UK planning to evict N-registered aircraft
Old August 10th 05, 11:17 PM
Juan Jimenez
"Thomas Borchert" wrote in message
Juan,
In Argentina the same rule applies,
Actually, IIRC, the rule planned for the UK is more sophisticated: 90
days out of 365 are the maximum allowed time in the UK.
Ah, but of course, the dreaded Anal CAA Residency Rule.
Can't someone give the suicidal muslims alternate targets, like, umm...
bureaucrats?
  #32
Old August 11th 05, 12:25 AM
David Lesher
Obviously, this change is necessary to keep all the terrorists with
N-registered airframes from sneaking away in IFR weather.
A host is a host from coast to
& no one will talk to a host that's close........[v].(301) 56-LINUX
Unless the host (that isn't close).........................pob 1433
is busy, hung or dead....................................20915-1433
  #33
Old August 11th 05, 12:47 AM
Sylvain
ORVAL FAIRAIRN wrote:
In the US, all you need is three takeoffs and landings at night within
the past 90 days to be qualified at night -- no IFR, "night rating," etc.
to carry passengers; if you go on your own, you don't even need that.
--Sylvain
  #34
Old August 11th 05, 12:51 AM
Scott Moore
Naw, it keeps N registered airplanes from being flown over the ocean
and used as weapons. The terrorists can't afford to learn to fly in
the UK, like everyone else.
  #35
Old August 11th 05, 03:19 AM
George Patterson
bureaucrats?
Nah... They're smart enough to realize who their allies are.
George Patterson
Give a person a fish and you feed him for a day; teach a person to
use the Internet and he won't bother you for weeks.
  #36
Old August 11th 05, 07:08 AM
ShawnD2112
Are you kidding? Have you ever tried to find an ANO reference for anything?
I can't make heads or tails out of that silly document.
You're much more technically correct that I intended to be. I was only
trying to point out the original poster was in error about the IMC rating.
Shawn
"Peter" wrote in message
"ShawnD2112" wrote
You need an IMC rating to fly in IMC but it doesn't give
you the full priveleges of an IR (Class A use, for instance). It is
merely
to teach you to fly in marginal weather.
Do you have an ANO reference for the last sentence of the above?
The IFR privileges of the UK IMC Rating are essentially those of the
JAA IR, but limited to the UK, no Class A, and 1800m min vis.
Everything else is an opinion; fair enough but it's just that.
One can do perfectly safe fully-IFR flights, in solid IMC, with its
privileges. Just like the full IR, it needs currency and a suitable
aircraft and these cost serious time and money.
Unfortunately it's no good outside the UK, for IFR.
Its possession removes the UK PPL *VFR* requirement to be in sight of
surface and that removal is valid everywhere where they have not added
the "must be in sight of surface" requirement to the ICAO PPL (got
that in writing from the CAA).
  #37
Old August 11th 05, 11:49 PM
Simon Hobson
On Thu, 11 Aug 2005 7:08:08 +0100, ShawnD2112 wrote
(in message ) :
If you are referring to my post at 9:02 yesterday, then please go back and
read it again - I did NOT mention IMC rating or flying in IMC, only IFR !
IFR is not the same as IMC, you can easily fly IFR in VMC.
I wrote :
Not to mention that in the UK a basic PPL with no ratings can fly IFR,
and only needs a Night Qualification to fly at night. I understand
that elsewhere, any night flying (as here) is IFR, and IFR is not
allowed without a full IR.
Hence even night flying requires an IR outside the UK.
In hindsite I suppose I should qualify that statement as "Hence even night
flying requires an IR IN MANY COUNTRIES outside the UK." since I am aware
that the UK is not the only place that allows night flight without an IR.
  #38
Old August 12th 05, 06:01 PM
ShawnD2112
Good point. I'll read more closely next time.
Shawn
"Simon Hobson" wrote in message
et...
(in message ) :
anything?
rating.
  #39
On Thu, 11 Aug 2005 06:08:08 GMT, "ShawnD2112"
Shawn
merely
If you look at the ANO under Schedule 8 it gives the PPL privileges of
an IMC and Night Rating:
http://www.legislation.hmso.gov.uk/s...0/20001562.htm
As for Operating Mimima this is in the AIP under Aerodromes General
AD-1. In particular from section AD 1-1-6:
http://www.ais.org.uk/aes/pubs/aip/p...omes/30101.PDF
As noted previously you may only wish to "fly in marginal weather" but
you can legally fly "fully-IFR flights, in solid IMC". The CAA may
wish to stress it's only to get you out of trouble but that is only
their recommendation.
I have an IMC rating and usually file IFR on longer flights in the UK,
especially as flights over the Cairngorm Mountains are rarely blue
skies! Sometimes I can get on top at FL70 to FL10. If only I could use
the IMC rating when on holiday..
David
  #40
Old August 12th 05, 11:24 PM
Juan Jimenez
LMAO! Good one!
"George Patterson" wrote in message
news:WAyKe.5672$lK2.1846@trndny01...
bureaucrats?
George Patterson
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 May 1st 04 07:29 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 April 5th 04 03:04 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 2 February 2nd 04 11:41 PM
