USA automated panel-cutting service?
Old February 1st 21, 04:23 PM posted to rec.aviation.soaring
AS
Default USA automated panel-cutting service?
It can do panels for side-by-side gliders, too!
Thanks, Eric! I will keep that in mind. My current panel was laser-cut out of a thin sheet of Aluminum and has cut-outs for all the toys I need to fit.
Uli
'AS'
  #32
Old February 1st 21, 08:22 PM posted to rec.aviation.soaring
Kenn Sebesta
Another CAD package you can use that is FREE is ONSHAPE (onshape.com/en). It also has a bit of a learning curve (all capable CAD programs do) but for jobs of limited complexity, such as a console, you can use onshape free.
Rich L.
I couldn't more strongly recommend OnShape. It's founded by the guys who founded SolidWorks. They sold off SolidWorks to Dassault, and then set about fixing all the architectural legacy mistakes. The new way of approaching parts by building in Part Studios is far more natural then SW's one-part-per-document approach.
Source: many of my friends work for OnShape, and one of the founders was their college professor.
  #33
Old February 3rd 21, 04:33 AM posted to rec.aviation.soaring
Craig Funston[_3_]
On Monday, February 1, 2021 at 12:22:26 PM UTC-8, Kenn Sebesta wrote:
Another CAD package you can use that is FREE is ONSHAPE (onshape.com/en). It also has a bit of a learning curve (all capable CAD programs do) but for jobs of limited complexity, such as a console, you can use onshape free..
Rich L.
Dave, lots of sign shops have CNC routers with a large enough bed to do a panel. Fiberglass should be easy for them.
Cheers,
Craig JN
  #34
Old February 5th 21, 04:26 AM posted to rec.aviation.soaring
Doug Bailey
I 3D printed a CNC machine (search for MPCNC and you'll find it quicker than typing a link) that uses 3D printer hardware and circuit boards to move the router. Here's mine working...
https://youtu.be/Iyhvc_-HReQ
The table is made from hickory flooring left over from my remodel. The MPCNC is more than capable of cutting a panel in composite.
  #35
Old February 5th 21, 03:08 PM posted to rec.aviation.soaring
Kenn Sebesta
MPCNC is awesome. The LowRider (which is the one I built, https://forum.v1engineering.com/t/mo...m-1-25/23253/2) might be more appropriate for a instrument panel, depending on the dimensions. For those who haven't read about them yet, they're the same but the smaller MPCNC will hold tolerances better, while the LowRider can do full 8x4' panel cutting.
The cool thing about either is that you can swap out the metal tubes to change its size. So someone could make it big for a one-off, and then go back to desktop size.
  #36
Old February 6th 21, 09:04 PM posted to rec.aviation.soaring
2G
Here is a video on how to build an MPCNC:
https://www.youtube.com/watch?v=_atw3e0nIrg
Here is another video on how to fix the problems in that MPCNC:
https://www.youtube.com/watch?v=RDnGvhdGFEY
Tom
  #37
Old February 6th 21, 09:40 PM posted to rec.aviation.soaring
2G
MPCNC is awesome. The LowRider (which is the one I built, https://forum..v1engineering.com/t/m...m-1-25/23253/2) might be more appropriate for a instrument panel, depending on the dimensions. For those who haven't read about them yet, they're the same but the smaller MPCNC will hold tolerances better, while the LowRider can do full 8x4' panel cutting.
Tom
Here is a manufactured CNC at an incredible price:
https://www.toolots.com/cnc-3018-min...waAtKUEALw_wcB
Tom
  #38
Old February 6th 21, 09:41 PM posted to rec.aviation.soaring
2G
Tom
Tom
And here is a tutorial on how to use GRBL:
https://howtomechatronics.com/tutori...-with-arduino/
Tom
  #39
Old February 9th 21, 10:50 PM posted to rec.aviation.soaring
Michael Bamberg
Tom
Tom
That one is much too small for instrument panels!
  #40
Old February 16th 21, 03:45 AM posted to rec.aviation.soaring
2G
The table is made from hickory flooring left over from my remodel.. The MPCNC is more than capable of cutting a panel in composite.
Tom
Tom
The dimensions aren't given, but you might be able to mill the panel in two passes. In any event, it's a hell of a price for general purpose use.
Tom
Some LiFePO4 Battery Testing Results Manual and Automated John DeRosa OHM Ω http://aviation.derosaweb.net Soaring 32 October 20th 19 03:26 PM
automated flap setting Wallace Berry[_2_] Soaring 16 September 26th 16 04:03 PM
Cutting 57mm holes in the instrument panel.....how to? John Bojack[_2_] Soaring 20 November 12th 10 09:15 PM
Automated Assisted Flight System James Long Home Built 2 March 5th 06 09:58 AM
FAI/IGC/CAI File Name Decoding - Automated!! ContestID67 Soaring 9 September 24th 05 09:26 AM
