Rheostat Audio Interference
Old August 11th 05, 06:28 AM
RST Engineering
My original comment holds...
horsefeathers.
"David Lesher" wrote in message
"RST Engineering" writes:
If you look closely at an incandescent light bulb (especially the aviation
versions like the 327-28 volt and 330-14 volt) you will see that the
internals of the bulb start with a little dot of ceramic called the
"bead".
Well, I was not aware we were talking exclusively about aviation/space
rated lamps, but as it turns out while working for LeRC; I almost
emptied Building 142 with those unshortable lamps. I was driving
them with NE555's which turned out to be effective, if somewhat
smoky, fuses. The technician and I just looked at each other while
the cloud rose toward the smoke detector....the one going to the
sprinkler system and Evac alarms.
Audio Panel Suggestions Jay Honeck Owning 5 May 9th 05 02:00 PM
millionaire on the Internet... in weeks! Malcolm Austin Soaring 0 November 5th 04 11:14 PM
S-TEC 60-2 audio warning Julian Scarfe Owning 7 March 1st 04 08:11 PM
RF interference issue again (esp. for E Drucker and Jim Weir and other RF wizards) Snowbird Owning 77 December 3rd 03 09:10 PM
