#31
"Icebound" wrote in
: "Dave S" wrote in message ink.net... Icebound wrote: Where did you get that number? One of the discovery channel programs on the soviet space program, which I have not independently verified. http://www.jamesoberg.com/ James Oberg gives a pretty detailed account of Soviet failures and myths. I have not been able to find an actual "number" in his on-line stuff (buy the books, I guess), but the implication is that some rumors of USSR space deaths are overblown... and he also states that some is simply not known. Now since he often appears on Discovery, so that "100" figure may be his (or NOT), but his chapter at: http://www.jamesoberg.com/usd10.html does not seem to imply a number anywhere near that. Try this article of his.... http://www.astronautix.com/articles/therophe.htm Brian -- http://www.skywise711.com - Lasers, Seismology, Astronomy, Skepticism Seismic FAQ: http://www.skywise711.com/SeismicFAQ/SeismicFAQ.html Blog: http://www.skywise711.com/Blog Sed quis custodiet ipsos Custodes? |
#32
Jose wrote: [snip] But the focus of our space program should be going to Mars and onward. Because it's there. Absolutely!!! -- Bob Noel no one likes an educated mule |
#33
![]() "Skywise" wrote in message ... "Icebound" wrote in : "Dave S" wrote in message ink.net... Icebound wrote: Where did you get that number? One of the discovery channel programs on the soviet space program, which I have not independently verified. http://www.jamesoberg.com/ James Oberg gives a pretty detailed account of Soviet failures and myths. I have not been able to find an actual "number" in his on-line stuff (buy the books, I guess), but the implication is that some rumors of USSR space deaths are overblown... and he also states that some is simply not known. Now since he often appears on Discovery, so that "100" figure may be his (or NOT), but his chapter at: http://www.jamesoberg.com/usd10.html does not seem to imply a number anywhere near that. Try this article of his.... http://www.astronautix.com/articles/therophe.htm Thanks.... in the index on his "Russian" page, I had skipped right over that one to "Uncovering Soviet Disasters; Chapter on Dead Cosmonauts", several items below. Thanks again. |
#34
Judah wrote:
But the regs say it only has to be accurate when empty! Wrong. George Patterson Why do men's hearts beat faster, knees get weak, throats become dry, and they think irrationally when a woman wears leather clothing? Because she smells like a new truck. |
#35
Another fleet of mini-shuttles would be used to
carry people up and down - they would be the size of a lear jet and have enough payload capability for six people and little else. Funny you should say that. There is a company in Oklahoma that plans on taking a stripped Lear 25 fuselage, bolting it to a basic wing, adding turbofan engines and a re-useable rocket engine. Take-off and climb to 30,000 feet of the turbofans, light the rocket and climb to 158,000 feet, then coast to about 330,000 feet before gliding back to earth. All in a half hour flight. Perhaps I should have been clearer... "Another fleet of mini-shuttles would be used to carry people up and down, and get them going five miles per second to meet with other stuff up there." ![]() Jose -- Nothing takes longer than a shortcut. for Email, make the obvious change in the address. |
#36
![]() "Ben Hallert" wrote I wonder if these low-fuel sensors are part of the system that shuts down the SSMEs if there's a fuel starvation issue. I remember a mission a few years back where MECO (main engine cut-off) was unexpectedly a few seconds early because of higher then projected fuel burn or something. Not enough to really impact the mission, but it showed the safety systems that prevent dry-running SSMEs was working. That was exactly the problem. The main engines shut off at zero fuel level, and with the sensor reading zero fuel, the engine would not even start. Not a "good' thing. -- Jim in NC |
#37
Morgans wrote:
"Ben Hallert" wrote I wonder if these low-fuel sensors are part of the system that shuts down the SSMEs if there's a fuel starvation issue. I remember a mission a few years back where MECO (main engine cut-off) was unexpectedly a few seconds early because of higher then projected fuel burn or something. Not enough to really impact the mission, but it showed the safety systems that prevent dry-running SSMEs was working. That was exactly the problem. The main engines shut off at zero fuel level, and with the sensor reading zero fuel, the engine would not even start. Not a "good' thing. There are four sensors - NASA could have removed this (apparently) faulty sensor from the voting. Hilton |
#38
I'm guessing that they're deciding that they don't want to launch with
the loss of avoidable redundancy. If they lose a sensor after they're off the pad, that's one thing. But would you embark on a cross country after losing your vacuum system? Why not, you have the electric instruments that your IFR training showed you how to use as a backup....? Same thing with them, plus a healthy dose of CYA, nobody wants to be 'that guy that said launch anyways' right before it asplodes, and turns out that it's because of a short in the faulty sensor that, I dunno, caused a leak of LOX into the H2 tank or something. Ben Hallert PP-ASEL |
#39
Quick followup, the SSME does not have a restart-in-flight mode, so
once it's shut down, it stays off until after the shuttle is back on the ground. Ben Hallert PP-ASEL |
#40
AES wrote:
But the bottom line here is surely that the whole manned space flight effort and focus at NASA not only should be terminated as fast as possible, but should have been terminated several decades ago, for at least two major reasons. Well, at this point I think manned spaceflight needs to be saved *from* NASA, not *by* it. First of all, manned space flight at this point in time is just too difficult, dangerous, and expensive to be worth pursuing. It's a matter of the laws of physics versus the currently available or currently foreseeable level of technology, not the competence or the culture of NASA. Maybe some future breakthrough in technology will make manned space flight a much more reasonable goal; maybe not. "Future breakthrough[s] in technology" do not fall out of trees. Once upon a time, flying at FL450 was "difficult, dangerous, and expensive." But because we kept doing it, failing with often lethal results, it is now as safe (or safer) as traveling on the ground. But by far the more compelling reason is that there are really zero useful things, much less compelling needs, that we can or might want to accomplish in space that are not better done with unmanned rather than manned missions. Perhaps. This is where the argument turns from a matter of reason into one more like faith. There is little that astronauts could do on the surface of Mars that we cannot at this time do faster and more cheaply with robots. BUT... The challenge of sending a human crew to the surface of Mars, and bringing it back to Earth intact, would I think serve to spur the development of many things with more quotidian uses. With a mission likely to last several years, one problem is healthcare. Many things can happen, and even if you put a doctor on the crew you have to allow (a) that he won't know everything and (b) he may get injured himself. So, you need to provide alternatives: computerized monitors which can observe the body and render diagnoses, and possibly devices which allow people with less than an MD to provide meaningful care. Healthcare is currently 15% of our economy, and growing without bounds. Surely such research could have revolutionary impact on our lives. The bureaucracy and legal/financial obstacles to developing such things in the pure civilian world mean that advancements will come slowly at best. In wartime, governments, businesses, and people are willing to take all manner of chances because victory depends upon it. Even Stalin gave up shooting his political opponents for a few years during WWII when it was clear that the Nazis might roll them all over. Similarly, the Apollo program provided an imperative of sufficient power to justify innovation at all costs. Frontiers are, always have been, and always will be dangerous places, but behind the pioneers come settlers. And then of course there is the point that man does not live by bread alone. You concede that the Apollo program was the right thing to do at the time, though it had little direct scientific merit. What about today? Imagine the whole world, from Shanghai, to Tehran, to Paris, and Los Angeles watching as an American backed down a ladder onto the surface of Mars. Now imagine that the astronaut is a Muslim woman, who came here as an immigrant to be educated in our great universities. Laugh, shake your head, scream "PC!" or whatever, but don't tell me this wouldn't cast an amazing shadow across the landscape. -cwk. |
Time, running out of fuel and fuel gauges | Dylan Smith | Piloting | 29 | February 3rd 08 07:04 PM |
fuel leak or auxiliary fuel pump malfunction? | [email protected] | Owning | 7 | December 17th 06 12:57 PM |
Replacing fuel cut-off valve with non-a/c part??? | Michael Horowitz | Owning | 46 | January 15th 05 10:20 PM |
Is Your Airplane Susceptible To Mis Fu eling? A Simple Test For Fuel Contamination. | Nathan Young | Piloting | 4 | June 14th 04 06:13 PM |
Yo! Fuel Tank! | Veeduber | Home Built | 15 | October 25th 03 02:57 AM |
