DUAT
Old July 11th 05, 02:55 AM
Stan Prevost
Default DUAT
I used to use DUAT to file flight plans for VFR Flight Following and VFR On
Top. Not long ago, they changed their software. Now I can't get it to
accept an OTP flight plan. Haven't tried FF.
Example: Yesterday I filed an IFR plan having altitude field of 125/OTP.
It rejected it. It accepted 125 for altitude, but I had to put "VFR On Top"
in Remarks.
Anyone else have this problem with DUAT? I haven't tried DUATS.
Stan
Old July 11th 05, 03:37 AM
john smith
As I have a Mac, the Golden Eagle software is useless for me.
I do use the service online for preflight planning.
There have been too many reported problems with flight plans not
entering the system for me to file online.
I always call a briefer verify the duat preflight info I obtained and
file my flight plans with the briefer.
Old July 11th 05, 04:29 AM
Newps
Try just OTP. The actual altitude is not needed.
in Remarks.
Stan
Old July 11th 05, 05:29 AM
Stan Prevost
OK, I'll try, but it used to work.
"Newps" wrote in message
On Top. Not long ago, they changed their software. Now I can't get it
to accept an OTP flight plan. Haven't tried FF.
Top" in Remarks.
Stan
Old July 11th 05, 03:09 PM
Stan Prevost
I tried it and OTP is accepted. However, I then tried OTP/125, and that was
also accepted, as was VFR/125 (for FF). I just had the order of the
subfields switched in my head. Apparently nothing has changed.
Stan
Top" in Remarks.
Stan
Old July 11th 05, 03:53 PM
Newps
There's no reason to put an altitude in when you're OTP. ATC knows you
may need to change altitudes for clouds, winds, etc.
Stan
Top" in Remarks.
Stan
Old July 11th 05, 04:18 PM
Stan Prevost
If I put the desired altitude in the plan, then the controller knows that I
want 12500 and can tell me to "maintain VFR On Top at or below 12500". If I
don't put it in, then he has to ask me what altitude I want or just
arbitrarily assigns me something and then if it's not what I want we have to
go through more radio exchange.
How is it better to not include the altitude?
was also accepted, as was VFR/125 (for FF). I just had the order of the
Stan
125/OTP. It rejected it. It accepted 125 for altitude, but I had to put
"VFR On Top" in Remarks.
Stan
Old July 11th 05, 07:24 PM
KP
Include what you *think* the weather conditions *might* allow your VFR
cruising altitude to be if you feel like it but "VFR-On-Top" alone is your
*requested/assigned* IFR altitude.
Once you report reaching VFR-On-Top and the controller reclears to to
"Maintain VFR-On-Top" he isn't responsible for separation. After that he
doesn't really care much what your actual altitude is now or might be later
(beyond verifying your Mode C for traffic or idle curiosity).
Any altitude restrictions issued *before* you reach VFR-On-Top are a
different matter.
"Stan Prevost" wrote in message
I want 12500 and can tell me to "maintain VFR On Top at or below 12500".
If I don't put it in, then he has to ask me what altitude I want or just
to go through more radio exchange.
Stan
VFR On Top. Not long ago, they changed their software. Now I can't
get it to accept an OTP flight plan. Haven't tried FF.
put "VFR On Top" in Remarks.
Stan
Old July 12th 05, 03:36 PM
Newps
No he does not.
or just
Say unable. OTP is a VFR altitude and no separation is provided. The
only time a controller should start trying to nail you down is as you
get close to your destination and you will need to be fit into an
arrival stream.
Old July 12th 05, 03:44 PM
Steven P. McNicoll
An alternative clearance is issued when necessary to ensure separation from
other traffic or airspace. For example, if the controller had traffic at
nine thousand a proper clearance would be; "Climb to and report reaching
VFR-on-top, no tops reports. If not on top at eight thousand maintain
eight thousand and advise." Remember, you're just another IFR aircraft
until you report reaching and are cleared to maintain VFR-on-top.
To issue "maintain VFR On Top at or below 12500" the controller would have
to know the tops were 11,500 or lower. Why use a restriction of 12,500? To
separate from IFR traffic at 13,500 or VFR traffic at 13,000?
Duat Graphics Slick Piloting 0 January 23rd 05 01:35 PM
NAS and associated computer system Newps Instrument Flight Rules 8 August 12th 04 05:12 AM
DTC DUAT Matt Whiting Instrument Flight Rules 0 June 5th 04 03:23 PM
Picking Optimal Altitudes O. Sami Saydjari Instrument Flight Rules 20 January 8th 04 02:59 PM
