instrument.
Make the positive or negative pressure with a syringe on a tee and check the altitude difference in time.
You can also check your ASI on some speed range with this is if you have the conversion table.
  #40
Old September 3rd 20, 01:56 AM posted to rec.aviation.soaring
Default Pitot leak?
If your pneumatic plumbing has leaks, I recommend this document from Mike Borgelt. It describes a thorough method of diagnosing and correcting problems with pitot, static and TE systems.
https://www.dropbox.com/s/iqklz472pw...Leaks.pdf?dl=0
Does not work with urinary leakage.
Saturday 072807 in Oshkosh Pt 4 - the Eclipse Concept Jet [4/5] - "Eclipse Concept Jet 4.jpg" yEnc (1/1) Just Plane Noise[_2_] Aviation Photos 0 July 31st 07 04:02 PM
Saturday 072807 in Oshkosh Pt 4 - the Eclipse Concept Jet [3/5] - "Eclipse Concept Jet 3.jpg" yEnc (1/1) Just Plane Noise[_2_] Aviation Photos 0 July 31st 07 04:02 PM
Saturday 072807 in Oshkosh Pt 4 - the Eclipse Concept Jet [2/5] - "Eclipse Concept Jet 2.jpg" yEnc (1/1) Just Plane Noise[_2_] Aviation Photos 0 July 31st 07 04:02 PM
Saturday 072807 in Oshkosh Pt 4 - the Eclipse Concept Jet [1/5] - "Eclipse Concept Jet 1.jpg" yEnc (0/1) Just Plane Noise[_2_] Aviation Photos 0 July 31st 07 04:02 PM
Saturday 072807 in Oshkosh Pt 4 - the Eclipse Concept Jet [1/5] - "Eclipse Concept Jet 1.jpg" yEnc (1/1) Just Plane Noise[_2_] Aviation Photos 0 July 31st 07 04:02 PM
