Michael 182 wrote:
I'm kind of curious - does anyone with more than 100 hours do a flight plan, with winds and all, before they fly cross country? Most of my planning is of the fuel stop, or occasionally detour for weather variety - but it is rare for me to include more than one or two waypoints in my "plan", and I almost never file an airway, even when I file ifr. Maybe it's because I live in the west. A typical flight plan will be Longmont - Amarillo - Austin, or if the winds are good, Longmont - Austin. What do others do? Michael I used to calculate everything manually, and took pride in interpolating wind / temperature data, and tweaking my climb and descent profiles to get the total time enroute accurate to a minute or two. That became boring, so I then concentrated on improving the speed with which I did all the calculations. Then my time became money, and I realized that doing it manually no longer served any purpose (there's only so much you can learn from a whiz-wheel, or calculating these things manually...particularly after a few zillion times). Now I let the computers do it and I find that given the right data, they're accurate to within 1 minute. I don't dig holes with shovels anymore. FYI, if you want to plan / file direct VFR, fine. But don't try that IFR -- particularly in the northeast. It irritates the controllers, and no surprise. The AIM specifies that you should file airways (sorry I don't have the exact reference handy...but just read Don Brown's columns on Avweb for more info). The entire ATC system (airspace boundaries, etc.) are based on the airway system, and when you file direct, you increase controller workload. Given the shortage of controllers, that's just about the last thing you should do. -Doug -- -------------------- Doug Vetter, CFIMEIA http://www.dvcfi.com -------------------- |
I would say that is increasingly a NE issue. In the SE boonies (south
of the Wash ADIZ), once they see /G, they tend to clear you direct *independent* of your plan. In FL my experience is that you will be initially cleared on airways then either thru request or offer, you can get direct for many portions. Leave the busier FL airspace and it's "cleared direct destination". I guess it's fewer words to say or something. Amazing! Doug Vetter wrote: FYI, if you want to plan / file direct VFR, fine. But don't try that IFR -- particularly in the northeast. It irritates the controllers, and no surprise. The AIM specifies that you should file airways (sorry I don't have the exact reference handy...but just read Don Brown's columns on Avweb for more info). The entire ATC system (airspace boundaries, etc.) are based on the airway system, and when you file direct, you increase controller workload. Given the shortage of controllers, that's just about the last thing you should do. -Doug -- -------------------- Doug Vetter, CFIMEIA http://www.dvcfi.com -------------------- |
Maule Driver wrote:
I would say that is increasingly a NE issue. In the SE boonies (south of the Wash ADIZ), once they see /G, they tend to clear you direct *independent* of your plan. In FL my experience is that you will be initially cleared on airways then either thru request or offer, you can get direct for many portions. Leave the busier FL airspace and it's "cleared direct destination". I guess it's fewer words to say or something. Amazing! It probably has more to do with traffic count per square mile (and therefore workload), which is almost always lower in places other than the northeast. Getting direct may also have something to do with getting lucky, no matter where you fly. Don Brown indicates that one of the chief reasons they hate pilots who file direct (even out in the boonies where radio calls are made every 100 miles) is that if a direct courseline quickly crosses or nears several sector boundaries (which can happen in both the horizontal or vertical planes), they have to do tons of point outs and (lacking successful communication with the neighboring controllers) radar vectors, reroutes, and other hand-holding that would not have been necessary had the pilot filed airways and avoided those trouble-spots in the first place. That said, on my way down the coast from New Jersey to Florida a couple weeks ago, I was about 10 miles south of my second departure point (Newport News, VA) when I was cleared to my destination (N. Myrtle Beach, Grand Strand) 225NM out -- a personal direct-to distance record under IFR. Of course, V1 is almost a straight line between the two airports and more or less equivalent to a direct-to route (thus I was getting lucky) but in general I agree with you that you are certainly more likely to get direct in places OTHER than the northeast. -Doug -------------------- Doug Vetter, CFIMEIA http://www.dvcfi.com -------------------- |
Maybe ATC in the SE Atlantic seaboard have somehow 'broken the code' on
handling direct. I swear that your experience with direct to N Myrtle is becoming the norm rather than the exception. Between the Wash ADIZ and Jacksonville I've been filing airways and getting cleared direct without requesting it. And I'm filing the airways to avoid SUAs that clog the airspace. The interesting part is that for someone like me flying at 9 or below, flights typically involve center and multiple approaches with constant switching. And yet I'm getting cleared direct 3 or 4 handoffs out from my destination. Who knows, it may be particular to the routes. I don't know who Doug Brown is but I'm going to continue to be pretty aggressive in filing and/or requesting direct where I consider it a reasonable request. And I expect to get it more often than not outside of those areas where it just isn't doable (ADIZ, Phille/NY corridor, FL ooastal routes). It's working better than one might expect in my experience. I'll have to get out more.... Doug Vetter wrote: Maule Driver wrote: I would say that is increasingly a NE issue. In the SE boonies (south of the Wash ADIZ), once they see /G, they tend to clear you direct *independent* of your plan. In FL my experience is that you will be initially cleared on airways then either thru request or offer, you can get direct for many portions. Leave the busier FL airspace and it's "cleared direct destination". I guess it's fewer words to say or something. Amazing! It probably has more to do with traffic count per square mile (and therefore workload), which is almost always lower in places other than the northeast. Getting direct may also have something to do with getting lucky, no matter where you fly. Don Brown indicates that one of the chief reasons they hate pilots who file direct (even out in the boonies where radio calls are made every 100 miles) is that if a direct courseline quickly crosses or nears several sector boundaries (which can happen in both the horizontal or vertical planes), they have to do tons of point outs and (lacking successful communication with the neighboring controllers) radar vectors, reroutes, and other hand-holding that would not have been necessary had the pilot filed airways and avoided those trouble-spots in the first place. That said, on my way down the coast from New Jersey to Florida a couple weeks ago, I was about 10 miles south of my second departure point (Newport News, VA) when I was cleared to my destination (N. Myrtle Beach, Grand Strand) 225NM out -- a personal direct-to distance record under IFR. Of course, V1 is almost a straight line between the two airports and more or less equivalent to a direct-to route (thus I was getting lucky) but in general I agree with you that you are certainly more likely to get direct in places OTHER than the northeast. -Doug -------------------- Doug Vetter, CFIMEIA http://www.dvcfi.com -------------------- |
![]() Doug Vetter wrote: Don Brown indicates that one of the chief reasons they hate pilots who file direct (even out in the boonies where radio calls are made every 100 miles) is that if a direct courseline quickly crosses or nears several sector boundaries (which can happen in both the horizontal or vertical planes), they have to do tons of point outs and (lacking successful communication with the neighboring controllers) radar vectors, reroutes, and other hand-holding that would not have been necessary had the pilot filed airways and avoided those trouble-spots in the first place. This is a typical FAA attitude that is very difficult to overcome. Don't do something that is convenient to you because I then have to work too hard. Or change what I have been doing for the last 50 years. Busy airspace is one thing but to say they hate pilots filing direct because that line nicks other sectors and airspaces is assinine. |
I haven't filed a VFR flight plan for a lonnnggggg time. I use Flight
Following or if I'm current an IFR plan. "Michael 182" wrote in message ... I'm kind of curious - does anyone with more than 100 hours do a flight plan, with winds and all, before they fly cross country? Most of my planning is of the fuel stop, or occasionally detour for weather variety - but it is rare for me to include more than one or two waypoints in my "plan", and I almost never file an airway, even when I file ifr. Maybe it's because I live in the west. A typical flight plan will be Longmont - Amarillo - Austin, or if the winds are good, Longmont - Austin. What do others do? Michael |
with winds and all, before they fly cross country? Sure. Especially for long, low XCs. I find it very convenient to have waypoints, frequencies, "things to watch for", and other stuff all laid out neatly on a sheet of paper in the cockpit. One of the additional things I add on my sheet is runway layout and FBO I'm using. I pre-plan that to avoid surprizes like outrageous parking fees (which would be free across the field) and such. Jose -- The price of freedom is... well... freedom. for Email, make the obvious change in the address. |
Not sure whether you are referring to a flight plan with ATC or a the
kind of plan you do to estimate headings, times, and fuel for planning purposes. I never file VFR. Often file IFR. Almost always fly for travel and usually have someone on the other end curious about when to pick us up. So, I'm always interested in at least how long it will take to get there. With the winds on ADDS, I love to plan the optimal altitude for favorable winds. The accuracy is amazing and the findings sometimes surprising (e.g. headwinds being substantially less at 8,000 than at 6,000 on a given day). $3.50 fuel and a slow plane make the exercise valuable on even 1 hour flights. GPS makes heading calcs unneccessary. Duats provides accurate winds and dead reckoning flight plans. GPS groundspeed allows detailed wind soundings during the climb. Again, amazing how accurate ADDS winds are. Major victory flying Raleigh NC to Tampa FL non-stop both ways last weekend. Planned IFR both legs with 1 stop. Detailed wind information, 10 mins of cloud flying, range extenders, and a sleeping passenger allowed non-stoppers of 4.5 and 5 hours (it was worth it). Michael 182 wrote: I'm kind of curious - does anyone with more than 100 hours do a flight plan, with winds and all, before they fly cross country? Most of my planning is of the fuel stop, or occasionally detour for weather variety - but it is rare for me to include more than one or two waypoints in my "plan", and I almost never file an airway, even when I file ifr. Maybe it's because I live in the west. A typical flight plan will be Longmont - Amarillo - Austin, or if the winds are good, Longmont - Austin. What do others do? Michael |
![]() "Maule Driver" wrote in message . com... Not sure whether you are referring to a flight plan with ATC or a the kind of plan you do to estimate headings, times, and fuel for planning purposes. I always do a PLOG |
RAF Blind/Beam Approach Training flights | Geoffrey Sinclair | Military Aviation | 3 | September 4th 09 06:31 PM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 02:26 PM |
Flight Simulator 2004 pro 4CDs, Eurowings 2004, Sea Plane Adventures, Concorde, HONG KONG 2004, World Airlines, other Addons, Sky Ranch, Jumbo 747, Greece 2000 [include El.Venizelos], Polynesia 2000, Real Airports, Private Wings, FLITESTAR V8.5 - JEP | vvcd | Piloting | 0 | September 22nd 04 07:13 PM |
WINGS: When do the clocks start ticking? | Andrew Gideon | Piloting | 6 | February 3rd 04 03:01 PM |
Flight instructors as Charter Pilots | C J Campbell | Piloting | 6 | January 24th 04 07:51 AM |
