Michael Clarke wrote:
Derek, my Nimbus 4 flight manual says: a) Apply opposite rudder. b) Hold ailerons neutral. c) Ease control sick forward until roation ceases and the airflow is restored. d) Centralise rudder and pull gently out of the dive. No surprize: JAR22 explicitely demands "standard spin recovery". And it must demonstrated from a spin of "at least 5 turns" and with "the most unfavorable configuration". (Cited from memory, so the exact wording may be different.) Stefan |
Just for general clarification, Section 4.5.6 of my
Nimbus 4T flight manual says: “Note: In order to achieve a high maneuverability, a favourable c/g position (when using the fin tank) and a maximum in ground clearance of the wing tips on take-off and landing, it is always recommended to fill the inboard water tanks first.” I know it is the opposite for the Nimbus 3, I assume the wings are just that much stronger on the 4. In my experience it does make take off less fraught and handling a bit nicer on the 4 than the 3. Mike At 18:30 11 July 2005, Roy Bourgeois wrote: I think what Bert says is technically correct (wing load doesn't change when you open the air brakes) - but the distribution does change a lot - especially on a ship like the N3 & N4 where the brakes are located inboard on the inner panels. Stated differently, when the brakes are opened the outer panels are being asked to do more work supporting the fuselage (and non flying portions or the inner panels) than before the dive brakes were opened. The Nimbus 3 and 4 are placarded against carrying water ballast in the inner panel tanks with the outer panel tanks empty for structural reasons. You also must dump the inner tanks first. The same structural problem occurs when the dive brakes are open and that part of the inner panel becomes 'dead weight'. So - while the brakes should be used to prevent the glider getting to extreme speeds - we need to be cautious about suggesting that nothing bad is going to happen if you open them at extreme speeds. Roy B. (Nimbus 3 # 65) |
At 20:18 13 July 2005, T O D D P A T T I S T wrote:
Don Johnstone wrote: If you have to open the brakes, do so before Vne is reached Absolutely correct, carve that in stone. The implication here is that if you find yourself extremely nose down, but at an initially low speed, opening the brakes is a desirable action. I disagree. Opening the brakes might be advisable if brakes were able to produce large amounts of drag - sufficient to limit you to speeds below Vne - but that is generally not true. So, your only other option is to get the nose back up to stop the acceleration. The only way to do that is to apply the maximum force possible in a direction perpendicular to the downwardly angled path of the aircraft to curve it back towards level. A force perpendicular to the path of the aircraft is called 'lift' and by opening the brakes you prevent much of the wing from producing the lift you desperately need to bring you back to level flight. This delays the critical recovery. Up until you reach Va, you can operate the wings at maximum lift coefficient and produce maximum lift without risk of structural damage, and that's exactly what you want to do to get the nose back up. In addition, by opening the brakes, you seriously increase the risk that the pilot will overstress the aircraft at higher speeds. With brakes open, the max G load for many gliders is so low that the pilot simply does not think he's about to break anything. His built in warning system does not begin to go off until much higher G loads are felt. Finally, if you open the brakes, you increase the altitude loss significantly, a potentially critical factor in a low altitude recovery. The proposal to use a tail chute does not suffer from these problems, as a tail chute does not decrease lift or max G limits. It also has the advantage of allowing recovery from otherwise unrecoverable spin modes. I accept what you say my original reponse was to the whole paragraph 'My main original point was that the first action in any sort of loss of control situation in a flapped glider must be to select neutral or negative flap. If you have to open the brakes, do so before Vne is reached' I standby that. It is important to select a non positive flap setting and if the brakes are going to be used it should be before VNE is reached. |
At 04:48 16 August 2005, Gerhard Wesp wrote:
Ian wrote: If you are in a situation (perhaps recovering from a spin) with your nose pointing 60 deg down below the horizontal and the ASI reading 180 km/h and accelerating rapidly. You could try: [ leave A/B closed and pull 4G ...] I have not worked out the maths of the two options but I think that in a clean glass ship, you would have a better chanced completing the first manoeuvre without exceeding VNE than the second. I couldn't resist the temptation and did the maths. I kind of lost the habit, so it took me 20 minutes. The result is: My intuition was right: Do *not* use the airbrakes. Even in an ideal ship (zero drag) and with the nose pointing vertically down initially, the peak speed is only 240km/h under your assumptions (4g pull-up and 180km/h initially). In a real ship and with only 60 degrees down, the peak speed would of course be lower. Here's the script with the phugoid equation (Mathematica). Feel free to modify the initial conditions and parameters and play around. The unknowns are v1, v2, the horizontal and vertical component of the speed vector. kmh = 1 / 3.6 Ng = 4 g = 9.81 v0 = 180 kmh tmax = 8 dt = .1 v = NDSolve[ { v1'[ t ] == Ng g * v2[ t ] / Sqrt[ v1[ t ]^2 + v2[ t ]^2 ] , v2'[ t ] == Ng g * -v1[ t ] / Sqrt[ v1[ t ]^2 + v2[ t ]^2 ] - g , v1[ 0 ] == 0 , v2[ 0 ] == -v0 } , { v1 , v2 } , { t , 0 , tmax } ][[ 1 ]] Table[ ( Sqrt[ v1[ t ]^2 + v2[ t ]^2 ] /. v ) / kmh , { t , 0 , tmax , dt } ] Regards -Gerhard I think the ground might get in the way before I have done the sums :-) |
since induced drag increase due to airbrakes is=20
high=20 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Don't you mean "form" drag? I thought induced drag resulted (crudely) from the wingtip vortices. Also, are you sure that drag is proportional to lift? Rgds, Derrick Steed |
Derrick Steed a écrit :
since induced drag increase due to airbrakes is=20 high=20 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Don't you mean "form" drag? I thought induced drag resulted (crudely) from the wingtip vortices. No. Wingtip vortices are only the visible part of the iceberg ;-) Induced drag is the result of lift itself and is lower when the span is higher and when the spanwise lift repartition is close to elliptic. And with the airbrakes out, the lift repartition is very bad, closer to 3 wings of 5 m of span separated by no lift (at the airbrakes) than to 1 27 m wing ! Also, are you sure that drag is proportional to lift? Induced drag is proportionnal to square of lift, while form drag don't vary much with lift. Total drag definitely increases with lift, but to quantify it that's where we need the proportion of induced drag... -- Denis R. Parce que ça rompt le cours normal de la conversation !!! Q. Pourquoi ne faut-il pas répondre au-dessus de la question ? |
Denis wrote: Derrick Steed a écrit : since induced drag increase due to airbrakes is=20 high=20 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Don't you mean "form" drag? I thought induced drag resulted (crudely) from the wingtip vortices. No. Wingtip vortices are only the visible part of the iceberg ;-) Induced drag is the result of lift itself and is lower when the span is higher and when the spanwise lift repartition is close to elliptic. And with the airbrakes out, the lift repartition is very bad, closer to 3 wings of 5 m of span separated by no lift (at the airbrakes) than to 1 27 m wing ! This appears to be confused. Also, are you sure that drag is proportional to lift? Induced drag is proportionnal to square of lift, while form drag don't vary much with lift. Total drag definitely increases with lift, but to quantify it that's where we need the proportion of induced drag... And this is clearly totally mistaken, or misspoken. Two gliders flying have twice as much lift as one glider, but they have four times as much induced drag as one glider? And ten gliders have one hundred times as much induced ddrag as one? -- Bruce | 41.1670S | \ spoken | -+- Hoult | 174.8263E | /\ here. | ----------O---------- |
Bruce Hoult a écrit :
Also, are you sure that drag is proportional to lift? Induced drag is proportionnal to square of lift, while form drag don't vary much with lift. Total drag definitely increases with lift, but to quantify it that's where we need the proportion of induced drag... And this is clearly totally mistaken, or misspoken. .... or misunderstood ;-) Two gliders flying have twice as much lift as one glider, but they have four times as much induced drag as one glider? And ten gliders have one hundred times as much induced ddrag as one? in this thread it is question of drag vs load factor - i.e. lift of one glider, not of ten ! -- Denis R. Parce que ça rompt le cours normal de la conversation !!! Q. Pourquoi ne faut-il pas répondre au-dessus de la question ? |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 02:26 PM |
Nimbus 4DT accident 31 July 2000 in Spain. | W.J. \(Bill\) Dean \(U.K.\). | Soaring | 217 | July 11th 05 03:13 PM |
AmeriFlight Crash | C J Campbell | Piloting | 5 | December 1st 03 02:13 PM |
Single-Seat Accident Records (Was BD-5B) | Ron Wanttaja | Home Built | 41 | November 20th 03 05:39 AM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
