#31
![]() "Doug" wrote in message ups.com... What kind of engines did the aircraft on the Jefferson City flight have? What kind of engines are on the Boeings that Bob flew? Gas Turbine Engines. Mike MU-2 |
#32
Mike,
Yes, Gas Turbine Engines. But what design, what manufacturer? Different airplanes and different engines behave differently. But think about it. Heat gets generated at lower altitude. There is a thermal lag. That heat gets dissipated at higher altitude. If you are climbing VERY fast, the incoming air is less dense, you can set up a cycle where heat is accumulating faster than it can be transferred due to the denser air creating more combustion. Sort of like having an extra boost of turbo charging. With the slower airspeed in a climb, and if the engine is operating close to the edge of it's heat dissipation maximum, it COULD cause overheating. Anyway, you see my point, I hope. (Even if it is wrong in this case). But I will yield, as I have no supporting data. The supporting data would be a climb limitation in the manufacturers flight manual. I don't have it, but I am sure it exists. These internet arguments are never won anyway. I'm not really interested in winning. Probably should have worded my initial statement a little less concretely. I honestly thought this was the cause. Apparently not, or at least not sure yet, or not public yet. Whatever. It's just my theory. Sorry about the two pilots dying. That is a tough one for the families I am sure. Whatever the reason is, I am sure we all want it found out so that other pilots and passengers can benefit from the knowledge. Airline travel is very safe, statistically, by the way. But you already know that. Sorry if I ruffled any feathers.. |
#33
"Doug" wrote
But think about it. Heat gets generated at lower altitude. There is a thermal lag. That heat gets dissipated at higher altitude. If you are climbing VERY fast, the incoming air is less dense, you can set up a cycle where heat is accumulating faster than it can be transferred due to the denser air creating more combustion. Sort of like having an extra boost of turbo charging. With the slower airspeed in a climb, and if the engine is operating close to the edge of it's heat dissipation maximum, it COULD cause overheating. Anyway, you see my point, I hope. (Even if it is wrong in this case). Young man...you don't have the foggiest idea about the operation of aircraft jet engines. Bob Moore |
#34
Bob,
This one certainly has me curious as to the cause. I've got very limited experience in fanjets, but I've flown them at max operating altitude and consider it a normal operation. In the turbojet 20-series Lears we regularly went to FL450 in the 23 and 24B (usually after one hour of flight) to get the fuel burns as low as possible when hauling freight (plus, back then, there was nobody up that high and we always got direct). In one version of the 25 we could go to FL510 although even when very light, the climb rate going through 490 was so slow we wondered whether we'd make 510 before time to start down (and, as you know, you could see the curvature of the earth). I did lose an engine at FL450 in a 24B when the captain moved the power levers fairly quickly and an old fuel control unit couldn't handle it at that altitude, flaming out the engine. We got a relight at 17,000 although, as I recall, the relight envelope was supposed to go to 25,000 (let's just say maintenance at that organization was not exactly top notch - long out of business). As a result, I'm curious as to what would cause both engines to go quiet - the only common system is fuel, although I don't know the CRJ systems at all and wonder whether there is/are any procedure(s) that must be followed above a certain altitude regarding pumps or if the company regularly flew so low that they didn't put in any additives such as PRIST to prevent ice in the fuel. Have to contact a CRJ captain friend of mine and see what she says. Also wondering why the relight was unsuccessful...just doesn't make sense, jet engines are so darn simple in operation - add fuel, ignite and go. Also wondering why they couldn't make an airport from 410 in central Missouri. The overheating comment on this thread is laughable. And I thought I'd heard all of the nutty theories of aircraft accidents. Or maybe it was some localized heavy gravity that shortened the glide range.... Your thoughts? Warmest regards, Rick |
#35
#36
"Bob Moore" wrote in message
. 122... [...] I'm putting my money on wrong fuel (freeze point) for the existing OAT. I think the climb rate theory has been sufficiently disputed. However, I find the thought that outside air temperature at FL410 might be an issue, when (presumably) the airplane was being operated safely at a lower altitude AT THE EXACT SAME TEMPERATURE, pretty silly too. I don't know the exact altitude of the tropopause on the day of the accident. But it was likely in the neighborhood of FL300 give or take a few thousand feet. From the tropopause all the way up to FL410 (and higher), the temperature would have been a relatively constant -57 C. Sorry...that theory doesn't pass the sniff test any more than the "overtemp due to climb" theory does. Not unless your theory is claiming that the altitude the pilots climbed to was entirely irrelevant, and that the accident would have happened regardless (I would find that to be a reasonable inclusion in the theory, though it would beg the question as to why other planes didn't have similar troubles that day, since the fuel presumably sold to a wide variety of aircraft was apparently not suitable for high-altitude flight). Pete |
#37
![]() "Doug" wrote in message oups.com... Mike, Yes, Gas Turbine Engines. But what design, what manufacturer? Different airplanes and different engines behave differently. But think about it. Heat gets generated at lower altitude. There is a thermal lag. That heat gets dissipated at higher altitude. If you are climbing VERY fast, the incoming air is less dense, you can set up a cycle where heat is accumulating faster than it can be transferred due to the denser air creating more combustion. Sort of like having an extra boost of turbo charging. With the slower airspeed in a climb, and if the engine is operating close to the edge of it's heat dissipation maximum, it COULD cause overheating. Anyway, you see my point, I hope. (Even if it is wrong in this case). But I will yield, as I have no supporting data. The supporting data would be a climb limitation in the manufacturers flight manual. I don't have it, but I am sure it exists. These internet arguments are never won anyway. I'm not really interested in winning. Probably should have worded my initial statement a little less concretely. I honestly thought this was the cause. Apparently not, or at least not sure yet, or not public yet. Whatever. It's just my theory. Sorry about the two pilots dying. That is a tough one for the families I am sure. Whatever the reason is, I am sure we all want it found out so that other pilots and passengers can benefit from the knowledge. Airline travel is very safe, statistically, by the way. But you already know that. Sorry if I ruffled any feathers.. Frankly the overtemping due to climb theory is ridiculous and it doesn't matter what gas turbine engines you are talking about. The fuel controllers constantly sample inlet air temp and pressure along with the pressure at the compressor discharge and trim the fuel flow to prevent the hot section temperature from changing without power lever movement. More sophisticated fuel controllers will allow the temp to rise with decreasing mass flow to the temperature limit (or one of several limits) while keeping some other parameter constant (like N1, fan rpm) then trim the fuel flow back to avoid over temping the hot section. In any case it is fuel flow (ie mixture) that determines temperature and the fuel controller is not going to be fooled by climbing fast. You are thinking about the problem like you would a piston engine. Limiting turbine engine temperatures are analogous to EGT on a piston engine, they are *not* analagous to CHT on a piston engine. It is a function of fuel flow which is constantly monitored and adjusted by the fuel controller...ie a *mixture* issue not a cooling issue. Mike MU-2 |
#38
("Guy Elden Jr" wrote)
[snip] Engine out issues aside, one thing that struck me about this accident was the fact that these guys had so much altitude in which to glide to a safe landing that I wonder if it was actually _too_ much altitude? I don't know how far away the airport was that they finally decided upon for the emergency landing attempt, but clearly they didn't succeed in meeting their goal. Were they too complacent in thinking they'd be able to restart the engines, given that they were nearly 8 miles up? My thoughts exactly. 10:1 = 80 miles 15:1 = 120 miles I wonder if they had x-length of runway as a landing requirement set in their minds? Or, like that person in the Everglades, with a rough running engine a month ago, heading for a patch of freeway - then diverting to an airport that ATC advised, even though he wasn't sure if he could make it if the engine quit. (It worked out for him) I wonder if they had no ATC to advise them, would they have chosen to put it down at a smaller (closer) 3,000-ft strip airport? Or, maybe they were ok with the chosen field, but did some math wrong in their heads, and didn't catch it until too late. Very sad. Also, has 'no fuel' been ruled out? I might have missed that part. Montblack |
#39
"Peter Duniho" wrote
I think the climb rate theory has been sufficiently disputed. However, I find the thought that outside air temperature at FL410 might be an issue, when (presumably) the airplane was being operated safely at a lower altitude AT THE EXACT SAME TEMPERATURE, pretty silly too. Maybe cold soaking...as often happened to me Sorry...that theory doesn't pass the sniff test any more than the "overtemp due to climb" theory does. Not unless your theory is claiming that the altitude the pilots climbed to was entirely irrelevant, and that the accident would have happened regardless (I would find that to be a reasonable inclusion in the theory, though it would beg the question as to why other planes didn't have similar troubles that day, since the fuel presumably sold to a wide variety of aircraft was apparently not suitable for high-altitude flight). The predicted temp at cruise altitude determined the type of fuel to be loaded...Jet A, Jet B, Kero A-1, or JP-4. I have had to alter the cruise altitude due to the type of fuel that had been previously loaded. Bob Moore |
#40
. 122... Maybe cold soaking...as often happened to me That would not depend on the altitude however. In fact, if anything, "cold soaking" would be more of a problem at a lower altitude, since there is more thermodynamic mass to absorb heat from the airplane (and thus the fuel). The predicted temp at cruise altitude determined the type of fuel to be loaded...Jet A, Jet B, Kero A-1, or JP-4. I have had to alter the cruise altitude due to the type of fuel that had been previously loaded. Thank you for that clarification. That does reinforce my understanding that fuel temperature is unlikely to have been causal in this accident. That is, there's no suggestion that the planned cruise altitude was low enough for a "high temperature" fuel to have been loaded. Any cruise altitude even moderately into the flight levels would require "low temperature" fuel (I apologize for the generic terms...I don't know which types have what temperature ratings). Of course, without knowing the planned cruise altitude for certain, I can't rule out the fuel theory. It could have been that the flight was originally planned at a relatively low altitude. One thing your theory has going for it is that it might explain the difficulty in restarting the engines, since the fuel might not have had time to warm up enough during the glide, especially assuming the temperatures would have remained too cold to do any good for most of the glide anyway. In any case, until such specifics are released, I still don't think that speculation is likely to come up with much useful data. ![]() be able to provide us with some real answers at some point, once they've had enough time to sift through all of the facts. Pete |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 02:26 PM |
Palo Alto airport, potential long-term problems... | [email protected] | Piloting | 7 | June 6th 05 11:32 PM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | November 1st 03 06:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | October 1st 03 07:27 AM |
Where to soar near Jefferson City - Missouri? | Peter | Soaring | 2 | September 15th 03 03:29 PM |
