VFR Flight Following -- What's going on here?
Old June 20th 05, 11:21 PM
Chris G.
I have placed a call to the local FSDO for the exact regulations
governing this, but I speak from experience, having been a State SAR
Coordinator backup for the State of Oregon a few years ago.
Chris
Peter Duniho wrote:
"Chris G." nospam@noemail wrote in message
eenews.net...
The way the SAR system works is that once the FAA has radar contact with
you and are providing radar services, they will continue to do so unless
they are unable (due to lack of radar coverage) or you cancel them. If
you fall below their radar coverage while utilizing their services, then
they begin the SAR process.
I have never seen any documentation of this claim, for VFR aircraft. My
understanding is that the scenario in this thread was motivated solely at
the discretion of the controller, that there is no automatic search and
rescue for abnormally terminated flight following, and that only a VFR
flight plan guarantees a search and rescue attempt for missing VFR flights.
Can you provide a reference to something that supports the idea that
airplanes getting VFR flight following are given automatic search and rescue
if they somehow are "lost" from the controller (either radio or radar
contact lost)?
Pete
Old June 21st 05, 12:39 AM
Steven P. McNicoll
"Peter Duniho" wrote in message
flights.
rescue if they somehow are "lost" from the controller (either radio or
radar contact lost)?
http://www.faa.gov/atpubs/ATC/Chp10/atc1002.html#10-2-5
See subparagraph b.
He didn't get it quite right. ATC must initiate a search when there is an
UNEXPECTED loss of radar contact AND radio communications. If the losses
occur in an area where it's normal to lose them ATC isn't required to do
anything.
Old June 21st 05, 04:37 PM
Newps
Nope, if you are unexpectedly lost then ATC will start a search immediatley.
Old June 21st 05, 12:34 AM
Steven P. McNicoll
eenews.net...
That's not quite correct. They initiate SAR when there is UNEXPECTED loss
of radar contact and radio communications.
Old June 20th 05, 09:47 PM
Jay,
You got good service from a controller who got worried about you.
Now, quit messing around; with that very capable airplane and all the
flying you do, get your instrument rating. It'll also help your VFR
travel and dealing with ATC. Besides, the workload IFR is much, much
less than VFR when you're dealing with weather such as you had and also
having to figure out airspace and so forth.
I've had a controller get hold of a small airport when I had a total
electrical failure on an IFR flight plan. In and out of the clouds,
saw an airport below me, spiraled down and landed. As I parked, the
airport manager came out to make sure I was okay and said CVG approach
had called and was concerned. I called the controller back, told him
what was going on and thanked him for making the call to have someone
looking out for me. It was a very nice feeling on an afternoon when
the airplane was in the midst of what turned out to be a reaction to a
stupid wiring job done by someone years before that was finally coming
due as insulation was scraping off of poorly routed wires. (In fact,
it was the only good thing that happened that afternoon-figuring out
the problem and repairing it wasn't cheap.)
Warmest regards,
Rick
Old June 20th 05, 10:37 PM
Gig 601XL Builder
"Jay Honeck" wrote in message
ps.com...
Now that I think about it, I suppose we could have asked Flight Watch
to notify Chicago Center when we could no longer hear them, but frankly
it never dawned on me that Chicago really cared that much about what
happened outside of their Class B airspace.
First, Chicago Center doesn't give a crap what happens in the Chicago
Class B.
Ah, true enough. I have mistakenly been using the terms "Approach" and
"Center" interchangeably in this thread.
"Chicago Center" is always cooperative and helpful, and will
unfailingly provide flight following all the way to Iowa City (if
we're high enough, which we rarely are) if requested.
"Chicago Approach" is the ATC facility in question here. They are the
ones who called the Rantoul airport manager, and they are the ones who
usually will not provide VFR flight following.
Which is why I was (and am) so surprised that they actually took the
time to call Rantoul when we lost radio contact with them. They are
usually not so helpful.
Jay Honeck
Iowa City
Jay, you've got the plane and you travel in it enough.
Break down and get your IFR ticket.
GigG
Old June 21st 05, 12:31 AM
Steven P. McNicoll
ps.com...
Ehh? Rantoul is well outside Chicago Approach airspace. Rantoul is in
Champaign Approach airspace which is assumed by Chicago Center when
Champaign closes for the night.
Old June 21st 05, 12:23 AM
Steven P. McNicoll
I've had radar facilities chase me down after I've lost comms with them
during VFR FF. They want to make sure they didn't lose you and something
bad happened to you (like you crashed). Just consider it
an extra service.
It's not necessarily an extra service. If radio and radar contact is lost
in an area where ATC would expect to have both, then ATC is supposed to
chase you down.
Old June 21st 05, 04:34 PM
Newps
something bad happened to you (like you crashed). Just consider it
an extra service.
It is a required service. If they lose you unexpectedly ATC is required
to start a search. In Jay's case he was cruising merrily along, asked
to switch to Flight Watch and then disappeared. Meanwhile Center is
watching Jay descend and can't get a hold of him. Pretty soon he drops
off radar. So call the most likely spot, the airport. If the manager
wouldn't have found him then SAR would have been started.
Old June 21st 05, 09:31 PM
Jay Honeck
an extra service.
Thanks for the clarification.
It's nice to know that the guys manning the Big Eye in the Sky are
watching out for us more carefully than I previously believed.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
RAF Blind/Beam Approach Training flights Geoffrey Sinclair Military Aviation 3 September 4th 09 06:31 PM
Flight Simulator 2004 pro 4CDs, Eurowings 2004, Sea Plane Adventures, Concorde, HONG KONG 2004, World Airlines, other Addons, Sky Ranch, Jumbo 747, Greece 2000 [include El.Venizelos], Polynesia 2000, Real Airports, Private Wings, FLITESTAR V8.5 - JEP vvcd Piloting 0 September 22nd 04 07:13 PM
Looking for Cessna Caravan pilots [email protected] Owning 9 April 1st 04 02:54 AM
us air force us air force academy us air force bases air force museum us us air force rank us air force reserve adfunk Jehad Internet Military Aviation 0 February 7th 04 04:24 AM
