#31
On Fri, 06 May 2005 18:11:12 -0400, gregg wrote:
Hi Corcky, I have the paper here, somewhere, that describes the problem and the fix - which is more or less as you describe. What I wonder is: Was this fix proagated through to the Packard Merlins, for the life of production? Or were Mustang and later Spitfire Merlins fitted with some other solution which also solved the problem? thanks Here ya go Gregg, looks like this answers your question. Google is your friend :-D I just typed in "Spitfire" and "Orifice". The British, with their extremely droll sense of humour, called the original fix "Miss Shilling's Orifice" because the engineer who came up with it was a woman by the name of Miss Tilly Shilling. *** Begin Quote*** Carburettor design One of the great problems as discerned by pilots was the tendency for the carburetted engine to cut out under negative 'g'. Luftwaffe pilots learned to escape by simply pushing the nose of their aircraft down into a dive, as their fuel- injected engines did not cut out under these circumstances. Many authors have criticised this aspect of the Merlin design. In reality, like most engineering, it resulted from a design compromise- the drop in temperature developed in a carburetor results in an increase in the density of the fuel-air mixture when compared to that of a fuel injection system. As a consequence the Merlin produced a higher specific power output (horse power per pound) that the equivalent German engine. It was felt that this gave a higher power to weight ratio for the fighter and (rightly or wrongly) that this outweighed the disadvantages. By 1941 Miss Tilly Shilling in Farnborough had developed a partial cure for the problem. A diaphragm across the float chambers with a calibrated hole (the infamous "Miss Shilling's orifice"!) allowed negative 'g' manouvres, and was fitted as standard from March 1941. Sustained zero 'g' manouvres were not sorted out until somewhat later. In 1942 an anti-g version of the SU carburetor was fitted to single and two-stage Merlins. 1943 saw the introduction of the Bendix-Stromburg carburetor which injected fuel at 5psi through a nozzle direct into the supercharger and was fitted to the Merlins 66, 70, 76, 77, and 85. The final development was the SU injection carburetor which injected fuel into the supercharger using a fuel pump driven as a fuction of crankshaft speed and engine pressures, which was fitted to the 100 series Merlins. *** End Quote*** Corky Scott PS, in regards the higher horsepower per weight ratio claimed above, I'm fairly certain that this had nothing to do with using a carburetor versus fuel injection and the fuel density charge. I believe this had much more to do with the fact that the British and all the allied forces were using 100 octane fuel (100 octane fuel was Jimmy Doolittles little known contribution to victory in WWII) for all their combat flying machines where the Germans were limited for the most part to much lower octane fuel. This allowed the Rolls Royce engineers to raise the boost level of the supercharger in the Merlin engine to the point where it essentially equalled the Daimler Benz 601. This all occured right at about the time the two fleets of fighters clashed in the Battle of Britain. This, and the installation of three bladed constant speed propellers brought the Spitfire's performance to basic parity with the Me 109 and boosted the Hurricane's performance to the point where it wasn't the slug the Germans encountered over France anymore. Good thing too as there were roughly three times the number of Hurricanes as Spitfires and "Hurries" downed more German aircraft than the Spitfires. |
P-51H Mustang Restoration Project | mustanger | Restoration | 1 | November 26th 04 06:09 AM |
Mustang Restoration Project | mustanger | Restoration | 1 | October 9th 04 04:45 PM |
The Mustang Suite is done! | Jay Honeck | Home Built | 20 | January 15th 04 10:34 PM |
The Mustang Suite is done! | Jay Honeck | Piloting | 18 | January 13th 04 03:29 AM |
The Mustang Suite is done! | Jay Honeck | Owning | 8 | January 12th 04 03:48 PM |
