Today I flew into KBFI (Boeing field) which is class D and has
extentions that underlie the Class B that require close attention to altitudes and headings so as to stay clear. Today the winds were favoring 31L (and 31R) and I came in from the west on the Vashon approach--the most common approach from the west. I was on a left downwind for 31L and the tower told me I was number three following an Arrow on about a 2 mile straight in final (Valley approach?). I acknowledged the traffic, and was waiting for it to come up on my 9 o'clock before turning base so as to allow enough spacing. The controller suddenly told me that I was too far south and said either that I had busted into surface B or was about to. (I never did clearly hear which). Unless one turns a fairly close in base here--within about a half mile or less--you end up in class B surface. My questions: 1.Assuming I busted B; who is reponsible if the controller asks me to follow an aircraft that is too far out on a straight in? I mean, I can reduce speed, s-turn, and the like but I can't turn base until the aircraft on final is a safe distance away, right? 2.Is the controller supposed to arrange things so that I *can* turn base and not be in conflict with other aircraft? 3.How would you resolve the problem if it were happening to you ? Any thoughts would be appreciated... Antonio |
![]() Antoņio wrote: Today I flew into KBFI (Boeing field) which is class D and has extentions that underlie the Class B that require close attention to altitudes and headings so as to stay clear. Today the winds were favoring 31L (and 31R) and I came in from the west on the Vashon approach--the most common approach from the west. I was on a left downwind for 31L and the tower told me I was number three following an Arrow on about a 2 mile straight in final (Valley approach?). I acknowledged the traffic, and was waiting for it to come up on my 9 o'clock before turning base so as to allow enough spacing. The controller suddenly told me that I was too far south and said either that I had busted into surface B or was about to. (I never did clearly hear which). Unless one turns a fairly close in base here--within about a half mile or less--you end up in class B surface. My questions: 1.Assuming I busted B; who is reponsible if the controller asks me to follow an aircraft that is too far out on a straight in? I mean, I can reduce speed, s-turn, and the like but I can't turn base until the aircraft on final is a safe distance away, right? 2.Is the controller supposed to arrange things so that I *can* turn base and not be in conflict with other aircraft? 3.How would you resolve the problem if it were happening to you ? Any thoughts would be appreciated... Antonio You are always responsible for remaining clear of Class B airspace unless you receive a clearance to enter Class B airspace. You should be well aware of the boundaries at a secondary airport like BFI. |
Uh, If you are on an IFR flight plan, you don't need to hear "cleared
for Class B". At least that is always the way it has worked for me. |
"Doug" wrote in message
oups.com... Uh, If you are on an IFR flight plan, you don't need to hear "cleared for Class B". At least that is always the way it has worked for me. You always need a clearance to be in Class B. But if your IFR clearance takes you through Class B, then that *is* a clearance to be in Class B, even if the words "Class B" are not mentioned in the clearance. --Gary |
![]() Doug wrote: Uh, If you are on an IFR flight plan, you don't need to hear "cleared for Class B". At least that is always the way it has worked for me. That's correct. But, it doesn't seem this guy was on an IFR flight plan. I don't find any "Vashon Approach" in my IFR charts for KBFI. |
"Doug" wrote:
Uh, If you are on an IFR flight plan, you don't need to hear "cleared for Class B". At least that is always the way it has worked for me. The applicable reg is 91.131(a)(1): "No person may operate an aircraft within a Class B airspace area except [...] The operator must receive an ATC clearance from the ATC facility having jurisdiction for that area before operating an aircraft in that area" If you are IFR, you have "a clearance". You don't have to specifically be cleared into the class bravo, you just have to have "a clearance". |
![]() "Doug" wrote in message oups.com... Uh, If you are on an IFR flight plan, you don't need to hear "cleared for Class B". At least that is always the way it has worked for me. If you are in IFR clearance you only got to distinguinsh two classes of airspace: controlled and uncontrolled. You don't need to worry about the classes of controlled airspace. |
![]() Guillermo wrote: "Doug" wrote in message oups.com... Uh, If you are on an IFR flight plan, you don't need to hear "cleared for Class B". At least that is always the way it has worked for me. If you are in IFR clearance you only got to distinguinsh two classes of airspace: controlled and uncontrolled. You don't need to worry about the classes of controlled airspace. Well, you do have to worry about equipage to go above FL 240 (DME) and above 290 (RVSM). |
wrote in message ...
Guillermo wrote: "Doug" wrote in message oups.com... Uh, If you are on an IFR flight plan, you don't need to hear "cleared for Class B". At least that is always the way it has worked for me. If you are in IFR clearance you only got to distinguinsh two classes of airspace: controlled and uncontrolled. You don't need to worry about the classes of controlled airspace. Well, you do have to worry about equipage to go above FL 240 (DME) and above 290 (RVSM). I'm not planning on going above FL240 in the C172RG that I fly. I wish I were flying something that could go that high up ![]() What is RVSM? |
![]() "Antoņio" wrote in message oups.com... Today I flew into KBFI (Boeing field) which is class D and has extentions that underlie the Class B that require close attention to altitudes and headings so as to stay clear. Today the winds were favoring 31L (and 31R) and I came in from the west on the Vashon approach--the most common approach from the west. I was on a left downwind for 31L and the tower told me I was number three following an Arrow on about a 2 mile straight in final (Valley approach?). I acknowledged the traffic, and was waiting for it to come up on my 9 o'clock before turning base so as to allow enough spacing. The controller suddenly told me that I was too far south and said either that I had busted into surface B or was about to. (I never did clearly hear which). Unless one turns a fairly close in base here--within about a half mile or less--you end up in class B surface. My questions: 1.Assuming I busted B; who is reponsible if the controller asks me to follow an aircraft that is too far out on a straight in? I mean, I can reduce speed, s-turn, and the like but I can't turn base until the aircraft on final is a safe distance away, right? 2.Is the controller supposed to arrange things so that I *can* turn base and not be in conflict with other aircraft? 3.How would you resolve the problem if it were happening to you ? Any thoughts would be appreciated... 1. Ask the controller to call my base turn. 2. Invest in a Garmin 196 at a minimum 3. File IFR when going into KBFI 4. Not get that close (and boxed in) to class B without permission to enter. My thoughts in order of preference Howard Antonio |
Carrying flight gear on the airlines | Peter MacPherson | Piloting | 20 | November 25th 04 12:29 AM |
World Class: Recent Great News | Charles Yeates | Soaring | 58 | March 19th 04 06:58 PM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
One Design viability? | Stewart Kissel | Soaring | 41 | December 10th 03 03:27 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
