Marty from Sunny Florida wrote:
The sky was clear, and when I got my pre-flight briefing, the temp was 26 and dew point 16. It was unseasonably cool and very dry for Florida. At altitude, I knew the air had almost no moisture, but on the way up, we did have a typical hazy layer. Temp 26 and dewpoint 16 puts you well outside the icing region on this chart: http://www.ez.org/carb_ice.htm The temperature at altitude was probably well below 26, but even so you seem to be pretty well outside the temperature / dewpoint danger zone. Nevertheless, I agree with the consensus that carb ice is the best explanation. I'm mystified that the chart doesn't confirm. Dave |
On 5/4/2005 08:20, Dave Butler wrote:
Marty from Sunny Florida wrote: The sky was clear, and when I got my pre-flight briefing, the temp was 26 and dew point 16. It was unseasonably cool and very dry for Florida. At altitude, I knew the air had almost no moisture, but on the way up, we did have a typical hazy layer. Temp 26 and dewpoint 16 puts you well outside the icing region on this chart: http://www.ez.org/carb_ice.htm I assumed the temperatures provided by the original poster were in centigrade. That puts the temp at 79 deg F and the dew point at 61 deg F. Assuming 2 deg C drop per thousand feet, that puts the temperature at 57 deg F and the dew point at 35 deg F. Very close to the blue "Icing at glide and cruise power" band. The temperature at altitude was probably well below 26, but even so you seem to be pretty well outside the temperature / dewpoint danger zone. Nevertheless, I agree with the consensus that carb ice is the best explanation. I'm mystified that the chart doesn't confirm. Dave -- Mark Hansen, PP-ASEL, Instrument Student Sacramento, CA |
Mark Hansen wrote:
On 5/4/2005 08:20, Dave Butler wrote: Marty from Sunny Florida wrote: The sky was clear, and when I got my pre-flight briefing, the temp was 26 and dew point 16. It was unseasonably cool and very dry for Florida. At altitude, I knew the air had almost no moisture, but on the way up, we did have a typical hazy layer. Temp 26 and dewpoint 16 puts you well outside the icing region on this chart: http://www.ez.org/carb_ice.htm I assumed the temperatures provided by the original poster were in centigrade. That puts the temp at 79 deg F and the dew point at 61 deg F. Assuming 2 deg C drop per thousand feet, that puts the temperature at 57 deg F and the dew point at 35 deg F. Very close to the blue "Icing at glide and cruise power" band. You're right. I did the unit conversion correctly on one axis, but somehow muffed the other axis. Thanks. |
I'm extremely impressed with the response I've gotten to this post. I know
as a given fact that I will not get hurt in a general aviation aircraft that I'm flying during daylight hours. It's just a fact that comes with a great respect for the unexpected (I have a healthy fear of what I don't know). I'm a pre-flight nut case. I sump the fuel always, even after a 10 minute stop without re-fueling. The plane has an almost zero time status (now at 125 hours since major OH). I'd had an oil change a couple of days earlier and wondered if my mechanic had nicked the fuel line, or in some odd manner made a change to the fuel system, but that didn't and still doesn't make sense. Regarding my flight plan- I have been tossed out of Miami's Bravo airspace about as often as girls turned me down when I was a teenager. Not being shy, that's a lot. The only choice is over the ocean below 3,000, over MIA's airspace at 7,000 or the swamp to the west. I take the swamp because it's quiet (except for a few minutes when the big jets are turning final while West of MIA). At all times I check to make certain I have enough altitude (except when climbing out, of course), to make solid ground. This time I knew I could make the interstate, but would truly choose this as a last resort. The NTSB would get involved, and I'd have to get the plane trucked out of the everglades. To save my wife and I, I would do this in a heartbeat. My preference, of course, would be to put down at an airfield, which I did. Someone asked me what I'd do differently, and my wife and I have discussed this several times since Friday. The answer comes up every time - Nothing. I did and would still do exactly as before, but probably swap the first thing = full rich to first thing = carb heat. Other than that, no other change. I didn't touch the mags for concern I'd kill the engine. A dead mag will rob you of power, but it won't cause a rough sputter. I've been trained to make as little change to a failing engine as possible. Even an aiplane that's lost it's oil will continue to fly a lot longer if you don't touch the throttle or mixture. It's when you make a change that an opportunity to seize occurs. I did, however, push and poke everything else (or what litter there is to push in a C152). My wife who's not a pilot, but spends a lot of time in the right seat telling me where to go, concluded carb ice. She did this when we first touched down at Dade-Collier airport. My mechanic on the phone explained that a bad cylinder wouldn't fix itself, but water in the tanks would eventually blow through the system. The mechanic I met on the ramp also said bad fuel. My buddy and CFI back in Lantana (I called everyone), said bad gas. My wife insisted carb ice. So whadayall' say. Should I give my pilots license to Lynda or what? Marty |
Marty from Florida wrote:
I didn't touch the mags for concern I'd kill the engine. I agree with you completely. Switching to one mag would help only in a situation in which a mag has jumped time. Your description of the symptoms doesn't match what happens when a mag's mistimed (backfiring usually comes into the picture in this case). I would not have touched the ignition switch. George Patterson There's plenty of room for all of God's creatures. Right next to the mashed potatoes. |
![]() "Marty from Florida" marty@-x-x-x- remove -x-x- worth.net writes: [...] I know as a given fact that I will not get hurt in a general aviation aircraft that I'm flying during daylight hours. It's just a fact that comes with a great respect for the unexpected (I have a healthy fear of what I don't know). [..] I hate to say this, but all that respect and pre-flight attention is just not a guarantee that you won't be hurt. There are unfortunately many ways to get hurt in an airplane, some foreseeable, some preventable, and some neither. I don't want to scare you by dreaming up scenario after scenario, but rest assured that they exist. - FChE |
You should show this story in RAS. I think it is a good story for student
pilots to hear. Toks Desalu PP-ASEL "Dyin' to soar" "Marty from Sunny Florida" wrote in message ... Hello everyone. The end of my story is this; We landed safely in the middle of the Florida Everglades and didn't get a single Alligator bite. Here's what happened; On Friday, April 29th, we took our Cessna 152 from Lantana, Florida to the center of the State for gas and start our trek south to Key West. The total journey is a little over 2 hours. Forty five minutes after filling with gas in Pahokee, we were just below Alligator Alley (highway 75). Our engine hiccupped. A few minutes later, it hiccupped again, this time losing a couple of hundred RPM. We were at 6,800 feet, strait and level flight running at 75% power (about 2350 RPM). The mixture had been leaned back about 30 minutes earlier, and none of the engine instruments had changed from the time we made our cruise altitude. As the hiccups got closer together engine power dropped off significantly, grabbing our total attention. My first move was pulling up on the yoke to maintain altitude. I trimmed to our plane's best glide of 60 kts When the sputtering became a constant rough drone, the engine still held some power, and we could see nothing but marsh. I though about the choice between ditching in green or brown muck, not sure where the biggest alligators live. There was absolutely no solid ground as far as the eye could see. Solemnly, I rolled the 'standby' frequency to 121.5 acknowledging the severity of our predicament. Acting on the premise that the engine could quit at any moment and our best option was behind us on highway I75, I started a very gentle 180 degree turn. Oil pressure was in the green. Oil temp was in the green. Mags were on BOTH. The fuel showed close to full (I had at least 18 gallons useable). My only immediate change was to push the mixture to full rich, which had no effect. When I touched the throttle to add power, the RPM dropped. Gently, I returned the throttle and the power evened out. The sky was clear, and when I got my pre-flight briefing, the temp was 26 and dew point 16. It was unseasonably cool and very dry for Florida. At altitude, I knew the air had almost no moisture, but on the way up, we did have a typical hazy layer. My next move was carb heat, even though there was absolutely no visible moisture. It did smooth out the roughness slightly, but did nothing for the power loss. The engine was dying, and the math was simple. Sink at 500 fpt, 6,800 feet gives me about 13 minutes and at 60 kts, I'd get about 15 statute miles. I knew I could make the highway without an engine. I've personally had experience looking for downed aircraft in the Florida swamp, and know how difficult it is to spot a small plane. We needed to let someone know our position and situation. We had the skill to find the closest airport but every moment was precious. ATC could save valuable minutes and that might make the difference. With this in mind, I hit the radio's flip-flop button and announced our tail number on the emergency frequency. The Controller was a true professional. He asked me a few questions and instructed me to "ident" before assigning a squawk code. The radio reception was not clear, which generated a stream of "say agains". This, of course added to the general stress of the situation. Efficiently, he ascertained our position and vectored me to the Dade-Collier airport, which is in the middle of nowhere. Ironically, so were we! The strip was 17 miles to our southwest, which is farther than a dead engine would take me. We had been heading due north to a safe landing point on I75 when ATC advised us to turn our backs on the hwy and return south. In my heart, we turned away from solid ground to face only swamp again. I decided to trust fate and the ATC controller as I asked the alligators to gift me the extra minutes of engine power needed to make the airport. Trimmed back to slow flight, we managed to barely maintain altitude. We arrived at the 10,500 foot runway with 3,200 feet of altitude and 120 kts of air speed. I figure I could have made 4 complete turns around the pattern and still land hot. I have never been so relieved in my entire life. On the ground, we taxied to an area near two other planes. Relieved and curious I did a runup and the engine gave a text book performance. Our cell phones didn't work so we called the FBO on the radio. We were invited into the small building nearby where there was a phone. There we learned that the other two planes had landed the day before with similar symptoms. I phoned my mechanic and relayed the story. He gave me some great advice and a definite suggestion about what caused the problem. We returned to the plane to follow my mechanics instructions. Another mechanic, who had come to pick up one of the other downed planes kindly offered to look at my engine. He pulled the cowl open, checked the cables on the throttle, carb heat and mixture. He sat in the 152 with me while I did a regular and then full-power run up. The engine showed great response to throttle, the mixture choked it and the carb heat performed as advertised. This qualified mechanic was planning to fly out in a plane that landed in the same condition as ours. They offered us a ride if we were not comfortable flying our 152. We had options. Now, we had to make a decision to take the ride or hop in our plane and head out. The logic was: someone at some point would fly our 152 out, and we would again need to fly this same plane at some point ourselves. If we waited, what would be different? A qualified mechanic not only said it was safe, but was flying out a plane in the same condition. We decided the problem had resolved itself. We would fly. After a lengthy check, we headed for the runway. I did a steep climb over the field, continued uphill after completing a long, slow circuit of the airport, and headed north with a 500 FPM climb. All the while, I knew I could glide back to the runway if needed. It was late to start our day in the Keys so we turned towards home. When We sighted I75, I knew I was home free. If there was trouble we were guaranteed a level spot to land. We made Lantana at full power with no sign of the earlier problem. I must say, I am impressed with the FAA system and the people who dedicate their careers to the safety of our skies. This system that trains and relies on the good judgment of the individual pilot also supports the decisions necessary in crisis. While part of the mandate of the FAA is to enforce the laws, a pilot's decisions are respected even when they are examined. I find great comfort in the FAA and the service it provides to general aviation. If our highways resembled our skies, perhaps the average driver would be less likely to knowingly break the law. Here's my question to this group. What caused the engine failure? More than one thought is welcome, but please explain your answer. I have one of two possibilities in my head, and invite any questions, advise, opinions, or wisdom. Warm regards from one very happy pilot. Marty |
I've had real bad carb ice two times in a C-150 on perfectly clear
days. Both times the conditions were similar to yours. One time at 6500 feet; one time at 8500; about 70 degrees on the ground and about 42-44 at my cruising level each time, and also in the south. I got detailed weather information from Shaw AFB WX after I got back each time which showed relative humidity at my cruising altitude was just over fifty percent on both occasions, despite the beautiful clear skies and great visibility. This is when carb ice sneaks up on you and hits you hard, leaving you shocked and in disbelief, trying other solutions and cursing your mechanic. One time the carb heat cured the situation very quickly, the other it took quite a while and I had to keep adjusting mixture. When you have carb ice the mixture changes as the ice builds up and again as it melts away which sometimes has you "chasing" the engine with throttle and mixture manipulations to keep it running. I didn't read all the other posts and it may have been mentioned already but it's important to get full throttle in right away when dealing with carb ice also. In 3000 hrs flying mostly small piston planes I've learned to immediately pull carb heat full out and leave it out at any burble, hesitation, slow down or silence! Once you've got the carb heat engaged, go to full throttle if you haven't already and adjust mixture for best power -- you may have to keep adjusting the mixture several times as the shape of your venturi/level of blockage changes from ice melting or, (GASP) growing because your carb heat is inop or insufficient. - Brett Justus, ATP, G/S MEI/CFII, ASC |
