VOR Check question
Old July 22nd 05, 08:01 PM
Michael 182
Default VOR Check question
I was told by an avionics guy that if a plane has VOR's they must be
accurate to file IFR, even if I file /G.
FAR 91.171 says "(a) No person may operate a civil aircraft under IFR using
the VOR system of radio navigation unless the VOR equipment of that
aircraft..."
I'm not debating the logic of having VOR's that are accurate, and I'm
getting mine adjusted - but it seems to me if my means of navigation is an
IFR certified GPS I do not have a legal responsibility to pass the VOR
check. Am I right?
Michael
Old July 22nd 05, 08:38 PM
Mark Hansen
aircraft..."
check. Am I right?
Michael
You are also required to have available in the aircraft equipment necessary
for navigation along your route, in the event GPS goes out. That sounds like
VOR to me.
Mark Hansen, PP-ASEL, Instrument Student
Sacramento, CA
Old July 22nd 05, 09:57 PM
Ron Natalie
like
VOR to me.
Not if you have the right GPS. But an unchecked VOR is technically not
airworthy, so unless you're going to follow the procedures for inop
equipment, it would be easier just to do it.
Old July 23rd 05, 12:41 PM
like
VOR to me.
Not so. VOR is still the primary means of navigation in the NAS. Even the
latest and greatest airline aircraft with dual GPS sensors, dual FMSes, triple
IRUs, etc, cannot be dispatched without operate VOR receivers (in their case
two).
The presumption is that the GPS system can fail at any time; at least in a given
area. WAAS doesn't mitigate that whatsoever.
Old July 26th 05, 01:36 AM
Mike Rapoport
wrote in message ...
Ron Natalie wrote:
necessary
like
VOR to me.
triple
case
two).
given
I thought that WAAS was approved for sole means of navigation?
MU-2
Old July 26th 05, 04:36 AM
Stan Gosnell
"Mike Rapoport" wrote in
nk.net:
Not that I'm aware of. WAAS has nothing to do with reliability, other
than vertical accuracy. Its only function is to give enough vertical
accuracy to allow a semi-precision approach.
Regards,
Stan
"They that can give up essential liberty to obtain a little temporary
safety deserve neither liberty nor safety." B. Franklin
Old July 26th 05, 04:09 PM
Steven P. McNicoll
triple
case
two).
given
So why is it presumed that the VOR system cannot fail?
Old July 27th 05, 05:11 AM
Jose
I would assume (and I know the etymology) that VORs fail 1000 square
miles at a time, and GPS fails 3,000,000 square miles at a time. Or,
more to the point, there is more systemic redundancy in the VOR system.
Jose
Nothing takes longer than a shortcut.
Legal question - Pilot liability and possible involvement with a crime John Piloting 5 November 20th 03 09:40 PM
