![]() "Mark Hansen" wrote in message ... No, Actually, he's not (unfortunately). Well, he had to get the idea they were ground speeds somewhere. The timing table is pretty much the only possible source. |
On 7/15/2005 11:52, Steven P. McNicoll wrote:
"Mark Hansen" wrote in message ... No, Actually, he's not (unfortunately). Well, he had to get the idea they were ground speeds somewhere. The timing table is pretty much the only possible source. His reasoning is that the faster we're moving across the ground, the faster we'll move outside of the protected area, for example, on the circling maneuver, and that to use the higher minimums 'just made good common sense'. However, he's interpreting the rule using this 'common sense' and claiming that this is what the rule implies. He made it clear to me that he was talking about the approach category minimums and not just the time from FAF to MAP (which, of course, is based on ground speed). -- Mark Hansen, PP-ASEL, Instrument Student Sacramento, CA |
![]() "Mark Hansen" wrote in message ... On 7/15/2005 11:52, Steven P. McNicoll wrote: "Mark Hansen" wrote in message ... No, Actually, he's not (unfortunately). Well, he had to get the idea they were ground speeds somewhere. The timing table is pretty much the only possible source. His reasoning is that the faster we're moving across the ground, the faster we'll move outside of the protected area, for example, on the circling maneuver, and that to use the higher minimums 'just made good common sense'. However, he's interpreting the rule using this 'common sense' and claiming that this is what the rule implies. He made it clear to me that he was talking about the approach category minimums and not just the time from FAF to MAP (which, of course, is based on ground speed). -- Mark Hansen, PP-ASEL, Instrument Student Sacramento, CA This CFII is stupid. Once you start circling the winds change and will become a headwind at some point. Mike MU-2 |
Mark Hansen wrote in
: His reasoning is that the faster we're moving across the ground, the faster we'll move outside of the protected area, for example, on the circling maneuver, and that to use the higher minimums 'just made good common sense'. He has no idea what he's talking about. TERPS takes tailwinds into account, and it's not possible to exceed the protected airspace if you use the correct airspeed, and don't have a hurricane blowing behind you. And in that case, you need to reconsider flying that approach. -- Regards, Stan "They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." B. Franklin |
NTSB: USAF included? | Larry Dighera | Piloting | 10 | September 11th 05 10:33 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 2nd 03 03:07 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 05:12 AM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
