-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1 Ron Natalie wrote: A Guy Called Tyketto wrote: If you're working in any sort of Class C or D airspace, his response to you is in fact clearance into that airspace. No clearance is required. For Class C airspace, 2-way communication is the clearance into that airspace. No, ATC doesn't ahve to 'clear' you into it, but the communication is the clearance as is. So if he responds, you can fly through unless ATC tells you 'remain outside Class x Airspace'. Then you must read back something. The last sentence makes no sense whatsoever. If I call and he answers, that's two-way communciation and that's all that's required. If ATC tells you to remain outside a certain class airspace, you must read that back and remain outside that airspace until he clears you into it. Yes, it establishes communication, and normally that is all that's needed. but ATC's actual notification of 'remain outside Class x airspace' (where x is B, or C) overrides your clearance into that airspace. You will need to remain outside that airspace until told otherwise. Class B airspace requires ATC to tell you that you are cleared into it. So if ATC tells you 'radar contact location, altimeter xx.xx', you're cleared through that space where he's controlling, establishes 2-way comms, in which you need to acknowledge that he hears you whether it's a vector he's given you, or just replying with your callsign, that is all that's needed. You can reply back with the alt. setting, but it isn't really necessary. RADAR CONTACT is not required. Altimeter setting is not required. Readback is not required. You know he hears you because he responded to your radio call with your call sign. I'm having a hard time following your argument. Actually, for Class B, it does. AIM 3-2-3.d.2 and 3-2-3.e back that: 3-2-3.e: ATC Clearances and Separation. An ATC clearance is required to enter and operate within Class B airspace. VFR pilots are provided sequencing and separation from other aircraft while operating within Class B airspace. For Class C, AIM 3-2-4.3 states that 2-way comms must be established, and that is the clearance into/through Class C. But, if ATC tells you to remain outside of it, you *MUST* remain outside of it until told otherwise. Plus, a readback of that would be required. BL. - -- Brad Littlejohn | Email: Unix Systems Administrator, | Web + NewsMaster, BOFH.. Smeghead! ![]() PGP: 1024D/E319F0BF 6980 AAD6 7329 E9E6 D569 F620 C819 199A E319 F0BF -----BEGIN PGP SIGNATURE----- Version: GnuPG v1.4.1 (GNU/Linux) iD8DBQFCe74byBkZmuMZ8L8RAlqHAKCDiIwC/DZKvK74zjHk7smf7uxcSgCgtQUa oAEGUuO3awcwz2HutdswmF0= =bc9u -----END PGP SIGNATURE----- |
![]() "A Guy Called Tyketto" wrote in message m... If ATC tells you to remain outside a certain class airspace, you must read that back and remain outside that airspace until he clears you into it. If ATC tells you to remain outside you have to remain outside, whay requires you to read it back? RADAR CONTACT is not required. Altimeter setting is not required. Readback is not required. You know he hears you because he responded to your radio call with your call sign. I'm having a hard time following your argument. Actually, for Class B, it does. AIM 3-2-3.d.2 and 3-2-3.e back that: 3-2-3.e: ATC Clearances and Separation. An ATC clearance is required to enter and operate within Class B airspace. VFR pilots are provided sequencing and separation from other aircraft while operating within Class B airspace. For Class C, AIM 3-2-4.3 states that 2-way comms must be established, and that is the clearance into/through Class C. But, if ATC tells you to remain outside of it, you *MUST* remain outside of it until told otherwise. Plus, a readback of that would be required. Where's the requirement for radar contact? Where's the requirement for a readback? |
outside Class x airspace' (where x is B, or C) overrides your clearance into that airspace. You will need to remain outside that airspace until told otherwise. Wouldn't it also apply to Class D airspace? -- Mike Flyin'8 PP-ASEL Temecula, CA http://flying.4alexanders.com |
No clearance is required. For Class C airspace, 2-way communication is the clearance into that airspace. No, ATC doesn't ahve to 'clear' you into it, but the communication is the clearance as is. No clearance is required. Do you know what CLEARANCE means? If ATC tells you to remain outside a certain class airspace, you must read that back I don't have to read back anything. and remain outside that airspace until he clears you into it You will not EVER get a VFR clearance into class C or D airspace. RADAR CONTACT is not required. Altimeter setting is not required. Readback is not required. You know he hears you because he responded to your radio call with your call sign. I'm having a hard time following your argument. Actually, for Class B, it does. AIM 3-2-3.d.2 and 3-2-3.e back that: 3-2-3.e: ATC Clearances and Separation. An ATC clearance is required to enter and operate within Class B airspace. VFR pilots are provided sequencing and separation from other aircraft while operating within Class B airspace. What on earth does that passage have to do with anything? Radar contact is NOT required, Altimeter settings are not required, Readbacks are not required. A clearance is required. For Class C, AIM 3-2-4.3 states that 2-way comms must be established, and that is the clearance into/through Class C. But, if ATC tells you to remain outside of it, you *MUST* remain outside of it until told otherwise. Plus, a readback of that would be required. It says nothing about clearances. You're making things up again. |
![]() "A Guy Called Tyketto" wrote in message m... It's a bit more than that. If you're working in any sort of Class C or D airspace, his response to you is in fact clearance into that airspace. A clearance is not required for VFR operations in Class D or Class C airspace. If you're operating IFR you had a clearance into that airspace prior to your call. So if he responds, you can fly through unless ATC tells you 'remain outside Class x Airspace'. Then you must read back something. You can enter if he responds with your identification. If he doesn't you have to remain outside, but you don't have to read anything back. Class B airspace requires ATC to tell you that you are cleared into it. Class B airspace requires a clearance to enter, the clearance does not have to be "Cleared into Class B airspace". If you're on an IFR clearance that penetrates Class B airspace you're good to go. If you're VFR but have been cleared for a practice approach that requires entry of Class B airspace you're good to go. So if ATC tells you 'radar contact location, altimeter xx.xx', you're cleared through that space where he's controlling, establishes 2-way comms, in which you need to acknowledge that he hears you whether it's a vector he's given you, or just replying with your callsign, that is all that's needed. Say what? You might want to clean that sentence up a bit. |
Class B airspace
requires ATC to tell you that you are cleared into it. So if ATC tells you 'radar contact location, altimeter xx.xx', you're cleared through that space where he's controlling No. As you said, Class B airspace requires ATC to tell you you are cleared into it. You need to hear "Cleared through the Bravo airspace" or somesuch. Jose -- Get high on gasoline: fly an airplane. for Email, make the obvious change in the address. |
Jose wrote:
Class B airspace requires ATC to tell you that you are cleared into it. So if ATC tells you 'radar contact location, altimeter xx.xx', you're cleared through that space where he's controlling No. As you said, Class B airspace requires ATC to tell you you are cleared into it. You need to hear "Cleared through the Bravo airspace" or somesuch. Nope, you just have to have a clearance. "Cleared into/through the [NAME] Class Bravo" is just one form of it (and the safest for VFR's). |
Class B airspace
requires ATC to tell you that you are cleared into it. So if ATC tells you 'radar contact location, altimeter xx.xx', you're cleared through that space where he's controlling No. As you said, Class B airspace requires ATC to tell you you are cleared into it. You need to hear "Cleared through the Bravo airspace" or somesuch. Nope, you just have to have a clearance. "Cleared into/through the [NAME] Class Bravo" is just one form of it (and the safest for VFR's). I stand corrected (but I will still ask for the magic words rather than risk coming to the attention of the FAA!) In any case, "radar contact location, altimiter xx.xx" is not a clearance. Jose -- Get high on gasoline: fly an airplane. for Email, make the obvious change in the address. |
Jose wrote:
No. As you said, Class B airspace requires ATC to tell you you are cleared into it. You need to hear "Cleared through the Bravo airspace" or somesuch. The last clearance I got from New York ran something like "November 3162 Kebec, climb to 2500 feet, heading 355, stay west of the river, report at the Hudson tunnel." George Patterson There's plenty of room for all of God's creatures. Right next to the mashed potatoes. |
"George Patterson"
Jose wrote: No. As you said, Class B airspace requires ATC to tell you you are cleared into it. You need to hear "Cleared through the Bravo airspace" or somesuch. The last clearance I got from New York ran something like "November 3162 Kebec, climb to 2500 feet, heading 355, stay west of the river, report at the Hudson tunnel." Ask for the clearance. You're in violation without it. ATC should know better. moo |
What F-102 units were called up for Viet Nam | Tarver Engineering | Military Aviation | 101 | March 5th 06 03:13 AM |
